Question about KitchenAid KHMS155LSS 1000 Watts Microwave Oven
Do you have an diagram of a kitchen aid microwave?
  • KitchenAid Master
  • 9,098 Answers
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
Posted on Dec 17, 2008
Mod.KHMS155LSS-1 Getting F-6 Fault code ????
Search Results
    Combination Microwave Wall Oven - Error Code/Message ...
    www.kitchenaid.com/...microwave...error-code...f6-error-cod...
    KitchenAidQuestion: Combination Microwave Wall Oven - Error Code/Message - F6 Error Code -F6 E8. Answer. Product Symptom: Combination Microwave Wall Oven ...
    Over-the-Range Microwave - Error Code - Starts with F ...
    www.kitchenaid.com/...microwave-error-code...f...f6...code/P...
    KitchenAidKitchenAid's product help articles give answers to your frequently asked questions (FAQs). ... Microwave - Error Code - Starts with F - Starts with F6 - F6E0 Code.
    Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kitchen Aid Model # KEMS308SSS02 and I getting the follow error message... is working and was always working but the top microwave/oven does not work. ...Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost Err/ F6 E0/ ... Most "F6/E0" fault codes is usually because of a loose wire connections, loss of ...
Feb 05, 2016 | KitchenAid Microwave Ovens
Error code F2
Per the tech sheets (page 8), "F2" error code means "Keyboard failure". Recommended by the manufacturer to replace the touch panel first and, if it would not solve the problem, then the control board has to be replaced too. Not the best recommendation but we have to follow it.
- The part number for the touch panel (aka a membrane switch) is AP3130765
- The part number for the control board AP3130764
Here are the break down diagrams for the Kitchen Aid microwave Model KHMS155LSS4
Gene.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
Read more: http://forum.appliancepartspros.com/microwave-repair/19054-kitchen-aid-microwave-error-code-f2.html#ixzz3bRus7JKM
May 28, 2015 | Microwave Ovens
Error code : Door
There will be a technical sheet hidden behind the controls which will help you locate major components.
The marked diagram below shows you the various parts that can fail and what effect will result.
You can find helpful exploded view diagrams and order parts by part number here.
Check the two fuses first, then if you have to check the cavity TCO, you will likely need to remove the oven from the wall.
If for some reason you don't still have your installation instructions, you can get them - and the parts list - here.
Dec 01, 2013 | Microwave Ovens
Microwave - Kitchen Aid KHHS179LSS4 ERROR CODE -
Hello there Jerry
Sorry it took so long getting back to you i just finished moving into my new home and just got my internet today ok ill send you a troubleshooting steps
However this error code usually turn out to be a problem with the controle panel of the microwave and the only fix for these is to replace the part ok i will post the rest of the troubleshooting steps in a following comment ok
Best regards Mike
Jan 23, 2012 | Microwave Ovens
Need help with changing a magnetron for a built in microwave, Kitchen aid
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Nov 21, 2010 | Microwave Ovens
I'm looking for repair manual for range made by Kitchen Aid
web search-kitchen aid range manuals- or -kitchen.manualsonline.com
Oct 15, 2010 | Microwave Ovens
How do i replace the magnatron on a kitchen aid khms147kss
You would need to remove it from the wall, using the installation instructions here, review the safety information here, then remove the outer cover and discharge the high voltage capacitor.
Then you can swap the magnetron.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
May 05, 2010 | KitchenAid KHMS147 Microwave Oven
Burned out bulb on Kitchen Aid Microwave Model KBMC140
You will need to remove the oven from the wall and remove the outer cover.
If for some reason you don't have yours, you can download your owner's manual and installation instructions free from this page.
You can also find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
These models use halogen lamps. You must not touch halogen types with your bare skin, as the oils will shorten the bulb life.
You should be able to get one from a home center or local appliance parts store.
If you order it online (from the link above) it is part # 4375348.
Aug 04, 2009 | KitchenAid KBMC140HSS Convection/Microwave...
KitchenAid KHMS155LSS 1000 Watts Microwave Oven Logo
69 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
