Question about Health & Beauty
My 5 lb spring scale is broken
I have a kubota 5lb spring scale with a flat circular top that is removable after my 4 year old played with it...it no longer goes down to register weight. I opened it up and it seems there is little to no parts on this scale so if I saw a design of how works I would know where the parts are suppose to be and how they are hooked up. Any idea how I can see the designs inside? Thanks
SOURCE: Tanita, the Ultimate Scale
The scale may have instructions on the bottom of the scale. (Example for the Tanita: The Ultimate Scale w/ the body fat analysis). The instructions on the back state the following steps: Step 1: press both the "Set" and the triangle buttons. Step 2: press the "triangle" button until you select the appropriate weight measurement (a) kilogram, (b) stone lbs or (c) lbs. Step 3: press the set button.
Posted on Nov 20, 2008
ptooshar
  • 19 Answers
SOURCE: scale appears to be inaccurate
this type of less resoluted scale hasn't repeatability. if you wish to repair it, change the loadcell. use 2 x scale capacity of load cell.
Posted on Dec 02, 2008
SOURCE: Conair WW41 Scale
To totally reset the scale and remove any old data in the users take battery out for 2 hours.
To use the USER functions:
Tap scale to turn it on
When you see "0.0" press
Press SET button. "P-1" will appear and blink
Use UP/DOWN button to select a user number
once desired user number (1-4) appears press SET button to confirm
when 0.0 appears step on scale this will enter your starting weight
press SET to confirm
scale automatically sets a goal weight of 10% below starting. you can raise or lower it by using arrow buttons-Press SET to confirm
Tracking weight
tap, see 0, select user number. Scale displays start weight, then goal weight then 0.0 and you weigh yourself. In the smaller windows it will display last weight and the difference between current and last weight then diff between current and start then diff between current and goal
Posted on Dec 04, 2008
  • 215 Answers
SOURCE: Paper tray not lifting the paper up for the initial paper feeder
most common problem on these is the rear paper stop pressing too hard against the rear of paper causing paper not to lift. make sure you have about an 1/8" gap.
good luck,
razors
Posted on Jan 09, 2009
fitnessbalan
  • 59 Answers
SOURCE: I have a Tanita scale. It will not register weight.
Sounds like somehow it was calibrated to your weight as zero instead of 0. I would contact manufacturer here is the contact info.
http://www.tanita.com/en/contact-us/
Posted on Mar 16, 2009
How do I clear the 'L' error on my bathroom Salter scale. I have changed the battery but I cannot get the error to clear.
new batteries? or one's that have been sitting around.
they may be low.
what they say to do...
1.
Open the battery compartment on the scale underside.
2.
Remove isolating tab from beneath the battery (if fitted) or insert batteries OBSERVING the polarity signs (+ and -) inside the battery compartment.
3.Close the battery compartment.
4. Select kg, st or lb weight mode by the switch on the
underside of the scale.
5.For use on carpet attach enclosed carpet feet.
6.Position scale on a firm flat surface. next......
INITIALISING YOUR SCALE
1. Press the platform centre and remove your foot.
2.'0.0' will be displayed.
3.The scale will switch off and is now ready for use.
This initialisation process MUST be repeated if the scale is moved. ie battery replacement.
Feb 14, 2018 | Salter Health & Beauty
Cubic feet for maytag model number washer sav571eeww
washing machines are rated in pounds of wash and not cubic ft
it is rated as either 4lb, 5lb, 5.5 lb 6 lb 7 lb 7.5lb
the size will be on the same decal as the model number and power details
Jan 22, 2016 | Maytag Washing Machines
Is there a way to calibrate without 3-50 pound weights?
water weighs 10lb to the gallon ( engilish measurement-calculate amount for us gallon)
so get your self a jug and place it on the scales empty adjust the scales to zero
fill the jug with a measured amount of water (example 1 pint will weigh 1.25lbs
then set the scales to the reading of 1.25lbs
to check the scales accuracy you can add extra water to the jug (say 4 pints ) and the scale should read 5lb
Jul 25, 2015 | Office Equipment & Supplies
15 yr old admiral 20 lb. (I think it is model 35-4119 ) walks
You gonna have to remove the front and look for a broken spring, If the springs are all there then the snubber pad probably needs replacing.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 05, 2010 | Washing Machines
How to calibrate a Pelouze model 4010 scale with a
when i turn on my 4010.the screen display shows 4010 but thats all it does.any solution.
Jul 08, 2009 | RTO Pelouze Scale With Remote Display -...
Tanita BD-590 calibration
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
May 11, 2009 | Tanita BD-590 Digital Baby Scale, 40 lb x...
Removed old strut last night Today can't get new
Installation
  1. sww~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: The bearing and seal assembly is press-fit onto the upper mount. The mount washers must be installed in the correct orientation.
    NOTE: Be sure to check the spring insulator for damage before assembly. If the outer metal splash shield is bent or damaged, it must be carefully bent back, so it does not touch the locator on the bearing and seal assembly.
    NOTE: New gas struts are shipped with the rod in a locked down position. To extend the new strut, remove the external tie down and/or rotate the upper end of the rod, counterclockwise.
    Install the coil spring insulator, coil spring, and upper mounting parts to the new strut assembly. Make sure the spring is correctly seated in both spring seats.
Item Part Number Description 1 — Dust Boot (Part of 18045) 2 N803826-S100 Front Shock Absorber Mounting Bracket Nut
(3 Req'd) 3 N803952-S100 Washer 4 N808625-S100 Front Shock Absorber Nut 5 18183 Front Shock Absorber Mounting Bracket 6 3B455 Front Suspension Bearing and Seal 7 5310 Front Coil Spring 8 5414 Front Spring Insulator 9 18045 Front Shock Absorber A — Tighten to 35-40 Nm
(25-30 Lb-Ft) B — Tighten to 55-63 Nm
(40-46 Lb-Ft)
  1. sww~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not over tighten the lock nut; damage to the lock nut or piston rod could result.
    Install new rod lock nut and tighten it to 55-63 Nm (40-46 lb-ft).
  1. Remove the spring compressing tool.
  1. Position the strut assembly into the vehicle. Install the three mount-to-strut tower nuts. Tighten the nuts to 35-40 Nm (25-30 lb-ft).
  1. Partially raise the hoist.
  1. Position the strut assembly to the steering knuckle. Install the pinch bolt and tighten it to 115-132 Nm (85-97 lb-ft).
  1. Position the stabilizer link to the strut assembly and install the retaining nut. Tighten the nut to 90-100 Nm (66-74 lb-ft).
  1. Install the front wheel and tire assembly.
  1. Lower the vehicle.
May 01, 2009 | 1998 Ford Windstar
2004 Ford Explorer front shocks are worn out
Remove the front wheel.
Locate and remove the 3 nuts on the upper frame mount,top of the shock.(torque 20 ft lb)
Remove the nut on the sway bar link.(torque 18 ft lb)
Remove the lower bolt that goes thru lower control arm and shock.(torque 258 ft lb)
Then use a spring compressor to compress spring and remove the nut on the spring plate.(41 ft lb)
Apr 15, 2009 | 2004 Ford Explorer
I need step by step instructions to replace front struts.
1.Turn ignition to OFF position to place steering column in unlocked position.
2.Remove hub nut
3.Loosen, but do not remove, three top mount-to-shock tower
4.Raise vehicle on a hoist.
5.Remove tire and wheel assembly
6.Move brake caliper and wire out of the way
7.Remove brake rotor
8.Remove cotter pin from tie rod end stud and remove slotted nut.
Discard cotter pin and nut
9.remove tie rod from knuckle
10.Remove stabilizer bar link nut, and remove link from strut
11.Remove and discard lower arm-to-steering knuckle pinch bolt and nut. (A drift punch may be used to remove bolt.) Using a screwdriver, slightly spread knuckle-to-lower arm pinch joint and remove lower arm from steering knuckle.
12.Press halfshaft from hub
13.Remove shock absorber strut-to-steering knuckle pinch bolt. Using a large screwdriver, slightly spread knuckle-to-strut pinch joint, if required, for removal
14.Remove steering knuckle and hub assembly from shock absorber strut
15.Remove three top mount-to-shock tower nuts and remove strut and spring assembly from vehicle
16.Compress spring with Spring Compressor
17.Place 10mm box-end wrench on top of shock strut shaft and hold while removing top shaft retaining nut with a 21mm 6-point crow foot wrench and ratchet
18.Loosen Spring Compressor , then remove top mount bracket assembly, bearing plate assembly and spring.
INSTALLATION
1.Place a 10mm box-end wrench on top of shock strut shaft and hold while tightening top shaft retaining nut with a 21mm 6-point crow foot wrench and ratchet to 53-72 Nm (40-53 lb-ft).
2.Install strut and spring assembly and three top mount-to-shock tower nuts
3.Install steering knuckle and hub assembly to shock absorber strut.
4.Install a new shock absorber strut-to-steering knuckle pinch bolt. Tighten to 98-132 Nm (73-97 lb-ft).
5.Install halfshaft into hub
6.Install lower arm to steering knuckle ensuring that ball stud groove is properly positioned and boot seal is not damaged. Install a new pinch bolt and nut. Tighten to 53-72 Nm (40-53 lb-ft).
7.Install stabilizer bar link to strut and install a new stabilizer bar link nut. Tighten to 77-103 Nm (57-75 lb-ft).
8.Install tie rod end onto knuckle.
9.Install a new tie rod end slotted nut. Tighten to 31-47Nm (23-34 lb-ft).
10.Install a new slotted nut retaining cotter pin.
11.Install brake rotor
12.Install brake caliper
13.Install tire and wheel assembly
14.Tighten three top mount-to-shock tower nuts to 30-40Nm (23-29 lb-ft).
15.Lower vehicle and tighten hub nut to 230-275 Nm (170-202 lb-ft)
16.Depress brake pedal several times prior to moving vehicle.
Hope this helps. Good luck !
Mar 14, 2009 | 1992 Ford Taurus
Power Glide Circular Saw with Laser Guard Spring Broken
The spring hooks onto the blade guard and wraps around the hub of the blade guard. It is orta hard to see but it will hook onto the guard.
Feb 11, 2009 | Ace Hardware Power Glide Circular Saw with...
Health & Beauty Logo
66 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Marvin
Marvin
Are you a Health and Beauty Expert? Answer questions, earn points and help others
