Question about Mitsubishi VS-45607 45" Rear Projection Television
Color convergence I have a Mitsubishi projection tv vs 45 a2 and the red color convergence can not be adjusted. The blue lines woks Ok. Help Thanks
  • Igerryb Dec 20, 2008
    I would like to know where I can get the schematic for my set so that I can order the proper part. Instructions for replacement of the IC will be helpful too.
    Thanks
    IGB
  • topcat743 Jan 05, 2009
    I have the same problem with my 45" mitsubishi vs 45607 but it is with the red and blue convergence I can not get them to align and it seems to be getting worse.
  • 41 Answers
The convergence IC's will need to be replaced along with possible resistors and/or fuses.
Posted on Dec 17, 2008
  • Ray Smith Dec 21, 2008
    There are links on this website that should be helpful as far as a repair manual goes. Basic solder skills and equipment. Be sure to replace the heat sink compound with fresh and that the IC's are either originals or good quality replacements. There are low quality knock offs out there so be careful when considering low priced IC's.
The Color On My Mitsubishi Rear Projection Tv model- WS-55908 looks to be off, picture looks blue and Yellow.
its sounds like the convergence on your TV needs to be adjusted. (this adjusts all of the color guns in the back of the tv to line them up again, when they get off, you start to get yellow blue or red halos around objects in the picture. In the setup menu on your TV under picture or Display there will be an item that says "convergence" follow the instructions in there so all the crosses on the screen no longer have colored halos anymore.
Mar 10, 2011 | Mitsubishi WS-55908 55" Rear Projection...
Mitsubishi big screen rear projection tv the blue
The tv 100% have convergence problems,it dead.If any colors lines don't matches or stay in the - + convergence grid.The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.The tv conververgence board must have these parts changes to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Dec 11, 2010 | Mitsubishi Televison & Video
Left convergence on mitsu vs-60609
Convergence IC's inside of your TV are nearing end of the life. If during adjustments that you made Red and Blue was moving in all directions (left, right, down, up) than resistors and fuses still probably OK. IC's (part number will start with "STK" and they attached to huge aluminum radiators) have to be replaced and fresh heat sink compound have to be applied.
After that convergence adjustments should not be a problem. And color will stay together for another several years.
regards.
Russ.
Apr 04, 2010 | Mitsubishi VS-60609 60" Rear Projection...
Mitsubishi VS-55609 distorted Picture Flickers
This is a convergence problem and not really a DIY Many amateurs try it to save money but end up spending more on it than a professional. There are dozens on here that managed to fix it for a day or two only to have it fail again.
cost of fix about $300.
Please rate my help++++Thanks for using FIXYA
Mar 24, 2010 | Mitsubishi VS-5059 50" Rear Projection...
Blue convergence is shifted right slightly
CHECK FOR THE SUFECE MOUNT CAPACITORS AT THE SMALL CONVERGENCE CIRCUIT BOARD
Jul 13, 2009 | Mitsubishi VS-60609 60" Rear Projection...
Looks like its in 3d and cant get red , blue , and green colors to line up.
In the tv menu there is a convergence setting. This is used to line up your colors.
Jul 01, 2009 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi VS-4561 picture curved inward
Its Your Convergence Chips!. And Maybe a few Resisters!. Common Problem with this kind Of Set!.....
Jun 30, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi convergence Problem
You only have 3 colors Red, Blue, and Green. No black or yellow. I would say look for self test diagnosic on here or other sites.
Jan 13, 2008 | Mitsubishi VS-60607 TV
Red convergence wont move
if the red line is blurry and you have adjusted the screen focus control and does not work then you prob have a bad red CRT or bad red CRT fluid.........
convergence STK have nothing to do with the red being blurry
Dec 09, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi VS-45607 45" Rear Projection Television Logo
126 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
