Computers & Internet Logo
bien moncada Posted on Aug 10, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
3/4 is equal to how many 84ths? - MathRescue Word Problems Of Algebra Lite
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 16, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
755
Points
84/4=21
3/4 divided by 21 is 28.
Is this right?
k24674
Level 3:
  • MathRescue Master 8,093 Answers
  • Posted on Aug 11, 2012
k24674
MathRescue Master
Level 3:
Answers
8093
Questions
0
Helped
4675201
Points
21596
84/4=21
3/4=(3x21)/(4x21)=63/84
Bose 901 equalizer connect to Lafayette 3500 receiver using bose 901 speakers
The Bose 901 speakers require the use of a specific equalizer that is designed to optimize their performance. If you have a Bose 901 equalizer, you will need to connect it to your Lafayette 3500 receiver in order to properly use the speakers.
Here are the general steps for connecting the Bose 901 equalizer to your Lafayette 3500 receiver:
  1. First, ensure that the power is turned off on both the receiver and the equalizer.
  2. Locate the preamp output jacks on your Lafayette 3500 receiver. These will typically be labeled as "pre out" or "line out".
  3. Connect a pair of RCA cables from the preamp output jacks on your receiver to the input jacks on your Bose 901 equalizer. These jacks are typically labeled as "preamp in" or "line in".
  4. Next, connect another pair of RCA cables from the output jacks on your Bose 901 equalizer to the main amplifier input jacks on your receiver. These jacks are typically labeled as "main in".
  5. Turn on your receiver and equalizer, and ensure that the volume levels are set to a low level before playing any music.
  6. Set the Bose 901 equalizer to the "On" position, and adjust the various equalizer controls to your preferred settings.
  7. Finally, play some music and adjust the volume levels as needed. You should notice a significant improvement in the sound quality of your Bose 901 speakers with the equalizer properly connected.
Note: It's important to use the Bose 901 equalizer specifically designed for the speakers. Using a different equalizer or not using any equalizer at all may result in poor sound quality or damage to the speakers.
How cani i solve "x divided by 9 and x divided by 9 equals 4
x divided by 9 and 9 divided by 9 equals 4, so x divided by 9 equals half of 4 or 2. 2 times 9 equals 18, so x equals 18.
To check, 18 divided by 9 equals 2. 2 and 2 equals 4.
2answers
WHAT IS THE DIFFERENCE BETWEEN MG AND ML
A Milligram is MG and a Milliliter is a ML. (MG) is used in dry measure and (ML) is used in liquid measure
1000 micrograms (mcg) EQUALS 1 milligram (mg)
1000 milligrams (mg) EQUALS 1 gram (g)
1000 grams (g) EQUALS 1 kilogram (kg)
1 kilogram (kg) EQUALS 2.2046 pounds
1 ounce EQUALS 28.35 grams
1 pound EQUALS 0.4536 kilograms
1 pound EQUALS 16 ounces
16 ounces EQUALS 453.6 grams
1000 milliliters (mL) EQUALS 1 liter (L)
1 liter (L) EQUALS 1.0567 quarts liquid
1 quart liquid EQUALS 0.9463 liter
4 quarts EQUALS 1 gallon
1helpful
There is a series: 8,6,17,35,30,71,_,143 what will be the number in the blank space?
8 plus (-2) equals 6
6 plus 11 equals 17
17 plus 18 equals 35
35 plus (-5) equals 30
30 plus 41 equals 71
71 plus X equals Y
Y plus Z equals 143
Not much of a pattern in the "differences".
8, 17, 30, X
6, 35, 71, 143
No pattern there.
8, 6, 17
35, 30, 71
X, 143, Y
8 + 6 + (3) = 17
35 + 30 + (6) = 71
No pattern there.
2helpful
I need a hook up digram fof an optimus model 31-2025 stereo equalizer
http://support.radioshack.com/support_audio/doc48/48943.htm
Ten-Band Stereo Frequency
Equalizer (310-2025) Connections Faxback Doc. # 48943
Follow these steps to connect the equalizer to your audio system.
CAUTIONS: Use only shielded audio cable with RCA-type connectors (not
supplied). This type of cable is available at your local
RadioShack store.
Before you connect the equalizer, turn off all components in
your audio system and unplug their power cords.
Before you plug in the equalizer's power cord, complete all
connections and be sure the equalizer's POWER button is out.
1. To connect the equalizer to your receiver, connect the receiver's TAPE
OUT jacks to the equalizer's MAIN IN jacks.
Then, connect the equalizer's MAIN OUT jacks to your receiver's TAPE
IN or TAPE MONITOR jacks.
2. You can connect a tape deck to each set of tape jacks (TAPE 1 and TAPE
2) on the back of the equalizer.
To connect each tape deck, connect the equalizer's TAPE OUT jacks to
the tape deck's in jacks. Then, connect the tape deck's out jacks to
the equalizer's TAPE IN jacks.
3. Plug the equalizer's power cord into your receiver's switched power
outlet or any standard AC outlet.
WARNING: The equalizer's power cord has a polarized plug. To prevent
electric shock, do not use an extension cord or other
receptacle unless you can fully and easily insert the plug's
blades.
4. Connect the power cords of all other components.
(wr 08/04/98)
1helpful
Gemini Sound Products EQ-3000 equalizer
please connect as the following-----1-mp3 out-----to cd in in your receiver.
2-receiver rec out (tape put)----to equalizer in.
3-equalizer out----to tape in in receiver.
2helpful
2answers
How do i conect equalizer
first connect pre-amp out to equalizer in and equalizer out to amplifier in-and amplifier to loudspeaker.
second-mixer out to equalizer in and equalizer out to amplifier in and amplifier out to speaker.
2answers
Bose 901 equalizer hookup
media out(dvd-cd) to equalizer in ------equalizer out-------to aux in or line in in receiver.
Installing pyramid 795cd equalizer
cd player or dvd player output------------to equalizer input---------equalizer output---------amplifier input--------amplifier output ----------to speakers
Top MathRescue Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a MathRescue Computer and Internet Expert? Answer questions, earn points and help others
