Question about Acer Aspire 3610 Notebook
Rexhina_revi@hotmail.com my notebook not work the battery work direct the adaptor pls help me and my keyboard when im formating my pc is diferent key has been aqw now is qaz pls help best regards vini
    Master:
  • 413 Answers
The normal keyboard is called a qwerty keyboard because the letters in the upper left portion of the letters spells qwerty and it would be very surprising to find out that you had a different style. As far as the power problem, you will need to order a new battery for the laptop from what it sounds like.
Posted on Dec 23, 2008
When we boot from hard disk it showing memory parity error.pls suggest the solution
format it
if u need more help email me :- aliumarahmed@hotmail,com
umex_umar@yahoo.com
umex_umar@hotmail.com
Jun 04, 2011 | Acer Aspire 4720 Notebook
Toshiba Portege 7200 i try to fomat it it does no format why
Windows won't as a rule allow format of an older system onto a newer system, it goes into protect mode.
If you are trying to format the laptop with say XP and you have XP with SP3 installed, because SP3 is newer than XP it will try to stop you from destroying the newer system. Matbe you are running out of space?
Processor
Mobile Intel® Pentium® III processor at 600 MHz featuring Intel® SpeedStep™ technology, 256 KB 2nd level cache, 100 MHz Front Side Bus
Memory
Standard 64 MB SDRAM, expandable to 320 MB
Hard disk
12.0 GB1) capacity, S.M.A.R.T. hard disk
Internal video modes
1,024 x 768 x 16.7 million colours Display
13.3" (33.8 cm) TFT active matrix colour display
Battery
Removable lithium-ion battery, 2-3 hrs battery life, with extra high capacity battery up to 5 hrs
Size and Weight
297 x 241 x 25 mm, 2 kg
Diskette drive
External: 3.5" 1.44 MB/720 KB
DVD-ROM drive2)
6-speed (max) with optional DVD Network Dock II, 12 cm (5.25") and 8 cm (3.5") disks, data transfer 3,600 KB/sec, average access time: 140 ms
Graphics adaptor
128-bit graphics accelerator, SVGA-/VGA compatible, AGP bus, 64-bit BiTBlT, 4 MB internal Video RAM
External video modes
640 x 480 x 16.7 million colours,
800 x 600 x 16.7 million colours,
1,024 x 768 x 16.7 million colours,
1,280 x 1,024 x 65,536 colours,
1,600 x 1,200 x 65,536 colours
Up to 85 Hz refresh rate
Keyboard
86 keys, 12 function keys, 8 dedicated cursor keys, inlaid numeric keypad, 8 Hot Keys, 2 Windows® keys, AccuPoint™ II, Euro key
Sound System
16-bit stereo Sound Blaster Pro compatible, 3D-wide mode, MIDI & Wavetable synthesis, volume dial, built-in speaker and microphone
BIOS
ACPI (1.0b) enabled BIOS, SM BIOS V. 2.3
Expansion
2 x PC Card Type II or
1 x PC Card Type III, CardBus support, memory expansion slots
Communication
Integrated international V.90 modem (56 Kbps data, 14.4 Kbps fax)
Interfaces
FDD connector, external monitor, USB, Fast Infrared Port, I/O adaptor connector, RJ 11 modem jack, headphone, external microphone, slot for Kensington Cable Lock
With I/O Adaptor:
serial, parallel, PS/2™ mouse and keyboard
With Docking Station (DVD Network Dock II):
serial, parallel, external monitor, PS/2™ mouse and keyboard, video out (NTSC/PAL), line-in, line-out, integrated FDD, includes built-in Ethernet (Wake-On-LAN and Service Boot support), 6-speed DVD-ROM drive
Power supply
Autosensing 100-240 V AC adaptor for world-wide usage
Casework
Magnesium alloy
Bundled software
Windows® 95 and Windows® 98 selectable installation, Windows® NT 4.0 on request (limited language versions available), PC Card management software, Toshiba utilities and drivers (all pre-installed on the hard disk)
Bundled hardware
External diskette drive, autosensing AC adaptor, I/O adaptor
Special features
Toshiba Hibernation and Resume, Toshiba Power Extensions, System Password Securities, HDD password on request, SecureSleep™, LANDesk Client Manager (LDCM), Wake-On-LAN and Service Boot support (with manageability software and LAN chip), Recovery CD, 3-year international warranty
Options
DVD Network Dock II, carrying case, extra high capacity battery, battery charger, 32, 64, 128 and 256 MB memory modules
Dec 31, 2010 | Toshiba Portege 7200CT Notebook
Shift key not working
You have 2 Shift keys on the keyboard. If the other shift key is working then the shift key that is not working is defective. You should consider replacing the keyboard on your laptop. There is no setting on Windows that can disable the shift key.
**Note : If both Shift keys are not working, Try to check if sticky keys feature on windows is on. Sticky keys should be disabled. To disable sticky keys, Click on start and Go into control panel > Accessibility Options, and under keyboard there is sticky keys. Remove the tick and click apply and OK.
**If "Use Sticky Keys" is unchecked, that means sticky keys is disabled.
May 29, 2010 | HP Compaq nc6000 Notebook
My letter Z and digit 0 are not working, pls what can i do
sounds like your keyboard needs to be replaced. If you depress the keys and they seem fine, but nothing comes up, then it may need reppacement...http://www.acer-laptop-battery.com/acer-aspire-5315-keyboard-as53152142-as53152191-as53152940-p-1408.html
Apr 01, 2010 | Acer Aspire 5315-2940 Notebook
Keyboard l key come off
there is a swivelling x-frame (like a deck chair) that clicks off the button or keyboard whichever it is fastened to This has four toggles and rectangular recesses which correspond to the keyboard and button underside, pls email me djzakm@hotmail.com if U have any probs but if you are gentle it can be clicked back on with care and patience zak
Oct 29, 2008 | Acer Aspire 5315 Notebook
Keyboard not work
Hello ,
As per what i understand from the issue you stated it has the possible solutions :
1. perform a Power Drain Test to drain out the accumulated static charge from within the notebook (happens with every laptop) - let the laptop be on , remove the power cord , remove the battery directly without directly shutting the laptop. The laptop will shut down once you remove the battery. Then press and hold the power button for the next 50 seconds continuously. Then attach the battery , then the power cord and power on the notebook. Check the keyboard . If no go , then
2. use an external keyboard . Attach the external keyboard to the laptop and boot into the normal OS desktop. Open Device Manager and check if there are any conflicts. Or else directly update/flash the BIOS by clicking on the link below :
www.hp.com
If unable to do so , please mail back giving the Serial Number of the laptop and the Product Number (loacted underneath the laptop on a white label beginning with s/n and p/n respectively ) and i shall send you the exact BIOS update/flash link .
Regards ,
Puloma
Aug 02, 2008 | HP Compaq Presario 2200 Notebook
Keyboard + toucpad freezes
Might seem ovious but you may want to try Acer support and look for a new Driver.. Also check under Control Panel...Mouse options... and also check device profiles to make sure windows isn't loading a "docked profile which may disable touchpad and laptop keybaord use.
Feb 21, 2008 | Acer Aspire 5670 Notebook
Acer Aspire 3004 keyboard and touchpad error
Just resolved same problem on Acer Aspire 5000 by removing the battery, then goto device manager and disable "Microsoft ACPI-Compliant Control Method Battery" you can then put your existing battery back into the latop with any problems with the keyboard and touchpad. Mad solution I know but it worked for me
Jan 22, 2008 | Acer Aspire 3000 Notebook
Acer Aspire 3610 Notebook Logo
132 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
