Question about Sony VAIO PCV-RZ40C1B PC Desktop
My Vaio has a129 D drive but only a 13m C drive. Despite moving everything I can to the D drive I am now down to 2.5 mg on the C drive. Why did they build them this way? How do I either enlarge the C drive or move everthing to the D drive? Thanks Tom
  • 113 Answers
Here is what you can do... 1. Copy all crucial data to any external drive, if you have one. Make the partitions again and reload everything. OR 2. We have utilities like Partition Magic, which help you change your partitions, like you can increase the disk space available. good luck
Posted on Mar 26, 2007
Accelerates/passes very slowly as trans refuses to downshift when in Drive.
I would be looking for a vacuum operated actuator that down shifts when the accelerator is wide open
could be a failing TCM so have the fault codes read first to get an idea of the problem area
Nov 12, 2015 | Cars & Trucks
Sony Vaio VGN-SZ18GP Windows 7 shutdown problem .... when I shut down .... it gets stuck on the screen of shutdown but the "loading circle" is still running
This can be a sign of a memory failure, either the RAM is not clearing or the hard drive is on its' way out. Hold the power button down for 6 seconds for a "hard shutdown". Then restart and see if the problem persists.
Oct 13, 2013 | Sony VAIO VGN-SZ18GP/C, VAIO VGN-SZ420NB,...
When i drive my mg zs 120 the heaters blow cold air is this a problem my thermostat could cause
if the coolnt level is ok try bleeding the system little 8mm bleed screw on coolant rail check the water valve is open and moves when the temp control is rotated i think your problem is the little valve located in the heaterhose at the back of the engine you will need a new hose
Mar 13, 2013 | MG ZS Cars & Trucks
My Satellite Pro S200 running XP has a 30gb C drive and 100gb D drive. The computer constantly whines that is low on C drive space. I have moved everything possible to D drive, cleared 2.8gb space a few...
windows - start - control panel - administration - computer administration - hard drive administration - resize your C drive to bigger capacity, but first resize D drive to smaller capacity to free a space for C drive enlarge, then apply setting, reboot, my computer drive C right click - propertis- service - defragmentation and same operation and chek it for errors
Nov 15, 2012 | Toshiba Satellite Pro P300-28L 17-Inch...
I have a 30ltr TDI quattro that smokes when it idles for than a few minutes
This car doesn't have coils and wires, it's gasoil. The most likely reason is the piezo injectors are worn. The best way to test is with VCDS
After an overnight stationary period drive the vehicle with cold engine between 1200 - 1600 rpm till the complaint occurs. Constantly read the measured value block 13 and 14 for the smooth running control in the engine control unit. The values of one or several cylinders should noticeably move to positive.
modified injectors A8: with 3.0l, 4.2l TDI from: WAUZZZ4E*7N016685
Replace the injector with the highest deviation and all injectors produced between 1.3.2006 and 30.4.2006.
Example of production date: 060304 stands for 4.3.2006
vcds go to address 01 measured values below
013 Smooth running control1)Cyl. 1 Injection quantity variation[mg/stroke]2)Cyl. 2 Injection quantity variation[mg/stroke]3)Cyl. 3 Injection quantity variation[mg/stroke]4) VacantPermissible values at idle: +- 2,99 mg/strokeA If the permissible tolerance is exceededfirst check injector IQA-IVA adaption values
014 Smooth running control1)Cyl. 4 Injection quantity variation[mg/stroke]2)Cyl. 5 Injection quantity variation[mg/stroke]3)Cyl. 6 Injection quantity variation[mg/stroke]4) VacantPermissible values at idle: +- 2,99 mg/strokeA If the permissible tolerance is exceededfirst check injector IQA-IVA adaption values
Jun 28, 2012 | 2006 Audi A6 3.0
I have a sony vaio pcg. it powers on and does nothing else. the 2 little cooling fans come on but the hard drive doesn't run and screen won't come on. can anyone help me out. thanks
Its possible that you already have a bad hard drive. It may have crashed. Your system will not boot without the hard drive running. The computer will keep on trying to look for the Hard drive that's probably why it looks like its doing nothing. Bring your machine to sony and have them fix it. If you know how to open up your Vaio, try to check the Hard drive connection and see it its loose, if its not loose. its time to replace the hard drive.
I hope this helps. Thanks and have a nice day.
- HotRatchet
Dec 14, 2009 | Sony VAIO PCG-K35 Notebook
Sony Vaio VGN-FS980 is slow
Aside from hardware many things can slow up your PC:
  • If the C: drive is too full Windows is unable to allocate a proper virtual memory cache on the drive.
  • Your chosen anti-virus solution can even slow certain machines down (post what your running)
  • A high % of the time it is spyware/malware related
Just to make sure the machine is completely malware free you should download and run this program.
Feb 25, 2009 | Sony VAIO VGN-FS980 Notebook
Hi I have a Sony Vaio VGN-S1HP (model PCG-6C1M). It is too slow and running out of hard drive space. I would like to know if I can upgrade the processing power and also increase the hard drive from 40g to...
Well I would recommend upgrading your RAM to 2 GB (Your standard model comes with 1/4 of that) and a 250 GB drive. The RAM would cost you about $80 in parts and perhaps $30 labour and the hard drive should be about $60 in parts and $20 labour. I don't recommend upgrading processors as it can cause warranty problems down the road.
Oct 14, 2008 | Computers & Internet
Sony VAIO PCV-RZ40C1B PC Desktop Logo
46 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
