Question about Motorola Mobility RAZR V3
Dropped phone...it no longer works
Dropped my Razr..the phone went dead...it didn't drop far or hit hard....I plugged fone into my charger..and its says battery is charging with a big exclamation point...but I should be able to use the fone while its charging and I can't!! Whats going on??
  • 62 Answers
Well when its turned off it does that so see if you can turn it on. if not you'll need to open it up and check the connectors or your battery.
Posted on Mar 28, 2007
Ezip
The light came on because the charger brought voltage up to full, but when you hit the throttle, the voltage dropped since the charger cant power the motor. While checking the wiring (which I assume people automatically do), bypass the power switch with a screwdriver or a jumper wire. If it works, replace the switch. Check the battery with a multimeter...you should get > 25.2v full charge, no load. If you get 0v, check the fuse in the battery case. If all of the above check out ok, and it's totally dead, you probably need a controller.
May 28, 2013 | Currie Technologies eZip Mens Trailz...
Red screen of death
try to, borrow your friends batt and try, and if it's not working,, then here's what they gotta do put the cables in your fone and flash your fone with firmware and it will go back all to normal.. only prof's can do it, bring it to the center
May 10, 2008 | Motorola Mobility RAZR V3
Dropped it and screen went blank
take the phone and have them replaced the lcd or flexcable
Aug 26, 2007 | Motorola Mobility RAZR V3
Blank Screen
Sounds like the charger's defective. Did it get dropped accidentally? Take both the phone and the charger back where you got it. They should fix the problem for you. Battery in the phone is probably dead and just needs charging.
Aug 19, 2007 | Motorola Mobility RAZR V3
Dead phone but keypad flashes
replace the LCD + flexcable on the phone.
Aug 02, 2007 | Motorola Mobility RAZR V3
V3 Razr is dead, wont charge
take it to a local cell phone dealer and see what they say. most likley bad charger or bad connections.
Jul 08, 2007 | Motorola Mobility RAZR V3
Dropped fone in toilet
Hi, You can purchase a spray called electric cleaner that cleans small electric components and dries very quickly. But you will have to open the phone and spray on the small circuit board inside. If it still doesn't come up after that then it might possibly be dead. Sorry and good luck Lolita
Jun 09, 2007 | Motorola Mobility RAZR V3
MOTOROLA RAZR V3
man... it's a software and hardware problem... go to your nearest cervice center and they will fix it up.... 1st your problem is they have to check your firmware . but what i'm sure of is,, your going to change the flex, it's the ribbon part of your fone connected to the main board to lcd......tnx man...
Jan 06, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
54 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
