Question about Sanyo DS25390 TV
Losse connection Maybe
I have to hit the back of my t.v. to get the picture back on. What could that be and can I fix it myself?
  • 42 Answers
I say you have a lose board on the crt picture tube neck also is where the filament pins which are not making connection check and solder all connections on pix board also plug the board on the pins good and tight must be pluged on crt all the way
Posted on Dec 17, 2008
I have a toshiba model CX36H60 and the picture keeps going black. I have the hit the menu button on the remote to get the picture back. This is happening every 3 to 4 minutes. When I get the picture back...
Your tv has a defect ,maybe in the board, maybe its only loose connection. you need to sesolder all the parts in the main board .but you need a qualified technician to fix your problem.
Jun 28, 2010 | Televison & Video
The TV picture just goes black no matter what channel you are on. The picture only comes back when you turn the tv off and back on. What is this? Can it be fixed easily?
This issue is one of the boards in the tv is lossing raster, they call this the sustain board, Do not shoot the messenger as the tv is not in frount of me but I feel its the sustain. But have it checked out it can be fixed but it is going to hit your pocket book a few hundred dollars.
Please rate, leave feedback for you free answer, Thanks
Jun 19, 2010 | Pioneer PDP-4271HD 42 in. Plasma...
The television once on has good picture then black rectangular blocks the bottom half of the screen showing only half the picture, very annoying. how can i fix this myself?
look for the vertical section of the printed circuit board.there is a vertical driver ic and it is maybe bad...... either the soldering,or the ic.
if you bang on the tv and the picture regains deflection,there is a bad solder joint or connection.
there are a few capacitors too 100mf 25 volt 4.7 50v also 22mf at 50v
Jul 17, 2009 | Aiwa Televison & Video
Compaq presario V2110US backlight
If the backlight is an intermittent problem, it is likely that the video connector and or the backlight connector needs reseating. There are usually two connectors that connect the LCD display to the motherboard. You need to pull apart your laptop to reveal these connectors (these connectors are usually near the top edge of the laptop). Unplug and reconnect these connectors to re-establish a good connection.
Take note of the locations of the various screws when you remove them (some vary in length) so you can put them back in their correct location.
Jun 01, 2008 | Compaq Armada M700 Notebook
Photo- samsung m500
Hi the Best thing you do is go to the nearest phone repair it maybe your phone robin wire connection inside your phone is full of flux and contaminants so that it trigger the connections that maybe grounded
Mar 16, 2008 | Samsung SPH-M500 Cellular Phone
Sanyo TV stretches outwards and shakes
If the picture is closing (top to bottom) and goes back to normal when you hit it you probably have a bad solder connection on IC501 (location number) the vertical deflection IC on a metal heat sink. If you mean outwards as in side to side as it looks in the picture, I don't know specifically where to solder but get a magnifying glass and look for suspected bad solder connections. Look for the word width if it is there. It is good that you a confident in soldering.
Dec 27, 2007 | Sanyo DS27910 27" TV
Mitsubishi 6043A Loss of color
Sounds like many different problems maybe related thou. You say 6043a but you are under WD-62327. So this info is for that.1. Suspect the Light Engine part # 939P977020 also you could need.. Suspect the Signal PCB part # 930B923002 if no video keeps up
Aug 27, 2007 | Mitsubishi WD-62327 62" Rear Projection...
TV picture problems
this modle has a bad solder connection near the horizontal o/p transistor that causes the picture to fade in & out.the bad solder connection is on a small coil. the coil winding is typically red. looking at the back of the tv, the flyback has the rid wire going to the top of the tube, the horizontal o/p transistor is to the left & in font of the flyback, it's attached to an aluminum heatsink. directly in font of this heatsink is the coiul you are looking for, it should have a location id of L14XXX or L4XXX if I remember corectly. good luck.
Dec 08, 2006 | RCA F27440 27" TV
Loss of picture and sound repeatedly
You already hit the nail in the head,the problem might be the actual conector loose inside the set or the tuner has loose conections to the main board,the shell of the tuner is the ground make sure the conections are solid,if you are familiar with tv service this will help but if you are not too familiar be safe and call for help,right now it should not be expensive.
Oct 04, 2006 | Panasonic PV-C1321 13 in. TV/VCR Combo
Televison & Video Logo
29 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
