Question about 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
I had a viper 5701 responder LE 2 way system installed on my 2006 dodge Dakota, everything works fine but my headlights and parks lights stay on constant while in remote operation and my park lights do not flash . I had this installed at best buy on 11/24/08 i was told that there's nothing can be done and this is the way my lights work, what can be done. Thanks in advance Mr. Mason
  • Anonymous Dec 18, 2008
    first of all thanks for responding, i want only my parking lights to flash during remote start the problems i have is that nothing is flashing and all my lights are in full running mode but when i put the key in the ignition turn it and hit the brake pedal the lights go out for 3 seconds then come back on full mode when i put the vehicle in gear the lights go out until i put them on for driving.
  • Guy May 11, 2010
    I'm not sure I see the problem. Do you not want the headlights on during r/s cycle? Do you want the parking lights to flash?
  • 3 Answers
If your vehicle has daytime running lights they will be on when remote started no real way around that try leaving your parking brake on.
The new vipers default setting is constant rather than flashing.
Posted on Jan 07, 2009
  • 27 Answers
Take it back to the dealer. If the system is properly installed he can program the parking lights to flash during remote start. The parking light output on this alarm can be programmed to flash, stay solid (factory default) or stay off during the R/S cycle.
On your car the headlight and parking light are turned on by a multiplexed wire, i think 1130 ohms for parking light and 660 for headlight. They may have used the wrong resistor. It is a simple fix and leaving it like it is should not cause any harm, however, the longer you wait to take it back the harder it will be to get them to change it.
Guy
Posted on Dec 19, 2008
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
Why won't it start vehicle?
[PDF]Responder LE Model 5701 Security and Remote Start ...
xtremetruck.net/file/1101-Viper+5701+Owner's+Guide.pdf
the year, make and model of the vehicle; vehicle license number and vehicleidentification number. All ..... One five-button/2-way Supercode Responder LE RemoteControl. ? .... Disarm. Unlock LED blink for one second with 2 Beeps. Remote. Start..... Long-time Viper system users will notice the following differences:.
Viper LED 2-Way Security + Remote Start System
https://www.viper.com/car/securityremotestart/.../viper-led-2-way-securit...
Viper's elegant new Responder LE transceivers mark a giant leap forward in 21st century vehicle security and remote start, and an evolutionary milestone for the ...
Viper 5901 remote start error fix - YouTube
? 2:38
https://www.youtube.com/watch?v=wsSorAf88nw
Jan 13, 2013 - Uploaded by Power2ThePeopleZ
5901 won't start vehicle; gives an error. ... or even try to open the hood. the door remains locked when you start the car with theviper alarm.
Help With Programming/Pairing Viper Remote - YouTube
? 2:49
https://www.youtube.com/watch?v=cgbQsZuVyt8
Dec 2, 2010 - Uploaded by Paul L
I have a two-way remote from my Viper 5901 system. ... The other car (one in video) has the Viper 5701 system in it. .... and then release 3) press the remote start button 2 times until pairremote is displayed 4)press and old ... I had the same problem that the remote won't pair with the system no matter what.
15964701 Viper 5701 2 way alarm w/ remote start won't
Jan 05, 2016 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Parking and cab lights don't flash where arming or disarming. Also Lights don't say illuminated when remote start is on. Did i turn this function off?
It's possible that the parking kight wire is no longer connected or, the (alarm's) fuse for the parking is blown. The parking light fuse for the 5701 is located behind the door on the alarm module.
Jul 20, 2011 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
I have the viper 5701 on a bmw 540i and the alarm works so does the keyless but the remote start does not work, the park lights flash 7 times and gives an error code,what can cause this?
The flashing parking lights signal a shutdown diagnostic. There is a nuetral safety switch under the dash. It's a toggle switch that needs to be in the on position. Also, the hood pin needs to be making contact with the hood when the hood is closed.
Jun 28, 2011 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
My viper 5701 transponder gives error code of five blinks even though it does the function
Five blinks of the parking lights during remote starter operation is an error code for the (+) brake shutdown. If your foot is not on the brake then, there is an issue with your brake switch or your parking lights and brake lights wires are making contact, possibly in one of the front or rear light housings. Corrosion maybe.
Mar 15, 2011 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
I purchased and programmed a new remote to my 5701 starter.security system. the lock and unlock functions work byt i just get a loud beep, flashing red light on the remote and my headlights blink 7 times
The seven flashes from your parking lights is the remote starter error diagnostic. Seven flashes is the message for neutral safety wire. The toggle switch under the dash is in the off position or, if the small, thin black with white wire is not connected to ground.
Feb 08, 2011 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Hello. My Viper 5701 suddenly doesn't start anymore. I press the button on the 2way, I get a red light by the f instead of the usual green start light. The rest of the functions (unlock, lock, alarms) work...
You should also be receiving an error message. If the parking lights flash six times, it relates to the hood shutdown wire(-) or the brake shutdown wire(+). If the parking lights flash seven times, it relates to the neutral safety shutdown. Check the toggle switch under the dash and flip it to the opposite position.
Jan 23, 2011 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
My viper 5701 when cold will start with headlights staying on then the engine shuts off and when disarming the alarm the doors wont unlock. when the truck warms up then the system works properly.
This sounds like you may be having a problem with the interface module that is used in your truck and maybe not the remote start. Depending on what kind of truck you have and it sounds like you may have a GM truck... there is an interface that is used to control your locks and bypass the security system in the truck. You maybe having an issue with that.
Jan 07, 2011 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
My viper 5701 2way remote works, but gives buzz for all functions
hi did you get this unit from ebay? i am going through the same experience right now and there is a problem with the early units that were manufactured. It will need to be replaced. I am currently trying to get a refund.
Jan 31, 2010 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Viper 5701 remote programming
1st you need to enter the remote into progamming Hold the Function button until the remote gives a long beep and LED light comes on the remote a (it takes about 8 sec.) Then press and hold the remote start buttom until the remote beeps 3 times and LED lights up. Now your ready to program the remote
One of the door has to be open . Insert the key - turn the key to the On position then press the button on the antenna once and then press it again and hold it
You hear a chirp and then you press the lock button on the remote and then you hear a second chirp to recieve confirmation and then release the button and the turn off the key .
Remote should be program
Jul 11, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
VIPER 5701 GOES OFF ON ITS OWN
this is a EASY FIX.... if the car has a factory alarm installed, then the installer never connected the OEM disarm wire. its a LIGHT GREEN/BLACK wire connected to the H2 harness. just have them connect that and youre problem will go away .
JOSEPH GARCIA BEST BUY CERT M.E.C.P INSTALLER
Mar 24, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
5701 VIPER 5701 2-WAY ALARM w/REMOTE START Logo
895 people viewed this question
Top Viper Vehicle Parts & Accessories Experts
Kevin Daniels
oneStan
oneStan
Tre Elkins
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
