Question about Systemax (036052) PC Desktop
Error message, can't run network diagnositcs, system restore....
Many problems all of a sudden. No virus' detected. error message says "cannot access the specified device path, or file (C\documents and settings\HP_Admin\local settings\temporary Iternet Files\content:ies ...the path in my computer is C\documents and settings\HP_Admin\local settings\temp\temporary Iternet Files\content:ies I don't know how to make the two the same ..some files seem to be hidden, search for them, then make them visible, then they disapear again. There is no folder file in tools menu. I can not use arrow keys during game play. Can not restore computer to previous date, can not run any programs/diagnostics on internet without error message popping up. Pop ups are not disabled.
  • jeffrey gallagher May 11, 2010
    what os are you running a suppose it is xp give me more about when problem started
    Scholar:
  • 96 Answers
The Last Known Good Configuration feature is a recovery option that you can use to start your computer by using the most recent settings that worked. The Last Known Good Configuration feature restores registry information and driver settings that were in effect the last time the computer started successfully.
To start your computer by using the Last Known Good Configuration feature, follow these steps:
  1. Start your computer.
  2. When you see the "Please select the operating system to start" message, press the F8 key.
  3. When the Windows Advanced Options menu appears, use the ARROW keys to select Last Known Good Configuration (your most recent settings that worked), and then press ENTER.
  4. If you are running other operating systems on your computer, use the ARROW keys to select Microsoft Windows XP, and then press ENTER.
Posted on Sep 07, 2009
  • 70 Answers
Your internet may be blocked by the programs installed on your computer,may be blocked by some antiviruses or any.removing that programme or reinstalling windows xp or vista may fix that problem
Posted on Jun 20, 2009
IMF.exe missing component rtl120.bpl how to restore it?
error is a common system error which tells you that rtl120.bpl file is missing or corrupted when you try to open certain files, applications or just start up the computer. Usually rtl120.bplerror happens when there is a conflict in the path of the Dynamic Link Library or when there is some missing/ corrupted entries in Windows registry. rtl120.bpl error may cause the related programs stop functioning and accesses areas of your system memory incorrectly.
Method 1. Fix rtl120.bpl error Manually by Going Tweaking The Registry Keys.
  • a. Click "Start" menu--"Run"--type in "regedit".
  • b. Delete these registry keys as below manually:
    HKEY_CURRENT_USERSoftwareMicrosoftWindowsCurrentVersionRun
    HKEY_LOCAL_MACHINESOFTWAREMicrosoftWindowsCurrentVersionRun
list.jpgMethod 2. Fix rtl120.bpl error by Disabling Related Programs from Startup.
The DLL file would be infected by virus or Trojan. If the anti-virus program on your computer detects and deletes the infected file, you would probably receive error message alarming you that the DLL file cannot be found. You absolutely will fail to run the relevant application or program but keep receiving DLL error message on the startup. In such situation, you have to re-download and install the application to re-register the DLL information. Accordingly you have to disable an application run automatically on system startup in order to avoid such DLL error message:
  • a. Click "Start" menu--"Run"--type in "msconfig"---Start--- select the certain item to disable.
  • b. Reboot your computer.
Mar 21, 2012 | Toshiba Satellite L35-S2194...
We installed AVG 8.0 on the server of our small office network on Saturday 31/05/08. However we now have "Big Problems" trying to access our S6 system on E:\ drive. (Solution6 accounting and...
Did you try uninstalling the AVG?Next you can also try a system restore but make sure you take a backup of all your important data.Bcuz once you do a system restore then you'll loose all your data as it will be restored to an earlier time.
Goodluck..
Jun 02, 2008 | Computers & Internet
Is there anybody out there that can help me with this problem? I am unable to access Google Chrome. I keep on getting error signal 102, error connection refused. I checked my windows firewall and access...
If you have recently had a virus or malware attack, it has changed your proxy settings. Go to options>under the hood>change Proxy settings>LAN Settings and make sure of the following:
Automatically detect settings is CHECKED
Use a Proxy server for your LAN is UNCHECKED
If this doesn't fix it then the registry might have been affected, too. Perform a repair on your operating system or restore. I would recommend a factory restore after you have saved all important data on an external drive or flash.
Jan 15, 2011 | Google Chrome
I was on my husband's facebook but he didn't know I was on it and he tried to get on his. He got an error message HTTP 400. I got out of his facebook and tried to loggin on mine and got the same error...
The issue is broad and i need to check on your computer's settings. but that's impossible for me to do remotely so here are some of the common fix for the problem.
Do you have an antivirus software? If your PC is not well-protected, then all kinds of problems may occur - including HTTP 400 errors. If you run Windows, stay uptodate with automatic security updates from Microsoft and possibly consider getting a registry cleaner. Always have good anti-virus and spyware protection. Invest in a hardware firewall if you can afford one. Be sensible surfing the Web - block pop-up windows and avoid bad sites. If your PC security is compromised, then Web traffic out from your PC to the Internet may be secretly corrupted by malware (spyware, viruses, etc.) running on your PC. This can be difficult for you to detect.
You might accidentally installed an application from facebook apps like games, Some social networking and games sites ask you to download and run software on your PC so you can interact with other people on the Internet directly (without using your Web browser). This software, if badly written or even criminal, can corrupt all HTTP traffic from your PC. Getting rid of that defective software can be difficult. At worst you may have to reinstall your operating system again (possibly losing all your personal data on your PC if you do not have backup).
next, Try clearing your cookies, browser cache and browsing history in your Web browser. Disable or remove any third-party cacheing or 'web accelerator' software you installed. Then try rebooting your PC and any firewall/router you use to connect to the Internet. That may not fix the error, but at least may eliminate any problem due to old settings on your PC.
lastly, your option is to do a system restore. restore it prior to the time that the problem occur. to do that:
for Vista, click on start and go to start search, type in system restore. at the top it will show you system restore icon. click on it and do the restoration.
for XP, go to start, click on all programs, go to accessories, go to system tools and click on system restore..
hope this help.. please let me know if the issue is still there..
Sep 15, 2010 | Facebook Social Network
Dell XP restart problem
This error comes due to 1. RAM problem or 2.Hard disk problem or 3.Software/device driver problem or some times 4.Virus problem.
First you run the system in safe mode (pressing F8 at booting) - restore the system (start-programs - accessories - system tools - system restore). PC will be restarted and if it runs well then fine. If not again run in safe mode- uninstall few softwares or utilities, clear the temporary files, few drivers - restart the PC it may run well. If it does not run in safe mode the problem may be due to virus or critical RAM problem (main suspects, as the error may be for different reason). Now you format the hard disk and install your applications and drivers one by one and restart and check whether the problem repeats. Failure with the step you should change the RAM. With all failures - motherboard should be repaired and you have to give to the service center.
Jun 13, 2010 | Dell Inspiron 6400 Notebook
I'm encountering dll errors when I try to access Internet Explorer, even though I'm connected to the modem. How do I fix this?
Hello
Does Internet Explorer start or does it fail to load and displays the .dll error message?
Typically, .dll error messages are caused by 1. out of date Operating System, 2. viruses / spyware / malware on the computer that have over-written valid .dll files, 3. a failed program install
Since IE came with the OS, options 1 or 2 are more likely the cause of the problem. And, yes, you can still get viruses / spyware / malware while on a modem.
Make sure your antivirus is up to date and scan your hard drive for viruses (if you do not have an antivirus program - get one for free - search for AVG)
Make sure you have a spyware /malware detection program, update it and scan your system for spyware/malware (free from Microsoft - search for Windows Defender, other companies also offer free personal versions)
Very important - do both steps above, reboot and repeat 3 times. The computer holds the settings from the last 3 successful reboots, called Control Sets, in the Registry. Scanning the current Control Set only cleans it. It does not clean the other sets and viruses /spyware / malware can be re-introduced to your system if you perform a "Last Known Good" boot or use System Restore to restore your system to a previous date.
May 04, 2010 | Computers & Internet
Error code 5300:0119
Can you start it in safe mode? If so, try to do a system restore.
Next do a start>run>sfc/scannow to see if there are any system files messed up.
Can't start in safe mode? Then try to boot from the system disk and at the first prompt to do a repair type "R". Then run chkdsk /r to see if this solves the problem. This will fix bad files.
Still out of luck? Then you are looking probably in the right direction when you suspect the video card.
Feb 17, 2009 | Dell Inspiron 531s Desktop Computer
How do i get rid of a W32.SillyFDC virus
The following instructions pertain to all current and recent Symantec antivirus products, including the Symantec AntiVirus and Norton AntiVirus product lines.
  1. Disable System Restore (Windows Me/XP).
  2. Update the virus definitions.
  3. Run a full system scan.
  4. Delete any values added to the registry.
For specific details on each of these steps, read the following instructions.
1. To disable System Restore (Windows Me/XP)
If you are running Windows Me or Windows XP, we recommend that you temporarily turn off System Restore. Windows Me/XP uses this feature, which is enabled by default, to restore the files on your computer in case they become damaged. If a virus, worm, or Trojan infects a computer, System Restore may back up the virus, worm, or Trojan on the computer.
Windows prevents outside programs, including antivirus programs, from modifying System Restore. Therefore, antivirus programs or tools cannot remove threats in the System Restore folder. As a result, System Restore has the potential of restoring an infected file on your computer, even after you have cleaned the infected files from all the other locations.
Also, a virus scan may detect a threat in the System Restore folder even though you have removed the threat.
For instructions on how to turn off System Restore, read your Windows documentation, or one of the following articles:
Note: When you are completely finished with the removal procedure and are satisfied that the threat has been removed, reenable System Restore by following the instructions in the aforementioned documents.
For additional information, and an alternative to disabling Windows Me System Restore, see the Microsoft Knowledge Base article: Antivirus Tools Cannot Clean Infected Files in the _Restore Folder (Article ID: Q263455).
2. To update the virus definitions
Symantec Security Response fully tests all the virus definitions for quality assurance before they are posted to our servers. There are two ways to obtain the most recent virus definitions:
  • Running LiveUpdate, which is the easiest way to obtain virus definitions.
    If you use Norton AntiVirus 2006, Symantec AntiVirus Corporate Edition 10.0, or newer products, LiveUpdate definitions are updated daily. These products include newer technology.
    If you use Norton AntiVirus 2005, Symantec AntiVirus Corporate Edition 9.0, or earlier products, LiveUpdate definitions are updated weekly. The exception is major outbreaks, when definitions are updated more often.
  • Downloading the definitions using the Intelligent Updater: The Intelligent Updater virus definitions are posted daily. You should download the definitions from the Symantec Security Response Web site and manually install them.
The latest Intelligent Updater virus definitions can be obtained here: Intelligent Updater virus definitions. For detailed instructions read the document: How to update virus definition files using the Intelligent Updater.
3. To run a full system scan
  1. Start your Symantec antivirus program and make sure that it is configured to scan all the files.
    For Norton AntiVirus consumer products: Read the document: How to configure Norton AntiVirus to scan all files.
    For Symantec AntiVirus Enterprise products: Read the document: How to verify that a Symantec Corporate antivirus product is set to scan all files.
  2. Run a full system scan.
  3. If any files are detected, follow the instructions displayed by your antivirus program.
  4. Delete the autorun.inf file from writeable removable devices, if necessary.
Important: If you are unable to start your Symantec antivirus product or the product reports that it cannot delete a detected file, you may need to stop the risk from running in order to remove it. To do this, run the scan in Safe mode. For instructions, read the document, How to start the computer in Safe Mode. Once you have restarted in Safe mode, run the scan again.
After the files are deleted, restart the computer in Normal mode and proceed with the next section.
Warning messages may be displayed when the computer is restarted, since the threat may not be fully removed at this point. You can ignore these messages and click OK. These messages will not appear when the computer is restarted after the removal instructions have been fully completed. The messages displayed may be similar to the following:
Title: [FILE PATH]
Message body: Windows cannot find [FILE NAME]. Make sure you typed the name correctly, and then try again. To search for a file, click the Start button, and then click Search.
4. To delete the value from the registry
Important: Symantec strongly recommends that you back up the registry before making any changes to it. Incorrect changes to the registry can result in permanent data loss or corrupted files. Modify the specified subkeys only. For instructions refer to the document: How to make a backup of the Windows registry.
  1. Click Start > Run.
  2. Type regedit
  3. Click OK.
    Note: If the registry editor fails to open the threat may have modified the registry to prevent access to the registry editor. Security Response has developed a tool to resolve this problem. Download and run this tool, and then continue with the removal.
  4. Navigate to the following registry subkeys:
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run
    HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Shell Folders
    HKEY_CURRENT_USER\Software\Microsoft\Windows NT\CurrentVersion\Windows\"load"
  5. In the right pane, delete any values associated with the worm.
  6. Exit the Registry Editor.
Dec 18, 2008 | Microsoft Computers & Internet
Task manager
If you are certain that you are logged on as administrator or has administrator privileges, then a virus is preventing your opening of the Task Manager. Additionally, the same virus is likewise preventing access to the Folder Option and the MSCONFIG function.
Of course the correct solution would be to run a full deep virus scan and delete detected ones. You can also try running RRT.exe to force access to the above functions.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 29, 2008 | Microsoft Windows XP Professional
Systemax (036052) PC Desktop Logo
89 people viewed this question
Top Systemax Computers & Internet Experts
pankaj rautela
pankaj rautela
Abhinandan  Patil
Abhinandan Patil
Mike
Are you a Systemax Computer and Internet Expert? Answer questions, earn points and help others
