Question about Mitsubishi XD480U Multimedia Projector
What 2 buttons other than the Power button
After replacing the lamp in an XD480U projector, what are the 2 buttons needed when pushing the power button, to reset the Interval of lamp replacement time? The buttons to choose from are: Auto position (up arrow), Computer (left arrow), Keystone (enter), Video (right arrow) Menu, and down arrow.
  • keplerg Dec 17, 2008
    The Right & left arrow buttons.
    Sniper:
  • 50 Answers
To reset the lamp operation time on a Mitsbishi XD480U:
Plug in the power cord, turn on the lamp, and press the Left Arrow button, Right Arrow button, and POWER buttons on the control panel ALL AT THE SAME TIME, holding them all down for about three seconds.
Notes:
•Unless these three buttons are pressed at the same time, the lamp operation time isn't reset.
• Make sure that the STATUS indicator is lit twice and the lamp operation time is reset successfully.
• The projector doesn't turn on if the lamp cover isn't attached securely.
• Be sure to reset the lamp operation time whenever you replace the lamp.
• Do not reset the lamp operation time unless you replace the lamp.
Posted on Dec 17, 2008
2 Suggested Answers
  • 50 Answers
SOURCE: After replacing the lamp in
Notes:
Why does my Dell 1510X Projector not shut off when I push the off button ?
This projector as with most high power projectors will have a cool down period for the lamp once the power button is pushed from on to off. For this model, the cool down period is 120 seconds after which the unit will fully power down. You can override this cool down period by pushing and holding the power button for 1 seconds. If you use this procedure though, you should not power up the projector again for at least 60 seconds to allow the internal temperatures to stabilize.
Feb 27, 2015 | Dell 1510X Projector Projector
Our projector has said replace lamp for approx. 1 year. We did and it still saying to place lamp. Also it stops projecting after about 5 minutes and then 10 minutes later we are able to use it again for...
You need to reset the LAMP RUNTIME counter
1. Press the MENU button to display the menu screen
2. Press the UP and DOWN arrow buttons to select the "OPTION" menu
3. Press the ENTER button and then press the UP and DOWN button to select the LAMP RUNTIME
4. Press and hold the ENTER button for approximately 3 seconds
5. The LAMP RUNTIME screen will be displayed.
(Note: press any button other than the Power button to cancel the LAMP RUNTIME screen)
6. Press the POWER button to turn off the power
7. After the POWER button on the projector illuminates red you restart the projector
and check the LAMP RUNTIME counter it should be "0"
Nov 24, 2010 | Panasonic PT L735U Multimedia Projector
Need to reset lamp. replaced lamp and installed new lamp.
Press RESET, <, >, ENTER keys on remote within 5 seconds to reset lamp timer.
Jul 29, 2010 | Sony VPL-CX86 Multimedia Projector
My ask proxima c180 does not power up. I have confirmed the power cable is firmly inserted. When I press the power button nothing happens
take the lamp door off and manually hold in the safety switch.(if you look at the lamp door and see the post, the post is what pushes the switch in normally) while holding the switch in, push the power button. try the button on the projector and the remote. if the unit powers up it means your lamp door is miss-shapen from the heat from the lamp. if this didn't fix you problem, you need a power supply.
May 27, 2010 | ASK Proxima C180 Multimedia Projector
How do I remove the lamp on a optoma ep716?
Lamp Replacing Procedure:
  1. Switch off the power to the projector by pressing the Power/ Standby button.
  2. Allow the projector to cool down at least 30 minutes.
  3. Disconnect the power cord.
  4. Use a screwdriver to remove the screw from the cover.
  5. Push up and remove the cover.
  6. Remove the 2 screws from the lamp module.
  7. Pull out the lamp module.
  8. Replace the lamp module in reverse the previous steps.
Nov 11, 2009 | Optoma EP716 Multimedia Projector
I got a free sharp notevision PG-m20x. I plug it
if you don't hear a high-pitched whir, the colorwheel needs replacing. if you do hear it, the lamp may need replacing. if the lamp is new, there is a power supply problem.
Sep 04, 2009 | Sharp Notevision PG-M20X Multimedia...
I replaced the bulb but it still won't light up. The lamp operation time has been reset
you'll have to replace the ballast. but if there are no leds lit, you might have to replace the power supply.
Aug 15, 2009 | Mitsubishi XD480U Multimedia Projector
Optoma EP755 new lamp when power standby button
you need to reset the lamp timer, usually done by holding some buttons while turning on
Mar 10, 2009 | Optoma EP750 Multimedia Projector
After replacing the lamp in an XD480U projector, what are the 2 buttons needed when pushing the power button, to reset the Interval of lamp replacement time? The buttons to choose from are: Auto position...
Notes:
Dec 17, 2008 | Mitsubishi XD480U Multimedia Projector
No lamp
whats your location, The power supply is faulty, but fairly easily repaired, if you send it to me, I will sort it out
Feb 13, 2008 | Hitachi CP-X327 Multimedia Projector
Mitsubishi XD480U Multimedia Projector Logo
1,261 people viewed this question
Top Mitsubishi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
