Question about GE Profile Spacemaker XL 1800 36" Microwave Oven
GE Spacemaker XL1800. The power shuts off when I cook something for more that about three minutes. It will eventually power up some time later on when I turn on the light. There's about 6 inches
GE Spacemaker XL1800. The power shuts off when I cook something for more that about three minutes. It will eventually power up some time later on when I turn on the light. There's about 6 inches between microwave bottom and stove back and it sit's about 4 feet from the floor? Help.
    Master:
  • 665 Answers
5 Suggested Answers
SOURCE:
MicrowaveSvc
  • 9174 Answers
SOURCE: GE spacemaker Profile XL1800 vent fan will not shut off
It may be a bad door switch, a loose door switch mount, or a problem on the control panel, such as a sticky relay.
I would suspect a sticky relay first, but the door switches should be checked.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on Fixya: http://tinyurl.com/yzjozk
If you need your control panel assembly (smart board) repaired, we do that for $39.95 nationwide.
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Posted on Dec 02, 2007
MicrowaveSvc
  • 9174 Answers
SOURCE: Shuts itself off mid cooking cycle -- as if unplugged; then after 5 minutes or so turns itself back on as if it was just plugged in (forgetting all previous settings)
If you just put the fan blade back on, it will almost certainly fall off again.
The best bet is to slightly rough up the contact area of the shaft with sandpaper and use a little super glue to hold the blade assembly on the shaft, and let it set a few minutes before using it.
I always recommend that you use the hood vent exhaust fan when cooking on the stove top to keep heat, steam, and grease out of the controls.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
d:%5cele%5crepair%5cmicrowave%5cge_hotpoint%5cmini_manual_behind_grille_small.jpgdee77f7.jpg
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
[email protected]
http://www.microwavedisplay.com
Posted on May 23, 2009
MicrowaveSvc
  • 9174 Answers
SOURCE: I have a GE Spacemaker XL1800 over stove does not cook
This is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If the switch mount is broken, it's usually more economical and safer to add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
If you only need a switch, you can order a universal type here for $5 postpaid.
Posted on Apr 20, 2010
SOURCE: The power shuts off when I cook something for more
http://www.ehow.com/how_4704737_fix-ge-spacemaker-microwave.html
Posted on May 05, 2010
How to set at 50% power?
Hit power, hit 5 all after u set cook time.
Mar 20, 2015 | GE SpaceMaker Microwave Ovens
I have a GE Sapcemaker XL1800. Last night when I went to push express cook for one minute all I got was a small roar and after the one minute was done, my sandwich was not heated. We tried it several more...
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Feb 13, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
GE SPACEMAKER XL1800 IS NOT HEATING FOOD - GIVING "SENSOR ERROR" ON DISPLAY. I am a handy guy capapble of fixing if you can help me out w/the part I need
hello,
if you have a sensor, it means, the door was opened before steam could be detected. Do not open the door until stream is sensed and time is shown counting down on the display.
Steam was not detected in the maximum amount of time. Use Time Cook to heat for more time.The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
thanks.
Jun 16, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Not heating up anything
Tat would be a magnetron problem. The magnetron is what provides the heat
Apr 30, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE SPACEMAKER XL1800 MODEL: JVM1860BF001
MAGNETRON, 99% of the time with your complaint
Nov 20, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
[email protected]
May 20, 2009 | GE Profile Spacemaker Over-the-Range...
GE Profile XL 1800 Microwave overheating?
ge spacemaker XL1800 (JVM 1870BF02) doesn't heat, lights, turntable works.
Mar 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Spacemaker XL1800 runs but doesn't heat.
I think you should check the fuse first that runs the magnatron if the fuse is good that means the magnatron is bad! but if its only the fuse then you save time and money!
Jan 21, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Dec 02, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE Profile Spacemaker XL 1800 36" Microwave Oven Logo
218 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
vince
Jimmy
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
