FixYa.com
Tags:
Emerson 683-0254B System
DVD acting up
posted by lbrogdon on Mar 26, 2007
When I am watching a DVD the movie tends to pause itself without me pushing the pause button. It does it for about 2 seconds then continues to play. You can hear the dvd spinning then pause when this happens. What should I do?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Mar 26, 2007
Not Rated (0)
snakehead
Rank:Wiz Wiz
Rating: 81%, 833 votes
if it does it with all the dvd you play then you are starting to have problem with your microchip or the lens needs to be adjust or replaced.take it to a tech you problem is intermitent.so it will be very dificult but from what i am saying to you the tech can go ahead and replace the components the strip leading from the lens should be replace also they like to go bad.good luck.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Home Theater Systems problems?
LG/LF-KP5931 DVD/CD Player...
Hi I have played around with... Answer This...
panasonic dvd home theater...
Need directions on where... Answer This...
Digital Optical input on...
Hello- I can't get the digital... Answer This...
SA-HT640
I always get an error code F61... Answer This...
Using HDX275
Hi Ravi, I hope u r using sony... Answer This...
Repair Service
Find Home Theater Sys. Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
