Question about Canon FAXPHONE L80 Laser
Not able to receive a fax, but able to send a fax
Toner is good, all functions are operational
  • 124 Answers
Welcome FixYa! I'm the expert that has chosen your issue to fix. Now let's get started!
I believe the issue is that your machine is set to Manual Mode. The manual mode is used where you have only one phone line and you only receive occasional faxes. In this mode, the machine won't automatically take faxes, but you can send faxes fine.
If this is the case, and you receive a lot of faxes and you only want to receive faxes only, you will need to change your mode to Fax Only, as follows:
  1. Press Function, then
  2. Press Data Registration, then
  3. Press Set, then
  4. use up/down arrows to find RX Settings on the display, then
  5. Press Set (ECM RX will Display), then
  6. use up/down arrows to find RX Mode, then
  7. Press Set (Fax/Tel AutoSw will display, then
  8. Use up/down arrows to find (Fax Only Mode), then
  9. Press Set (Incoming Ring should be displayed), then
  10. Press stop/reset to return to standby mode.
  11. Confirm that display reads (Fax Only).
The machine will now treat all incoming calls as faxes and ignore all voice calls.
Thats about it! Thanks again for using FixYa.com
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation. If it hasn’t, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am at your service.
Posted on Jan 31, 2009
How to send a fax
Sending and receiving faxes online is simple using
Fax Internet Service - (just for USA)
Aug 29, 2014 | Brother MFC-215C All-In-One InkJet Printer
Unable to receive faxes. Able to send and cartridge printing OK
There can be a few things wrong lets take it step by step
1)Receive mode,your receive mode must be set correctly.If you don't have a tel connected to it, you cant use it as a Manual receive mode,it must be set on Fax only.If there is a telephone connected to it and it is set on manual mode make sure your Incomming ring is set to ON,you will find it under additional functions,RX settings,Incomming ring.
2)Make sure you have enough memory to receive a Fax.Go additional function,dataregistration,TX settings,Erase failed TX,set it to on.
3)Make sure there is enough toner and paper for the machine.
4)Tone or Pulse Dialing,depents in witch country you are make sure it is set correctly Tone or Pulse.You will find it under user settings.
5)There can be a problem at the you local exchange,you can send faxes but the exchange can be faulty and you would be able to receive faxes.
6)And then there can be a problem with you fax machine' NCU PCB board,there is to gas arresters one for send and the other for receive.If one of them are faulty you will have to replace the NCU.The gas arresters is not available as a part.
Dec 09, 2009 | Canon FAX-L360 Plain Paper Laser
Cant send faxes
It sounds like the faxes memory is full, either from receiving or transmitting faxes, try turning it off and on again, the fax might just need to recognize you have installed a net toner cartridge.
Oct 16, 2009 | Office Equipment & Supplies
I have a fax-100 machine. it wont send or receive at all. the display reads 'memory full'. i dont have an advanced user guide. help please.
I don't know what brand fax 100 is. But if the memory is full you might try the following.
Unplug the power form your unit for 24 hours and then restart it. The memory should clear itself. ( you really have to unplug it not just shut off the switch if it has one).
There are reasons why the memory got full in the first place. Either the phone line was off and transmitted documents never sent or the receive function was disabled due to a paper jam, out of paper, or toner or a spent drum.
Good luck.
Jul 29, 2009 | Office Equipment & Supplies
Can't receive fax but can send fax
I have a feeling that it is a re-manufactured or compatible cartridge??
There is a fuse that needs to be replaced on this unit. it blows when the cartridge is installed to reset the machine. If the fuse has not been replaced or is defective the machine will not recognize the new unit.
Feb 12, 2009 | Samsung SF-5100 Plain Paper Laser Fax
SF-560R. When receiving and sending Faxes
needs a new toner cartridge probably but the fuser rollers may be damaged as well usually if the lines are indented into the paper that means its the fuser roller if they just appear strait down the page then its the toner cartridge
Nov 18, 2008 | Samsung SF-560 Plain Paper Laser Fax
Fax machine problem
You need to use the [MENU], [< >] and [ENTER] keys to browse through the unit's menu. Find and enter the "System Setup" menu and then search for the "Ignore Toner" option. Press [ENTER] and change the setting to "ON". Press [ENTER to confirm, the, [STOP/CLEAR] to get out of the menu system. The unit should start printing all faxes in memory.
Be blessed.
Nov 07, 2008 | Samsung SF-5100 Plain Paper Laser Fax
Sending Documents
First the battery.
Along the top edge of the operation panel you will see a blue tab. just to the left of that tab you will see another beige tab of the same size, this is the battery holder.
Open the toner door and open the feeder ...pull upwards 1 inch until it stops.
Pull the beige tab out...not the blue one.
Take the battery to radio shack or CVS Pharmacy and match it up....CR-2032.
Next step:
press the MONITOR key and listen for a dial tone.
plug a regular phone into the phone jack to check for a dial-tone.
If all else fails.
Press FUNCTION
7
monitor key slowly 4 times
6
scroll down to SHIPMENT SET
press set
set
wait for the machine to initialize and reboot itself.
Oct 29, 2008 | Panasonic Panafax UF-585 Plain Paper Laser...
Toner Cartridge reading has empty but have replaced toner
Try to see in the software if there is any reset option for the toner.
Nov 06, 2007 | Ricoh FAX2500L Plain Paper Laser
Canon FAXPHONE L80 Laser Logo
158 people viewed this question
old marine
old marine
