Question about HP P1110 21" CRT Monitor
Display adjustments the monitor does not adjust the horizontal display. only the vertical adjusts
    Scholar:
  • 121 Answers
Is the H. Position not showing up in the menu? Or is it that you can't seem to get to the Horizontal positioning that is the problem? Usually there are 4 keys: Auto, <, >, and Menu (I'm NOT counting the power button of course) Menu starts off the process while the < and > get your through the menu. When you see the V. Position, hit the "menu" key and the H. Position should pop up.
Posted on Mar 27, 2007
My screen seems to be slightly out of focus - is there an adjustment I can make?
usually there is auto adjustment on the bottom part of your monitor. if there is none manually adjust it using vertical and horizontal adjustment tool in the same set of controls at the bottom of your monitor
Dec 05, 2013 | Dell Inspiron Computers & Internet
One inch of the window is off the screen
you could adjust the vertical and horizontal adjustment through the main menu of the monitor. buttons on front of monitor. auto adjust may fix it but if it does not look for the vertical or horizontal adjustment fot the area effected. if this helps please rate with comment
Feb 03, 2013 | LG Computers & Internet
On the Onscreen Menu I accidentily set the horizontal position of my monitor too far to the right- how can I decrease it so I don't have it offset???
If you have a 3D monitor, good luck, otherwise, tap the buttons on your monitor that say menu, etc... there's horizontal and vertical adjustments in your monitor. If it's software, then go to your display settings and re-adjust.
Sep 25, 2010 | Computers & Internet
I have a Samsung NC10 notebook hooked up to an Acer x193w monitor and up until today it has been working perfectly. Now the display will not fill the monitor's space. Horizontal is fine but vertically the...
Do you have a spare computer to hook up to the monitor to see if the monitor's settings are off vertically?
Can you adjust the vertical size of the image of the monitor?
Are the letters squashed down vertically?
If the letters are squashed down vertically, did the setting for pixel size of the screen get adjusted to another size accidentally in the control panel under display settings?
Can you reset the Acer monitor from the menu?
Jul 29, 2010 | Acer X193W LCD Monitor
How do you adjust the vertical and horizontal of the image on your screen?
Press the OSD (On Screen Display) button on the face of the monitor. You'll find controls to control the size & position both horizontally & vertically.
Jun 01, 2010 | Dell E773C 17" CRT Monitor
Vertical and horizontal not displaying property and shadows in picture.and do not know how to work the adjustment
I fixed the adjustmen.ts by trial and error of monkeying around on monitor adjustments(no manual to work with).In the morning the shadowing was gone..think it is from over heated graphics cards.
Dec 25, 2009 | Samsung SyncMaster 931BF LCD Monitor
Monitor problem
Appreciate the "Ask Me".
I am assuming that you have more than just familiarity with electronic components and circuitry, the use of a DVM and a soldering iron. Further, that you have access to a service manual.
Width problem is basically insufficient horizontal deflection, then analysis would have to be in the horizontal section. Areas to initially focus on:
  1. 12V line and pin 29 of IC401;
  2. 110 V peak to peak at collector of Q403, if yes check Q 402 & 404 as well as T401;
  3. other components that affect the horizontal size are:
  • IC201
  • Q 405, 406, 407 & 408;
  • D409
  • L401
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 06, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
Display issue
dear you will have to open your monitor case because this problam is related to your display so in your monitor you have to adjust preset then you can adjust you monitor display accroding to you.
Aug 13, 2007 | WYSE Link Max 900 Network Terminal
HP P1110 21" CRT Monitor Logo
113 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
