By Powe33 - usenet poster
When it's turned on, the light on my monitor blinks but the screen doesn't display anything. Why might this be happening, and how can I fix it?
60 Other Users Have The Same Problem
Comment by louve_0603, posted on Sep 17, 2008
when i open my computer the monitor is just blinking and monitor is not display anything how can i fix it?
Comment by Guest, posted on Sep 17, 2008
turned on my computer it would sound like normally booting but the screen is black, led is red blinking fast.
Comment by ebad, posted on Sep 09, 2008
I have HP L1706 LCD monitor some time the monitor just dont display anything and the light keeps on blinking then suddnly it comes to life,This usually happen on starting computer.
Comment by bigcesar1, posted on Sep 06, 2008
After taking one ram card of my computer and putting it on another computer and then putting it back on the original computer the monitor won't display anything. It turns on and i think there is communication between the monitor and the computer but nothing comes out the screen is just dark and the monitor light is steady just as it is on all computers what could happen and how can i fix it.
Comment by BlindDeath, posted on Aug 23, 2008
When I start up my computer and monitor, the light to the monitor just blinks and shows me nothing on the screen; staying black and not changing into any image.
I've checked the cables, unplugged them numerous times. This has been happening for some time now, but I was able to get it running, now I can't a thing it seems.
Best Solution
posted on May 30, 2006
Rank:
Apprentice
Rating: 77%, 19 votes
I found electroletic capacitor,(c707), to be bloated.
Changing this with an equivalent 1000uf 16v fixed my monitor.
Symptoms were:- Flashing orange light and no picture.
Also after switching off the power would not always come back on.
had to boot computer a random amout to get it to kick in.
That cap caused all that but is now as good as new.
All the best...Tom
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Nov 14, 2007
Guest
Rank:
Apprentice
Rating: 0%, 0 votes
Had same problem with my HP f1523 screen. Power light blinking and screen blank. I took the back off and had a look inside. Switched it on and screen came on. Closed it back up and working okay now. Supect it will probably go faulty again at some point.
Solution #3
posted on Jun 11, 2007
Guest
Rank:
Apprentice
Rating: 0%, 0 votes
I'm working on this problem right now. It could be bad capacitors in your monitor. I wouldn't advise trying to fix that yourself unless you are a trained electrician.
Solution #4
posted on Aug 08, 2008
Rank:
Apprentice
Rating: 85%, 1 votes
Probably fuse problem on the main board. Open the monitor and check fuse PF751 near the biggest heatsink of transistor D701.
Fuse looks like a resitor. Measure it with an ohm meter it should read open or short any other value indicates th itiem is to be replaced.
Solution #5
posted on Aug 08, 2005
Jimmy NY - usenet poster
Rank:
Apprentice
Rating: 0%, 0 votes
It sounds like it has power but not getting any signal from the PC. Try a different monitor cable from the PC.
Does the PC work with a different monitor? If not, it could be the graphics card in the PC.
Solution #6
posted on Mar 24, 2007
Guest
Rank:
Apprentice
Rating: 0%, 0 votes
on screen disply is ok
the problem is graphics card or vga cable problem. but when the monitor is on light blinks start,problem in power section rectifier and lot over loaded, power section main filter folty
Solution #7
posted on May 04, 2007
Rank:
Apprentice
Rating: 60%, 6 votes
reset the bios with the following methods:
1. remove battery and keep for somtime and then put it back
2. there is a jumper with exactly 3 pins which u should switch and then switch back
does work sometimes..
Solution #8
posted on Aug 20, 2008
Guest
Rank:
Apprentice
Rating: 0%, 0 votes
It sounds like a backlight failure,I have one and tried repairing it ,it had a major short at the ccfl connector burned through the plastic housing around the LCD
Solution #9
posted on Aug 11, 2008
Rank:
Apprentice
Rating: 0%, 0 votes
i have the same problem, monitor switches on and sound comes on then dies out, all the time i get a black screen. i have tried a different cable, but still no luck. the graphics card is totally wrong because if i try my old screen it works fine.
any genuine help will be greatly appreciated....
Solution #10
Rank:
Apprentice
Rating: 0%, 0 votes
You have to turn it on the right way, the way to do this is rub your ***** on every inch of the screen and kiss it with your pee hole then *** on the monitor logo. This will turn on the monitor in ways the power supply can't.
Solution #11
posted on Jun 05, 2008
Guest
Rank:
Apprentice
Rating: 0%, 0 votes
Possibly a blown out inverter.
Solution #12
posted on May 31, 2008
Rank:
Apprentice
Rating: 0%, 0 votes
This is the most common thing in these dell panel.
It is your inverter board or power board, because dell stupidly make these board combined inside of you lcd, you would just have to get the whole board replaced. look on ebay for same model with someone have a broken screen , and replace your internal parts with that.
Solution #13
posted on Apr 21, 2008
Rank:
Guru
Rating: 85%, 300 votes
I suggest to open the monitor and check for a DRY SOLDER, mainly around the INVERTER TRANSFORMERS on the PC board .
Solution #14
posted on Apr 18, 2008
Guest
Rank:
Apprentice
Rating: 0%, 0 votes
The TFT board has to be changed it is blown. The monitor light blinks but no pic if I am correct to your problem. I see this problem at work as I'm a tech for casino games as we use LCD monitors for certain games. We just open the backs and there is a board the looks like a memory stick shape with 4 wires going into it thats the TFT board you replace with a new one and Bam your back in service. You just gotta find someone who sells the board you need. Cant be expensive as we pay $15.00 for our boards for 19" monitors. Hope this helps.
Solution #15
posted on Apr 17, 2008
Rank:
Apprentice
Rating: 100%, 1 votes
I have the same problem with a Philips150S4. But my 150S3 does not have any problems. I suggested that my 150S4 has a problem with the power management function. I solve this problem in this way: turn on PC, wait until the user log-in of winxp appears (you know I can't see because monitor is off), turn on monitor. So, the power saving management of the monitor can't switch into suspend mode during resolution switching while booting.
That's not the ultimate solution, but it works. Does anybody have an idea how to fix this problem in order to replace or short-cut some hardware components of the monitor?
Solution #16
posted on Mar 14, 2008
Rank:
Apprentice
Rating: 92%, 2 votes
Definately power no signal.
Try the screen on another computer, if it doesn't work on another computer it's definately defective.
If it works, could be one of a number of things, a> defective video card, b> you had a different display on the computer before and the video res is set incorrectly c> video driver settings in general incorrect.
You can sort point b and c by resetting the video ram, you will need to look on the net which keys to do hold down on boot to do this, is different between pcs and macs.
Formacs support number is 0845 862 0480 or email service@formac.com
If its not under warranty the cost to replace the controller board in this type of display inc labor is approx £100.
Solution #17
posted on Mar 04, 2008
Rank:
Guru
Rating: 85%, 121 votes
Hi this is the way how to examine what's wrong with your LCD
monitors. Power on both CPU and monitor. After that, you have to check if you can see the image on the screen or not by shining a flashlight into the
screen, not directly but find the best angle to the screen and take a look very
closely. If you can see the icons or any image, there will be a minor problem.
Like me, I can see window image using flashlight and check lamps inside. Some
of them were broken and it is easily replaced. If you cannot see anything on
the screen, there'll be some problems with inverter board. If you have
soldering tool and want to fix it by yourself, check the caps first. It may
cause this problem. Some caps might show leaking or burn spot on the board
because of too high temp. If you don't have soldering tool, you better go get a
technician to do so.
Solution #18
posted on Jan 30, 2008
Rank:
Apprentice
Rating: 0%, 0 votes
i fixed mine if u take it apart there is 2 fuses one of mine was blown i replaced it with a fuseable link
Solution #19
posted on Jan 09, 2008
Rank:
Master
Rating: 76%, 10 votes
Right but worng... when it is blinking orange and you know
1 that you cable is good
2 that you video output is there (same cable and computer on different monitor)
THEN THE SINC BOARD IS BUST.
Throw alway the monitor
BTW all of these monitors mare made by SONY you will find a GDM number on them.
Solution #20
posted on Dec 17, 2007
Rank:
Apprentice
Rating: 0%, 0 votes
Sorry i'm swiss-french ;o)
Open the monitor's back cover.
When it is connected to a PC and receive a VGA signal, and it is switched ON, disconnect and reconnect all internal connectors. Especially the connector with a black cable that leaves about an internal a circuit. It seems that it stands to produce a Reset and the monitor works again!
In my case it was OK.
Solution #21
posted on Nov 19, 2007
Guest
Rank:
Apprentice
Rating: 0%, 0 votes
probably dead i have seen this twice and there was nothing wrong with the machine. so i tossed it.
Solution #22
posted on Oct 01, 2007
Guest
Rank:
Apprentice
Rating: 0%, 0 votes
I have about 200 vp930b's some even newer vp930b-3 and everytime there is a power outage we lose about 8 monitors that indicate this same problem. Even when we shut down computers and turn off these monitors we have many of them that show this same blinking green light.
Viewsonic used to be a good responsive company as we had several hundred CRT's but as they have gotten bigger they just are not as responsive. They will not give us any indication of what they are fixing or why this is happening. We curently have 16 monitors out of 200 in or on there way for repair. We have good power levels in our building use good surge surpressors and some that have gone out are on battery backup systems. ???? Call viewsonic if it is a blinking green light the monitor will require service.
Solution #23
posted on Aug 02, 2007
Guest
Rank:
Apprentice
Rating: 0%, 0 votes
in order to replace the wire for this monitor you need to take apart the screen and solder it in place...
Solution #24
posted on Mar 21, 2007
Guest
Rank:
Apprentice
Rating: 0%, 0 votes
Take a light and put it very close to the monitor, the backlight of the monitor has probably gone out. In which case you could get it repaired, or buy a new monitor.
Solution #25
posted on Jan 21, 2007
Rank:
Apprentice
Rating: 78%, 6 votes
Graphics settings are out of the monitor's range. If you're using Windoze, boot into safe mode, F4 or F8 and change the graphics settings. If you're using linux, boot into command line only from grub or lilo and reconfigure xorg.
If that doesn't work, you're monitor's screwed. Go hire a techie.
Solution #26
posted on Mar 30, 2006
Rank:
Apprentice
Rating: 55%, 2 votes
I have just had the same experience. At the moment it looks like a power supply fault. I have tried it on another PC but still nothing!!.If you look locelsy at the screen from an angle, you can see it trying to power up.
12v 2.00amp required.
Solution #27
posted on Mar 25, 2006
Rank:
Apprentice
Rating: 0%, 0 votes
Had same problem with Mine , changed graphics card and still the same fault . Removed back of monitor (do not do if still under warrenty)and found printed circuit board blown.
60 Other Users Have The Same Problem - Continued
Comment by x9_livesx, posted on Aug 20, 2008
well i have a sdm n80 color computer screen display it sony. it somtimes had problems n i would wiggle the cord tht connects the computer to the box n it would work the one day it fell of my desk straight down n hasnt work since then, the box blinks a red light but the moniter doesnt. plz help im trying to sell it and cant if its messed up
i droped my screen straight down once so yea the little box blinks a red light but lcd doesnt go on
Comment by goksincarey, posted on Aug 19, 2008
Lcd Screen is black when power is on
Comment by timv, posted on Aug 17, 2008
my Acer AL 2051W LCD monitor power is up, but it screen is blank.
How do I start to troubleshoot this? What could be the problems? Do I need a new card and the monitor? New graphics card in the PC?
please help!
Comment by Guest, posted on Aug 08, 2008
Lights Keep blinking
Comment by Guest, posted on Aug 07, 2008
it is just blank
Comment by amazma, posted on Jul 21, 2008
I have the same problem. The light stays on for the monitor but no display. I tried another monitor and it worked. I also tried another cable and the problem persists. Does anyone know if there is a part that may went bad and can be exchanged easily. The monitor is only 4 years old and I hate to disposed of it.
Comment by Kitcats, posted on Jul 20, 2008
I heard a brief, maybe a second and a half long, whistle before the screen went dark, although the green power light stayed. Leaving it turned off overnight made no difference. When I turn it on, I can hear its normal starting up sounds, but then the sounds just die out instead of remaining. I've never been able to see the bulb inside as another user mentioned. The power light starts as orange then switches to green at the same time as it used to. I only used this monitor for about 2 years, even though I'm sure the warranty ran out long ago.
Comment by alfaq2marow, posted on Jul 04, 2008
yeah same here everything is ok when i plug in a diffrent monitor but as i plug in the 21" the light goes green for about 20 sec then turns orange and blinks and i also noticed the bulb inside the monitor turns on but very dimm light then shuts off and thats when the light in the font turns orange
Comment by Guest, posted on Jul 04, 2008
my monitor just dont turn on i tired with a diffrent monitor and everything is ok but when i plug in the 21" it goes green for about a minute with a black screen then goes orange and blinks and the bulb inside the monitor turns on but very dimm then shuts off
Comment by majid97, posted on Jun 22, 2008
When it's turned on, the light on my monitor blinks but the screen doesn't display anything and none of the buttons function
Comment by kamal90, posted on Jun 15, 2008
When it is turned on the light on the press to start botton goes Green the screen show display for one second then goes blink and the light on the press botton turs orange.
Comment by jojobiggs18, posted on Jun 09, 2008
when i pus the power button the light on the tv flashes but the tv doesnt turn on
Comment by Guest, posted on Jun 02, 2008
Same here. I've tried restarting the computer several times and everything. When I restart, the power light turns orange, then back to green.. but nothing appears.
Comment by esotericx10, posted on Jun 02, 2008
Monitor light turns on when powering up, but remains blinking with nothing showing on the screen. The light should turn amber when it comes on, and then it should turn blue, but it blinks in blue instead. I disconnected that monitor and have connected another monitor, and that one works fine.
Comment by foxebasta, posted on May 29, 2008
My monitor after a year start smell burn overwarming after few days it turn on the screen for ten seconds and off again but only the screen not the power. I tried to contact Niko company but there is not Niko company in US. I have a warranty but there is not site (for sell) and not phone number. Do not buy Niko again !!!!
Comment by Guest, posted on May 28, 2008
my moniter is getting green light and with in few sec its getting orange light,if i remove dispay card from CPU it shows as no signal
Comment by Guest, posted on May 27, 2008
Comment by cherven, posted on May 19, 2008
Comment by Guest, posted on May 18, 2008
When I turn it on, the light stays orange and there 'no signal displays' Have checked connections and all seems fine. Monitor works fine with another PC
Comment by Lavina, posted on May 17, 2008
Comment by tweetyviper, posted on Apr 18, 2008
The screen on my monitor is blank and I plugged it in to another pc, I think it's a light bulb cause I looked at it in a very bright light and I can still see some image it's just not bright.
Comment by Hooplaw, posted on Apr 18, 2008
I bought this product at Best Buy --it blinks and the screen stays black...This is a problem inherent to this product? I want a solution? I have only had this product 1 1/2 years.
Comment by larmando, posted on Apr 15, 2008
I have a monitor in Dell UltraSharp 2405FPW 24. Flat Panel LCD, when you turn the screen starts blinking but not my picture, it is as if off, and with another monitor and probe is not my pc
Comment by lynfel, posted on Apr 12, 2008
my problem is when i turned on my computer monitor after a seconds it will turning off....
Comment by Guest, posted on Apr 12, 2008
when i turned on the monitor after a seconds it will turning off .....
Comment by ronnel_b, posted on Apr 09, 2008
My LCD Monitor blinks but no display on the screen..
Comment by flowers45, posted on Apr 02, 2008
my computer monitor blinks and it is 4yrs old i have change cable and power cord but it still does the same action what i do is like tap or knock on the back and then it will come on again and some times it shimmers.
Comment by Guest, posted on Mar 29, 2008
i have a benq fp731, it's green light is on, nothing displayed, but i have noticed you can see it is working but it's although the back light behind isn't lighting the screen up. i'm not sure if its the monitor or computer? i've struggled to change brightness but that didn't change anything?
Comment by Semanteme, posted on Mar 27, 2008
I have the same problem on my AOpen monitor.
Worked last night....problem this morning.
AOpen techsupport says they are now closed...call back during normal business hours...7AM - 7PM...it is now 7:40AM.
Guess the Sweetness of Low Price is gone Before the Bitterness of Low Quality.
Comment by mikxhelp, posted on Mar 14, 2008
When it's turned on, the light on my monitor blinks but the screen doesn't display anything. I have readjusted the VGA cable and the power cables, but still i just get the blinking light.
Comment by Guest, posted on Mar 05, 2008
Comment by Mike021570, posted on Mar 02, 2008
Same thing. Monitor appears to go into sleep mode but will not come out. Steady green light flashing
Comment by olady, posted on Feb 23, 2008
the picture on the screen was dull so i press the panel key on the monitor and it went black but theee green light is on .i off it and on again the green light still comes up but the screen is black
Comment by Patacake, posted on Feb 12, 2008
Message appears on screen 'no signal'. Monitor power light stays lit for a few seconds then turns orange and the screen remains blank. I have checked the power cables, etc. all are secure.
Comment by Guest, posted on Feb 08, 2008
No image when turned on
It used to be waiting for 10 minutes before image was showing up
Comment by Guest, posted on Feb 07, 2008
I have a HP f2105 monitor that starts with logo, goes off and I see desktop for about 4 sec then its turns black and stay black. I switched the monitor on my computer and my my old monitor works fine. I can't get the f2105 one to work with any other computer because they are to old. Any advice would be appreciate
Sharcee.
Comment by Guest, posted on Jan 11, 2008
I have the same problem. The power lock is on, and the monitor can't be turned on or off, except unplugging.
Comment by Guest, posted on Jan 02, 2008
yes am jude i have a celerone comp it powers with the green light first then after 2 seconds the lite turns to red and the screen does not show anything its just nothing: the screen looks like one that is off i have tryed changing my pc to another monitor but all is the same well give me the answer on email.
Comment by Guest, posted on Dec 30, 2007
when turned on my monitor blinks continously, but when i disconnect it stops or show no connection.
Comment by Guest, posted on Dec 18, 2007
When i turn on the KVM the back light comes on, but i get no display and the I the keyboard is not working cause when i toggle caps/number lock the led does not light up.
Comment by ATHOS, posted on Dec 03, 2007
Samsung SyncMaster 940b i have the same issue but i tryed with 2 different pc
first with docking station changed the cables and output to screen from numeric & analog same trouble then tried same on desktop still the screen lights up for .5 sec then appears to shutdown but by putting a flashlight on the screen i can see that the signal is going to the screen i barely see the desktop but i can see shapes of IE windows on the screen....i can almost see the mouse moving around...
do you think i might of used a combination of buttons on screen or old one of them too long and something happen ???
one more thing if i use the on/off button the screen reopen for .5 sec each time i press it weird ???
Comment by jess050669, posted on Dec 02, 2007
Comment by Guest, posted on Dec 02, 2007
When it's turned on, the light on my monitor blinks but the screen doesn't display anything. Why ....
Comment by tsaltmarsh, posted on Nov 29, 2007
When I turn on my Flat Panel Monitor the power button and the lower
edge on the screen starts flashing. The screen doesn't display anything. I replaced Power and Monitor Cables , I connected the monitor to another computer that had the same flat panel... the trouble followed.
When I turn on my Flat Panel Monitor the power button and the lower edge on the screen starts flashing. The screen doesn't display anything.
Comment by Hklassen, posted on Nov 27, 2007
I have a Hanns-G HN199D and it is doing the same thing. I'd love to hear if anyone is having any success... I've tried new power and display cords, and also plugged in other monitors. The new monitor worked on the old cords, and the new cords made no difference with the monitor
Comment by ntn_2000, posted on Nov 24, 2007
I also have the same problem. When it's turned on the BenQ screen displayed for less than a sec then turned off immediately. I'm vey sure that it's not graphic card problem 'cus i hooked up another monitor at the same time and it worked just fine. Please help
Comment by Vashishacked, posted on Nov 22, 2007
Same problem with Samsung 215TW. Tried with component input, the screen flashes the correct picture going to input and returns to blank about .5 second later. Turn off monitor and turn it back on to have the same thing happen continuously.
Comment by Sister2broth, posted on Nov 21, 2007
I'm also having the same problem. If I turn it on and off fast then I will get a screen display for about 1 second.
In my particular case this started happening right after I had the computer on for 2 days straight.
http://thecomputerdude.blogspot.com
Comment by Guest, posted on Nov 14, 2007
The Monitor turns on and displays the green power LED but only has a Blank screen, Have tried a different monitor cable, Still the same.
Regards
John
Comment by Guest, posted on Nov 09, 2007
Monitor light is blinking but monitor won't display
Comment by silkk, posted on Nov 06, 2007
yeah i have the same problem with my dell ultra sharp it just blinks and nothing come on what should i do?
