Question about GPS
I'm looking for a portable gps that can accurately mark where I'm standing. Later, I'd like to be able to plug the unit into a pc and determine the closest address to the point I set. Is this realistic? Any suggestions?
I called Garmin and Magellan.
Posted on Dec 18, 2008
Is it indash unit or portable? if indash then you need to locate the GPS Antenna and make sure it is plugged in and not obstructed by any metal.
If portable then try holding down the reset button on the back for ten seconds, If this doesn't help the unit will need servicing.
Mar 10, 2012 | Tomtom GPS
My garmin nuvi 205 will only display a black screen with the word garmin on it. I have powercycled multiple times but that is all it will do
It may either need a screen reset, or a cpu reset.
To reset the screen, Push the upper left hand corner of the screen (under the pwer slide-switch), while you toggle the power switch on AND HOLD THAT SPOT FOR MORE THAN 15 seconds, or until you see a display that says to Calibrate the Screen.
If you get there, there will be a black dot to touch (with the back of a pen) different locations of the screen. This determines how it will react to your touches when operating.
(I did not know about this, and just used my finger to touch the dots. Well I could not see other pages later, and I thought the unit is broken).
Then shut it off, and reboot. The Garmin comes on with black background...loads the software...then the warning notice-Agree- to press.
If you cannot get either of these, your unit is not loading its software.
If your unit has a "Reset Button on the bottom of the unit" . Do not use sharp pointed objects.
If no Reset Button... lastly, Slide and HOLD On/Off switch to the left FOR 8-10 seconds.
Wait a bit, and try switching on again. All this is per their web site User Manual for the 200series.
Good luck.
Jan 13, 2011 | Garmin nuvi 205 GPS Receiver
Megellan Maestro 4210 gps slow to find current location
I recommend you to reset it . Resetting should solve this problem .
Here is how to reset your Maestro :
1:Locate the button marked "Reset" on the left, right or bottom of the unit.
2:Using a thin object, such as a paper clip, depress the button for two to three seconds. The unit should reset.
3:If the unit does not reset, immediately press the button again and hold it for up to 10 seconds.
Apr 14, 2010 | Magellan Maestro 4210 GPS Receiver
Every time i turn on my lowrance 520c it says gps module not resp
I had the same problem. Sent my entire unit back to Lowrance, but they said it was fine. One year later, I find out that I did not receive or have the correct parts to hook up the GPS unit. I needed the NMEA 2000 T connector and terminator plugs. Look at your manual and hook it up the way the manual says. It will require a NMEA 2000 T and at least one 60 ohm terminator plug. Seems the GPS module sends back some kind of signal that if not absorbed by this thing will mess up your unit. Mine works since I got it hooked up correctly. HD
Jul 17, 2009 | Lowrance LGC-3000 GPS ANTENNA FOR UNITS...
My garmin Street Pilot just went dead on me.
I got back into my vehicle today to go get my mom at the airport. I plugged the unit In & It worked. I suspect that It is the battery. After I shut off the engine I got the message that says do you want to still operate on battery power. I clicked ok but it said low battery. So now I have it charging by using my portable air compressor. So hopefully It doesn't die on me for at least another few years or if It does then It's time to upgrade to the Nuvii
Thanks for the people that replied to my question.
Jan 17, 2009 | Garmin StreetPilot c550 GPS Receiver
bjw122266 Have you tried holding the power button down for about 10 seconds or so?
Dec 29, 2008 | Navigon 2100 Portable GPS Receiver
There is no rechargeable internal battery, AA only.
Nov 21, 2007 | Garmin StreetPilot i3 GPS Receiver
GPS Logo
14 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
