BLURRED COLORS OUT OF FOCUS PICTURE , PICTURE LOOKS WASHED OUT DESPITE MANY SETTINGS THIS IS A LG325700 tv
  • 41 Answers
This sounds like the High Voltage transformer may be going out or at least the focus control on the transformer needs to be adjusted.
Posted on Dec 17, 2008
I HAVE A HITACHI 53WX10B TV AND THE SCREEN IS BLURRED. I HAVE TRIED THE MAGIC FOCUS BUTTON AND THE SHARPNESS BUTTON. ANY OTHER IDEAS?
Magic focus button don't work or datas never reaches 100%.Tv have a problems,known as a convergence problems,it dead.Tv have colors lines R,G,B mis alingments,have colors shadows pictures or a 3D pictures look alike?The tv have a dead convergence board.The tv convergence board have 2 STK convergence ICS and some or all of it resistors are dead too.These parts on the tv convergence board,must be replaced to solved the tv convergence pictures problems.The shop,will cost like $300-350 for parts and labors.
Dec 04, 2010 | Hitachi 53SWX10B 53" Rear Projection...
Colors are blurred
There is a focus control on all CRT sets. It would be on the back of the set. It might be accessible or it might be inside which would involve removing the cover off the set. This is not recommended as there is very high voltage present in there. If it is accessible from the back without removing the cover there will likely be two little plastic knobs. One marked "F" for focus and the other one marked "S" for screen.........don't rotate the screen control, adjust the focus until your picture becomes clearer. If this doesn't help a whole lot then your picture tube might be shot and that means time for a new TV.
May 24, 2010 | Zenith C27A24T 27" TV
Picture quality
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 06, 2010 | Philips 55PP9401 55" Rear Projection...
I have a Mitsubishi RPTV. Everything looks fine except for the blue colors look blurred. I have tried software convergence but the blue still looks blurred and strange. What can I do?
ADJUST THE ELECTRICAL FOCUS. AND THERE IS A MECHANICAL FOCUS ALSO. SET THE ELECTRICAL FOCUS BY LOOKING DIRECTLY INTO THE TUBE AND ADJUST IT SO THE TUBE SURFACE IMAGE IS SHARPEST. THEN LOOKING AT THE REAR OF THE SCREEN ADJUST THE MECHANICAL FOCUS, ON THE LENS UNTIL IT IS SHARPEST. ALSO IT MIGHT NEED A CLEANING OF LENS&MIRROR. DIRT AFFECTS BLUE LIGHT FIRST.
Dec 27, 2009 | Televison & Video
The picture is blurred, words are blurred . . overlaid with red. Tried Magic Focus after 20 minutes and it was no better
you need to change the convergence chips that are attached to a heat sink, they are the two black chips with a lot of legs on them.
Sep 08, 2009 | Hitachi 43FWX20B 43" Rear Projection...
The picture is blurred because the red, green, and blue colors are not properly focused. The TV's auto focus feature doesn't solve the problem
This can be as simple as poor solder connections at the convergence ICs or defective ICs. If you can solder you can fiz this yourself. Let me know if you wish to attempt the repair and I'll suply additional details and instructions.
Dan
Mar 23, 2009 | Sony KP-43HT20 43" Rear Projection...
48" rear projection hazy/bad picture
most fluid changes would fix that. I recommend doing all three but that's just me. Also make sure the crt's are full as this would cause the set to be out of focus. also make sure you don't move the yokes too much because you can knock the convergence out pretty bad and also have a blurred pix
Jan 09, 2009 | Televison & Video
All pictures are blurred and when looking at screen its blurred
Your camera's Focus mode may be set on Macro Selectable in which case the Auto Focus Range will be "wide: 0.07–0.7 m, tele: 0.4–0.7 m (macro AF)" as quoted in the specifications from www.kodak.com web page for the EasyShare M1033. While this setting is great for a close-up of a flower, anything more than a meter (about one yard) away will be blurred unless you reset your Auto Focus mode back to "normal AF" or "landscape mode"
Jan 07, 2009 | Kodak EasyShare M1033 - black Digital...
Sony 61" Projection (KP-61HS10)
Your TV requires Geomatirc Adjustments in proper manner by qualified servcie person.
Jul 19, 2008 | Sony KP-57WV600 57" Rear Projection...
Green blur bot-R and up-L corner and no audio
If a standard TV has color splotches in 1 or 2 corners of the screen, it is possible that a large magnet, such as a large speaker, is or was near the set and has magnetized the picture tube. The set has a built-in degaussing coil but it is small and will only demagnetize small magnetic fields. Make sure there are no magnets near the set and if the colors are still off, have the picture tube demagnetized with a strong portable demagnetizer. As for the audio, when there are audio output jacks on the back of the set then there is usually an option to turn the speakers off. Some sets have a switch somewhere and some sets have a setting in the audio page of the on-screen menu. Look for a switch or go into the menu, navigate to the audio page and look for a speaker setting (ON / OFF) and make sure the speakers are set to ON.
Aug 28, 2007 | Konka K2386U 23" TV
Televison & Video Logo
237 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
