Question about Vulcan Convection Oven - VC44EC-208-1
Need to ask if you have a service man in my area?My vulcan convection oven is broken
  • Todd Born
    Todd Born May 11, 2010
    where do you live?
Blower motor not turning on is this correct
Posted on Nov 09, 2009
My vulcan convection oven flame stay on 10 second then goes off for 5 second then goes on again how should I fix this problem anybody has an idea???
I would check pilot is clean and strong , check thermocouple is in good condition not brunt out check flame sensor is clean and all connections are tight .
Mar 20, 2018 | Vulcan Ovens
Vulcan convection oven model SG4d-1 will not ignite burners
Gas does not ignite. No spark. No Ignition light is not ON.
1. Shorted electrode on igniter/flame sense.
2. Igniter cable (high voltage) OPEN.
3. Heat relay malfunction.
4. Centrifugal switch in blower motor inoperative.
5. Transformer inoperative.
6. High limit thermostat open.
7. Interconnecting wiring malfunction.
8. Ignition module malfunction.
Sparks but gas does not ignite.
1. Gas solenoid valve off or inoperative.
2. Manual gas valve closed.
3. Gas supply OFF or insufficient gas pressure.
4. Inerconnecting wiring malfunction.
5. Igniton module malfunction.
Feb 23, 2010 | Vulcan Convection Oven - VC44EC-208-1
We have gas operated vulcans that are not baking evenly. And browning is very uneven
They need to have the thermostat calibrated. Go to Vulacans web and locate the calibration proceedure service manual.
Aug 06, 2009 | Vulcan Convection Oven - VC44EC-208-3
Vulcan SG4D convection oven is shutting off.
http://www.vulcanhart.com/manuals/F-35626.pdf
Since you were lacking a few specifics, go to this web site and it will have the service manual on your unit.
Hope this helps
Jul 23, 2009 | Vulcan SG4D Gas Single Oven
Vulcan convection oven has pilot lit and fan blows but no ignition. The schematic is too small, grease smeared and partly ripped to be of use. Is a schematic available or is the cause obvious to an...
The list of problems is as long as the one Obama inherited when he took over. Good news though, the most expensive part works, the blower motor! The pilot is established which rules out a gas issue. The two most common problems are, either the temp controller or the infinate switch is bad. Your unit has one or the other but, not both. Controller has several wires leading to it & has a green or tan circuit board on it, infinate switch is a small black or white 2 inch square box with 4 or 5 wires leading to it. Each one of these are mounted thru the front control panel & both have knobs. Temp board around $180, infinate switch around $45. As far as the schematic is concerned, Vulcan was bought by Hobart & they DO NOT give out schematics or service manuals.
Jul 10, 2009 | Vulcan Convection Oven - VC44EC-208-1
I have vulcan Double stack electric ovens 208v 3ph.what size breaker do I need to power each oven
I need to know the Power rating Example 5Kw or the Ampere Ex. 30A . What is the raring of each oven? The Breaker should be greater than the Ampere of your oven let say 120% greater.
Jun 11, 2009 | Vulcan Convection Oven - VC44EC-208-3
Amana AOCS3040 Convection Oven
If I were you I would contact Amana and speak to their service dept. and tell them your problem as maybe theres a service bulliten out or a common repair and if that they would recommend someone who can fix this model.. I tryed to look up this model and I couldnt find it. If that dosent help Go to http://repairclinic.com and ask the repair guru there for assistance.. Good luck
Apr 16, 2006 | Amana AOCS3040 Electric Single Oven
Vulcan Convection Oven - VC44EC-208-1 Logo
118 people viewed this question
Top Vulcan Ovens Experts
John Tripp
John Tripp
Marvin
Marvin
Dennis Boxerman
Are you a Vulcan Oven Expert? Answer questions, earn points and help others
