Question about 3Com NBX 3101
Call Forwarding --Help
Phone rings twice then sends it to another persons phone?
The phone may be apart of a hunt group. Inside of the Net Set Utility, check to see if it is a member of that hunt group.
Posted on Mar 03, 2009
Incoming calls
Who is your carrier? the voice mail is set up via them call or web site. Your phone rings or not rings check ringer volume and ring tone and check if you always have a good signal.
Mar 07, 2014 | everbuying Cheap Unlocked Phone 5.0 inch...
How do you personalize your ring tone
Press PROGRAM the CO or intercom button twice, and use the Navigator key to step up or down for one of 30 tones. 1,4 and 7 or 9 is a normal standard ring, 25-30 or so is tunes. You have to do it for all lines or ICD groups to make it be special on your phone.
Carl
Dec 09, 2009 | Panasonic KX-T7633 Corded Phone
Number shows not the person name.
It is possible that you have not saved the number in the name of person whom you are sending message, or you might have saved that number twice in your cell phone, i.e. either in sim card or in mobile phone or both.
There is another way to check this. Try dialing the same number, if it shows the name of the person whom you have saved then its fine. If it shows the number only, then it indicates that you have have his number saved twice.
Try, you will get through this.
Sep 15, 2009 | Nokia E71 Smartphone
My Nokia 6300 only rings twice maybe 3 times therefore I have to bear the cost of always ringing the person back as I can't get to it in time
Type in *#002# . It will deactivate all call forwarding and phone will ring until caller hangs up. The code works on any GSM network only.
Rate me if helped,thanx.
May 02, 2009 | Nokia 6300 Cellular Phone
How do you turn the ringers off on the phone?
Do Not Disturb (Feature 01) will turn the ringing off of a phone, but it will also send any lines assigned to ring on that phone to voicemail (if applicable).
OR, to turn ringing off in system programming:
From ext. 10 or 11, press Feature button, 00, left intercom button twice, right intercom button once. Enter extension number of phone you wish to remove the ringing line from. Light indicators next to line keys show ringing status. Press line keys to desired ringing preference for each line-
steady green light- immediate ring
green fast flutter- no ring
green slow flash- delayed ring
Press "feature" 00 to exit
Mar 06, 2009 | AT&T Lucent MLS-12D Phone
Motorola W377 sends same message twice
Always From The Same Person? If So Its The Other Persons Service Doing It. If Its From Everyone That Way Call Your Wireless Provider And Tell Them About The Double Texts And They Should Offer Compensation.
Jan 05, 2009 | Motorola Mobility W377 Met Silver/Pink...
Incessant ringing
Ringing: Check the Alarm to know if their is a default time saved for the phone to ring.
SMS: It is not your problem. The problem is with an infected Nokia phone Symbian S60 to be specific. If my memory did not fail me I think it is called "CommWarrior".
It is possible that it might be the malware that is sending the messages to you. You need not to worry it will not cause you any harm.
Jun 18, 2008 | Motorola Mobility RAZR V3
Ring tones v3xx
With Motorola, they made the software so that when you have a call and an sms from a person that has a custom ring tone, it will ring like that both ways. Thats a limitation in the firmware with no way around it. And yes, you can either call your carrier to block it by default on the network itself, or you can go to into the phone settings and toggle a menue called send caller id, and click off
Jan 23, 2008 | Nokia 6233 Cellular Phone
Phone calls going to voice message without ringing while person is there.
Question: What does this have to do with a Panasonic KX-T7425 phone? Is a Panasonic phone hooked up to your Partner system?
Sounds like the system believes the phone is in use. Is the partner phone in question an MLS model? MLS-6, MLS-12 etc.. They all have keypad problems and buttons could be activating on their own randomly, making the phone in-use on the system. The message waiting light may not come on until the phone is no longer in-use. Usually phones with this problem will at least beep randomly when it thinks the buttons are being pushed.
Oct 11, 2007 | Panasonic KX-T7425 Corded Phone
3Com NBX 3101 Logo
158 people viewed this question
Top 3Com Computers & Internet Experts
micky dee
didi2005
john smith
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
