Question about Janome 8080 Computerized Sewing Machine
Thread getting caught
Sometimes the thread in my machine gets caught coming from the top spool. It is stuck so fast that the needle bends or it sometimes breaks regardless of the thread I use. I've take it apart and cleaned it but I'm not sure exactly where it is catching.
    Genius:
  • 1,074 Answers
Make checks on the bobbin case that holds the bobbin beneath the machine it could be broken or too tight then you need to slacken it a bit so that thread can flow easy there after oil your oil the machine if the bobbin case lever is broken or bent replace it.also adjust tension disc.good luck.
Posted on Mar 26, 2007
SOURCE:
Please help! I have a Brother Innovis 4000 embroidery machine. My machine is skipping stitches then the needle falls out or bends/breaks. This happens even after I changed the needle and rethread the...
I would double check your Threading. Make sure the thread coming from the spool is not getting caught on something. Try keeping the presser foot up, and then pull out some thread from the back of the needle, does it seem tight to pull? Now lower the presser foot, is it more difficult to pull out? It should be but not so much that it is bending the needle.
If it is to tight, there could thread caught in the tension discs. Remove the left side panel above the needle on the machine. Check to see if you can see any threads. IF not, lower the thread tension and see if that helps. Good luck
Apr 24, 2014 | Brother XL-3500
Thread breaking, not even threaded in needle anymore, thread gets caught on spool sometimes
Upper thread breaks
1.the needle may be bent or damaged--try rolling the needle on a flat surface to see if it's bent or not
Or the needle could be in backwards
Correct needle insertion
Correct needle insertion is mandatory for proper use of sewing machine.
Raise the needle bar to the highest point, then loosen the clamp screw to remove the old needle, place the new needle in the clamp with the flat side to the back of the machine or if using a round needle--the groove in the needle should face away from the shaft.
Push the needle all the way up to the stop or as far as it will go, then tighten the needle clamp screw
2.upper tension may be to tight--try 3 to 5
3.thread may be hanging up in bobbin case--check area for loose threads or lint
Lower thread breaks
The most probable cause of lower thread breaking is improperly wound bobbin
1.always start with a empty bobbin
Never wind one color over the other
2.choose thread that is identical in color & type as the one to be used for upper threading
3.wind the bobbin evenly across & in layers
4.don't wind the bobbin so full that it would be tight & hard to insert into bobbin case
5.bent bobbin--replace
6.lint built up in the bobbin case--frequent cleanings will eliminate this problem, the more often you use the sewing machine the more often it needs to be cleaned
7.thread catching on the bobbin spring or latch on bobbin case, check to see that the bobbin is inserted completely & correctly, & that you are using the right kind of bobbin
for the top & bobbin thread keep thread tails of 3 to 6 inches long pulled behind the needle before you start sewing
yes,sometimes the thread will get caught on the spool, you might think about getting a extra holder that sets behind the machine to hold those spool's that the thread get caught on, that's what I did.
Sep 15, 2011 | Brother PE770 Computerized Sewing Machine
When I thread my machine and try to sew, the stitches don't hold or it all gets tangled! The thread won't stay in the needle. And the bobbin angles up sometimes. I'm new to sewing, never have before. I'm...
check the needle to see if it's damaged-roll on flat surface to see if it roll correctly
always make sure to have a 3-5 inch thread tail for top thread & bobbin
if the bobbin angles up at times, it could be getting low on thread-on my electronic sewing machine it does that
sometime the thread & needle are not compatable
here's how to tell
Cut 6-8 inch piece of thread of the spool you are going to use for your project
Take the needle you are going to use for the project
& insert the thread thru the eye of the needle
& lift one end of the thread to a 45 degree angle
& if the needle is the right size for the thread it will slide down the thread
But if the needle hangs on the thread you need one size larger needle for the thread
sometimes when sewing the thread can get caught different places
1.spool pin
2.notch on spool of thread
let me know if this help you
Oct 01, 2010 | Sewing Machines
Why does my thread keep breaking and why wont the sewing machine stich?
sometimes the thread can get caught on the spool pin
or on the notch on the thread spool itself
on some machines the thread can come off the thread take up lever
it can also get caught in the top tension area
also check your needle to see if it's bent--roll on flat surface to see if it rolls correctly
there are 3 types of bad needles-bent
blunt--makes a popping sound when going thru fabric
damaged--broke tip
also check your bobbin area for lint or loose threads
check your bobbin to see if it's warped--I've come across some that were warped
check your top thread tension
Sep 24, 2010 | White Sewing 2200 Multi-Tasker
Why does the thread keep breaking?
check the needle to see if it's bent-roll on flat surface to see if it rolls correctly
thread tension maybe to tight-select lower number
1.spool pin
2.the notch on the thread spool itself
some times the thread will come off the thread take up lever
Sep 22, 2010 | Necchi 4595 Mechanical Sewing Machine
Thread bunches up in the bobbin area and needle appears to be stuck and won't move. Almost like the thread wont come off the spool.
Check to see if the thread coming off the spool is tangling on the spool pin or getting caught in the crack on the spool top where the thread originally comes off spool. Make sure the spool pin is pushed all the way to the right to secure your thread and then back it off slightly so the thread pulls evenly off the spool. Whenever your bobbin thread gets bunched it is usually something is wrong with the threading of the UPPER thread and vice versa. Let me know if this solves your problem.
Aug 23, 2010 | Brother XL-5500 Mechanical Sewing Machine
I have a Necchi 537FA sewing machine. It sill sew about 39 stitches and then the thread gets caught in the bobbin area and stope sewing. I've cleaned, changed bobbins, spent time trying to fix the...
have you checked to see if the needle is bent-lay the needle on a flat surface & roll the needle over,, if the needle does not roll good -replace
blunt needle-if the needle makes a popping sound when the needle penetrates the fabric,,the needle is blunt-replace
sometimes if the thread comes off the thread take-up lever it can jam the thread in the bobbin area
try rethreading the machine
check to make sure the thread isn't wrapping around the spool pin
check the spool of thread to see if the notch on the spool is catching the top thread
check to see if there's a burr on the bobbin case
I hope one of these suggestions helps you
please rate this using the thumbs in upper right hand corner
Aug 12, 2010 | Necchi 3537 Mechanical Sewing Machine
Machine is noisy; top thread breaks, even though needle has been changed out (it seems the thread gets caught on something inside the top)
check to make sure the thread is not winding around the spool pin
also check & see if it's getting caught on the notch on the thread spool
the thread could be coming of the thread take up lever
Aug 10, 2010 | Elna Quilter's Dream 6003Q
My machine has just started having a problem where the top thread is getting caught on the bobbin instead of clearing around it. This means I end up with many threads coming up from around the bobbin....
check to see if your needle is bent-roll it on a flat surface to see that it roll good
check to make sure the thread is not coming off the thread take up lever
check in the bobbin area for lint or loose threads
check to make sure the thread is not getting caught on the spool, sometimes the notch on the spool can catch the thread
Aug 10, 2010 | Husqvarna Sewing Machines
Needle keeps breaking when embroidery unit is attached
Make sure the top thread is not catching and causing the breakage.
Sometimes the thread unwinds too fast and catches on the spool pin and sometimes there is a rough spot on the thread spool that catches the thread.
Thread nets will help eliminate the fast unwind (pooling) - you can find them at sewing machine dealers.
If the thread spool has a rough notch that is catching the thread, smooth it with an emery board or turn the spool so the thread feeds from the opposite end.
Mar 17, 2010 | Singer CE-100 Futura Computerized Sewing...
Janome 8080 Computerized Sewing Machine Logo
136 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
