Question about Sanyo DS25390 TV
I have to hit the back of my sanyo for the picture to back on. It used to work but now when i hit it it wont come on anymore
  • 42 Answers
You have proply have totaly knott off the crt board and needs to be replug on the crt making sure all pins are straight and push board on tightly and also check the pins for solder joints bad resolder
Posted on Dec 17, 2008
No picture there used to be lines at the top
It sounds that there is some loose contacts with any cable connectors, or to any solder terminals at the circuit board. It will be best to contact any service technician, or the authorized service center for Sanyo. Gopakumar Gopalan Google
Feb 24, 2014 | Sanyo DP46848 LCD TV
My tailgate wont open anymore with the electric button, and there is no place to use my key to open it on the back? It use to work when I hit the button a million times but that wont work anymore either...
Jumper the switch harness connection that attaches to back of switch with a paper clip. if it opens, replace switch.
If on the other hand you hear the solenoid each time you press the button, adjust the catch. Usually outward.
Jan 24, 2012 | 2000 Jeep Grand Cherokee
Tv worked well last night...turned on this am.. sound but no picture
beachbabyfou, Use Sanyo warranty first, if covered. If not , then you or a electronics technician will need to troubleshoot and repair the unit's "switch-mode-power-supply" board. Partial power supply failure and unit can't "light-up" the cold cathode fluorescent lamps anymore. Is unit CCFL or plasma? If CCFL then possible same type problem as computer ccfl back-lit lcd monitors. Read some of the stuff in my fixya profile (older, higher pages) for more info. How old is unit? What is DOM? post back info you find. Yes, it could be failed capacitors on printed circuit board. Only rate this response if it helps you. 12fixlouie
Apr 05, 2010 | Sanyo DP32648 32 in. LCD TV
The camera wont take pitures, every time you hit the button to take the picture it says Write ok! on the screen and wont take the picture. Sanyo VPC-E870 Digital Camera
hi try to reset ur camera...To do such reset, turn on the camera and hold the menu button down for longer than 5 seconds. A message should hopefully come up on your LCD asking if you want to reset the camera. Select Yes...
thank u!!!
rate me!!
Jul 15, 2009 | Sanyo DSC-SX500 / VPC-SX500 Digital Camera
The focus lens was hit by a basketball and it won't take pics.
Have you tried a different lens on the camera almost any lens with the same mm size will work. If it still does not take pictures with another lens. You should take it in for service.
Dec 29, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Sanyo s750 camera problem my cameras button to take a pic wont work
Mine dropped two feet on carpet, and it won't turn on. How do you access internal memory?
Mar 07, 2008 | Sanyo Xacti VPC-S60 Digital Camera
My ps2 wont work on the TV
so back your tv input says yellow red and white should be sterio in unless its mono tv then just use white then in front hit ch down past 2 to go into inputs to see ps2 ok
Feb 10, 2008 | Sanyo DS31590 31" TV
TV wont shut off
If you hit your tv in on/off switch panel the swicth need to replace but if you use remote control you system IC or Croma IC are defective.
Oct 13, 2007 | Sanyo DS13204 TV
Straight line picture
If you were able to tap on the set to get it working, then it means that the solder joints on the vertical output IC are cracked and loose. This is very common on those sets. Now, the pins of the IC could be so loose that they just wont work anymore, and simply resoldering the pins of the IC will cure your problem. However, it could also be that the loose pins have caused the IC to short out inside, in which case the IC will have to be replaced and most likely a small resistor in its power supply too. If you do not have experience working on things like that in TV sets, allow a qualified tech to handle it for you.
Aug 30, 2007 | Sanyo DS25390 TV
Televison & Video Logo
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
