Question about D-Link AirPlus Xtreme G DI-624 Wireless Router (DI624RE)
Wireless Router Signal Strength
My router is a couple years old. Has worked perfectly. I just moved to a new home and hooked up my cable. Now my signal strength fluctuates from medium to low, and I am right next to the router. I used SpeakEasy.net to test the download speed. Its 5000kbs connecting directly to the modem, and only 400kbs using D-Link. What can I try to fix the problem?
  • 1 more comment
  • mmorrison13 Jan 03, 2009
    I have heard that routers can get channel interference, because everyone nowadays is using the same channel (#6). I have tried changing the channel, but the router doesn't allow me to change it from anything but #6. I may try the antenna.
  • eecom May 11, 2010
    If the computer and router are the same as before, and you're right next to the router, it's possible something has taken a knock during the move. Alternatively, if there is a DECT phone or similar device near the router - this would disrupt the signal.
    Just a couple of thoughts. All the best to you.
  • Teis Thomsen
    Teis Thomsen May 11, 2010
    Your new home, have iron forced concrete walls, right?
    Well, signals have a hard time going through these walls,
    So, either move, or find a new place for the router
  • 192 Answers
If is more signal strangth try replacing the atines with an upgrade antinas which you can buy from the routers website
Posted on Jan 03, 2009
Can't connect to server. Error code 52230 comes up.
Here are some troubleshooting ideas:
Error Code: 52230
Unable to connect to your wireless network
Likely cause: Your router or Internet Service Provider is having difficulty assigning a DNS or IP address to the Wii.
How to fix: Manually assign an IP address and DNS to the Wii.
The address below will show you how to manually assign an IP
http://en-americas-support.nintendo.com/app/answers/detail/a_id/3068
Other suggestions:
  • Did this connection used to work but has suddently stopped? "Power cycle" your router by unplugging it from the power outlet. Wait a few minutes, and plug the router back in. Wait a couple of minutes for it to initialize, and try to connect the Wii console online and test for proper response.
  • Check for wireless interference, which can affect the signal strength to the Wii console.
  • What to Do:
    • Check the location and distance of your wireless router.
      The further a device is from your wireless router, the weaker it's signal strength will be. If your wireless signal has to pass through any walls or floors, this will also weaken the wireless signal strength. Move the router to a central location within your home and as close to your system as possible.
      Additionally, if your router is on the floor, moving it to a higher location can improve the signal strength.
    • Change the wireless channel your router is broadcasting on.
      Wireless routers can broadcast on a variety of channels. Sometimes a specific wireless channel may experience interference from other devices and routers nearby. How to
    • Move any metal objects or electronic devices away from your Nintendo system and wireless router.
      Metal objects and electronic devices may interfere with wireless signals. If you have any of these, such as filing cabinets, speakers, power strips, glass, or cordless phones, next to your system or wireless router, move them away.
Nintendo Customer Service Nintendo Wi Fi Connection Error Code Results
Sep 30, 2015 | Nintendo Wii Console
Cant get wifi unless I am a couple of inches from router. All other wifi devices work perfectly. I even downloaded the latest driver directly from Intel and problem still exists.
Having a wireless Internet signal in your home allows multiple devices to use the same Internet connection without having to run lengths of Ethernet cable to each device. Given that the wireless network is transmitted over the air, the consistency of your Internet connection depends on the strength of the wireless signal. If wireless signal strength is not strong enough to give you a consistent Internet connection, there are a few simple steps for finding the problem and improving your signal strength.
Reset all devices. The majority of Internet issues, including poor wireless signal strength, are very often solved by a simple power cycle of all the devices in the network. Locate the power cords of both your modem and your wireless router and remove them (if you use a modem/router combination, simply unplug the power to that device). Leave them unplugged for a full 30 seconds, plug them back in and restart your computer. When your computer fully reboots, check your wireless signal strength to see if it has improved. If it has not, further troubleshooting is required. Move your computer closer to your router, or your router closer to your computer. Wireless routers do not have unlimited range. One reason your computer may be getting a weak signal strength from your wireless network could be because your computer is simply outside of the router's range. Typically, ISPs (Internet Service Providers) will install your modem in one specific location in the house and the modem will not work at other locations, so moving the modem or modem/router combination may not be a possibility. If this is the case, you may need to move the computer to a location that is within the range of the wireless router's broadcast. If you still get poor signal strength, your router may be experiencing a malfunction. Contact the technical support department of your router manufacturer. Router malfunctions often are not the result of a bad or broken router, but of something much simpler, such as the router's needing a firmware upgrade or an incorrect setting on the router's internal setup. If your router manufacturer is unable to improve your wireless signal strength, it may be time to purchase a new router. Purchase a new router. Wireless routers are priced in part based on how widely their wireless signal broadcasts (in other words, the more expensive the router you buy, the larger a wireless signal the router will broadcast). Included in the packaging of each wireless router is the approximated range, in square footage, of that router's wireless network. A good rule of thumb is to know the square footage of your house and buy a router that can accommodate that square footage. That way, as long as the router is functioning properly, you will have strong wireless signal strength throughout your entire home.
Mar 01, 2013 | Samsung 19628 NP300V5A-A0AUS NP300V5AI
Poor signal with WiFi on my zeepad
Reset all devices. The majority of Internet issues, including poor wireless signal strength, are very often solved by a simple power cycle of all the devices in the network. Locate the power cords of both your modem and your wireless router and remove them (if you use a modem/router combination, simply unplug the power to that device). Leave them unplugged for a full 30 seconds, plug them back in and restart your computer. When your computer fully reboots, check your wireless signal strength to see if it has improved. If it has not, further troubleshooting is required. Move your computer closer to your router, or your router closer to your computer. Wireless routers do not have unlimited range. One reason your computer may be getting a weak signal strength from your wireless network could be because your computer is simply outside of the router's range. Typically, ISPs (Internet Service Providers) will install your modem in one specific location in the house and the modem will not work at other locations, so moving the modem or modem/router combination may not be a possibility. If this is the case, you may need to move the computer to a location that is within the range of the wireless router's broadcast. If you still get poor signal strength, your router may be experiencing a malfunction. Contact the technical support department of your router manufacturer. Router malfunctions often are not the result of a bad or broken router, but of something much simpler, such as the router's needing a firmware upgrade or an incorrect setting on the router's internal setup. If your router manufacturer is unable to improve your wireless signal strength, it may be time to purchase a new router. Purchase a new router. Wireless routers are priced in part based on how widely their wireless signal broadcasts (in other words, the more expensive the router you buy, the larger a wireless signal the router will broadcast). Included in the packaging of each wireless router is the approximated range, in square footage, of that router's wireless network. A good rule of thumb is to know the square footage of your house and buy a router that can accommodate that square footage. That way, as long as the router is functioning properly, you will have strong wireless signal strength throughout your entire home. Hope this helps.
b>
Dec 13, 2012 | Computers & Internet
I have the router right by my PC, it appears connected but no signal strength at all (no bars) what is wrong?
try changing the wireless channel on the router and see if that makes any difference.
Open the setup page of the router.
Go to wireless tan and change the standard channel to 11. save the settings.
You can also try updating the drivers of the wireless adapter on your computer.
If your router is too old then you must upgrade the firmware on the router.
See how to upgrade Linksys router firmware
Mar 21, 2012 | Linksys Wireless-G Broadband Router
I have an old wannadoo live box on orange worked fine until I moved home. Orange have confirmed that internet has now been set up at my new address and I kept my old phone number. The LAN into my...
i assume you have DSL connection through phone line . double check the cables see if they are connected properly betwee the modem and router etc ..if its all connected then reset your router by pressing littile tiny button at the back of Router and apply new WPA2 password and try connect .
May 12, 2011 | Computers & Internet
I purchased mu HP Officeject 6500 Wireless within the past 12 months. I have had multiple instances where the printer stops scanning and sometimes stops printing. My tech guyhas fixed it 4-5 times and it...
Might be a problem with the router, or router location. Check the signal strength from the printer.
If your signal only has 1 or 2 bars, it could lose its connection very easily.
You should be able to move your modem and router, anywhere in the house, and it will not erase settings. Just have to have a strong cable signal going to the modem.
If the signal strength is not the problem, your router could be getting hot and cutting out. Or getting old and going bad. Try also resetting the router and reconfiguring it.
May 03, 2011 | HP Officejet 6500 Wireless All-in-One...
I lose connection every few mintutes when useing my router. If I hook up direct I have no problem. What can I do about this? My router isnt very old its s/n is F38K493007846 Model DIR-615
Hi, sorry not a solution, I have exactly the same problem with the same router, even when my laptop is next to the router with excellent signal strength if just drops the connection every few mins, Virgin, who I got the router from claim it is my laptop despite it working perfectly well on other wireless networks.
Jan 26, 2010 | D-Link DIR-625 (790069292637) Wireless...
After shutting down ibm lenovo r61 wireless will not connect to router until doing repair. are there any settings to look for
The reason why you need to do a repair is because the wireless router couldn't issue the wireless a IP address to the laptop at the time of booting up. This is a common problem.
Check the signal strength of the wireless card, if it is in the mid range move the laptop or reposition the wireless router so you get a better signal strength.
Also power off the wireless router, wait 1/2 min and power up the router again. This is a suggestion, do this once a month. The wireless router will get a new IP address from your ISP, and if someone locks onto your old router's IP address then it is no longer available to them when the router gets a new IP address.
Jul 13, 2009 | IBM ThinkPad T30 2366 Notebook
Router not working as well with D620 as with my older D610
If your router has the external antenna the signal will increase when you point the antenna in the direction where the computer is used the most. It always helps to locate the router in a central area and on the upper floors of a house because the broadcast signal falls like rain. Another trick to try is to change your broadcast channel in the router, the normal default is channel 6. Each channel broadcasts at a slightly different frequency. Hope this helps...Tennis123
Nov 05, 2008 | Arris Wireless G Broadband Router (wr850g)
D-Link AirPlus Xtreme G DI-624 Wireless Router (DI624RE) Logo
443 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
