Question about Canon Office Equipment & Supplies
Dear sir after stripping and cleaning the print head of my canon pixma pro 900o it refused to print. Upon examining the pins at the rear of the print slider i noticed that they were bent down at an angle of about 45 deg.Are they sopposed to be bent down or should they stick out at right angles
  • berniarem Dec 17, 2008
    MANY THANKS .I CAN NOW LOOK ELSEWHERE AND MAY GET BACK TO YOU
  • Canon Master
  • 6,487 Answers
The pins are fine and you just need to do a dep cleaning on the printhead to make the printer work fine again...
Posted on Dec 17, 2008
    Genius:
  • 1,269 Answers
The bent pins are fine because that the way they were created. Print head cleaning is critical in printer. You should know the risk of cleaning it. It might have been scratched hard. Please double check the printhead for any possible loose connection.
    Sergeant:
    Novelist:
  • 327 Answers
No no they should be bent down they r proper.but its the problem of head getting clogged or the brown dotted circuit is gone short.needs replacement.
  • 10,594 Answers
If all pins are bent in same degree , then its ok
Canon mg 3550 alignment problem?
Dear sir
I have encountered this problem on other printers. Try to clean the ribbon sensor found just above the head. It is a plastic digitizer strip used to align the head movement. Usually it has some grease on it just clean it with some cloth very gently.
Mark Borg
May 27, 2014 | Canon PIXMA MG3550 Inkjet Multifunction...
My printer only prints a 5/8" wide strip across and skips about the same horizontal width. In other words for some reason it looks like a zebra!
Hi sounds as if you have a partly blocked print head
do a clean from your PC in printer properties if that's no good replace the print head by going to amazon and looking for Canon PIXMA MX850 print head, easy to fit but not cheep
hope this helps yours Ian
Mar 17, 2011 | Canon PIXMA MX850 Multifunction Printer
P2 error
P02 (Carriage error)
  1. Make sure no foreign material stuck to the print head railway.
  2. Clean and check the print head encoder strip cable (timing **** film or encoder strip is a white line on the back of the box set of ink lines may be missing or mess up the ink.
visit this link for more info
http://pcmediks.blogspot.com/2010/10/canon-pixma-mp258-error-code.html
Dec 28, 2010 | Canon PIXMA MP240 All-In-One InkJet...
I have a Canon Pixma MP270 and I can only print in colour both the black and colour lights are lit up on the printer
f print quality does not improve by the standard cleaning of the Print Head, clean the Print Head deeply. Cleaning the Print Head deeply consumes more ink than the standard cleaning of the Print Head, so clean the Print Head deeply only when necessary.
1. Make sure that the power is turned on.
2. Clean the Print Head deeply. (1) Press the g0022565.png (Maintenance) button repeatedly until y appears. g0054776.png
(2) Press the Black or Color button.
The machine starts cleaning the Print Head deeply. Do not perform any other operations until the machine completes the deep cleaning of the Print Head. This takes about 2 minutes.
3. Check the print head condition.
When the deep cleaning is completed, the LED returns to the copy standby mode. To check the print head condition, print the nozzle check pattern.
See " Printing the Nozzle Check Pattern".
If the problem is not resolved, turn off the power and clean the Print Head deeply again after 24 hours.
If the problem is still not resolved, replace the FINE Cartridge with a new one.
See " Replacing FINE Cartridges".
If the problem is still not resolved after replacing the FINE Cartridge, contact the service center.
Print the nozzle check pattern to determine whether the ink ejects properly from the print head nozzles.
NOTE If the remaining ink level is low, the nozzle check pattern will not be printed correctly. Replace the FINE Cartridge whose ink is low.
You need to prepare: a sheet of A4 or Letter-sized plain paper
2. Load a sheet of A4 or Letter-sized plain paper in the Rear Tray.
3. Open the Paper Output Tray gently, and open the Output Tray Extension.
4. Print the nozzle check pattern.
(1) Press the g0020617.png (Maintenance) button repeatedly until A appears. g0054754.png
The nozzle check pattern will be printed.
5. Examine the nozzle check pattern.
See Examining the Nozzle Check Pattern.
Examine the nozzle check pattern, and clean the Print Head if necessary.
1. Check if there are missing lines in the pattern (1) or horizontal white streaks in the pattern (2). g0054755.png (1) Check if lines are missing in this pattern. If yes, the cleaning is required.
See " Cleaning the Print Head".
(A) Good
(B) Bad (lines are missing)
(2) Check if horizontal white streaks are present in this pattern. If yes, the cleaning is required.
(A) Good
(B) Bad (horizontal white streaks are present)
Post back!
Oct 26, 2010 | Canon Office Equipment & Supplies
Printing lines not straight and letters shadowed. Help!
Open the cover over the print head and *carefully* inspect the clear thin plastic strip that runs from left to right near the print head. If you see any lubricant (white grease) on this encoder strip, it needs to be cleaned off.
1. With the cover open and the print head in the center, unplug the power cord. This will allow you to gently move the print head left or right.
2. With a cotton swab wetted with rubbing alcohol, *gently* wipe the grease spots from the encoder strip. (Be VERY CAREFUL you don't dislodge the strip.) You may need to move the print head to the left or right to get all areas cleaned.
3. Let the alcohol dry off completely. With the area clear of cleaning tools, debris, and fingers, plug the power back in.
4. Try a test print.
Jun 17, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Print head
I encounter exact same problem. What I did was took out the print head and clean the print head with Qtips with alcohol. To locate and remove print head, follow the instruction at Canon's PIXMA MP830 website and choose the tab "Support & Service" type "rseating the Print Head"
You'll be seeing
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=123&modelid=12804#SupportDetailAct
Basically, printer head is inner carton where ink cartridges sit.
Above link shows pricicely how to remove the ink cartridge.
Above link's instruction says, Caution: do not touch print head nozzles<1>
But, I just went ahead and clean the print head nozzles with rubbing alcohol soaked Qtips.
After completely cleaned and dried, I reinstalled print head, reinstalled ink cartridges,
closed all the cover. It went back working perfectly.
Sep 18, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Printer refuses to work
You will need pro help with this - so call the man meanwhile browse through this list http://www.fixya.com/support/p360552-canon_pixma_ip4000_inkjet_photo_printer/solutions
May 17, 2007 | Canon PIXMA iP4000 InkJet Photo Printer
old marine
old marine
