Question about Canon FAXPHONE L80 Laser
Not able to receive a fax, but able to send
All functions are working
  • bizteksales Jan 16, 2009
    I was not able to carry out the test as the screen is saying "check printer" and not allowing me to do anything, help me
  • 318 Answers
Check that the fax is set for "tone" and not "pulse".press addisional funcktion ,select user settings,tel line settings.Set to "tone"
good luck
Posted on Dec 19, 2008
Unable to receive faxes. Able to send and cartridge printing OK
There can be a few things wrong lets take it step by step
1)Receive mode,your receive mode must be set correctly.If you don't have a tel connected to it, you cant use it as a Manual receive mode,it must be set on Fax only.If there is a telephone connected to it and it is set on manual mode make sure your Incomming ring is set to ON,you will find it under additional functions,RX settings,Incomming ring.
2)Make sure you have enough memory to receive a Fax.Go additional function,dataregistration,TX settings,Erase failed TX,set it to on.
3)Make sure there is enough toner and paper for the machine.
4)Tone or Pulse Dialing,depents in witch country you are make sure it is set correctly Tone or Pulse.You will find it under user settings.
5)There can be a problem at the you local exchange,you can send faxes but the exchange can be faulty and you would be able to receive faxes.
6)And then there can be a problem with you fax machine' NCU PCB board,there is to gas arresters one for send and the other for receive.If one of them are faulty you will have to replace the NCU.The gas arresters is not available as a part.
Dec 09, 2009 | Canon FAX-L360 Plain Paper Laser
Turning off receive on UF-490
Press these buttons.
Function
74
set
15
set
1 for tel
set
stop
Jan 06, 2009 | Panasonic PanaFax UF-490 All-In-One Laser...
Fax not sending or receiving
The fax function is controlled by a fax card on the inside of the printer. Most likely, that card has failed. You will need to contact Canon to get a replacement card and instructions on replacing it.
Thanks and please take a moment to give this a good rating of fixya.
Dec 24, 2008 | Canon PIXMA MX700 All-In-One InkJet...
Recently purchased a J6480 All in one. The fax function stopped working and the message was "Fax Log Full" cannot send or receive. How do I fix it? K. Kirschner ksk62@comcast.net
recently purchased a J6480 All in one. The fax function stopped working and the message was "Fax Log Full" cannot send or receive. How do I fix it?
K. Kirschner ksk62@comcast.net`1q```````````````````````````````````````````````````````````````````````````````````````````````````````````````````````````````````````````````````````````````````````````````````````````````
Jul 26, 2008 | Computers & Internet
All Fax pages not received or sent.
have you watched the paper going through the doc feeder are thay goning one by one or is it pulling more then one. try making a copie withe 4 sheets does that work. if not open cover of doc feeder clean rollers. serperation pad. ( pad would be twrods the top of the cover )
C.W.H.
Jul 21, 2008 | Canon LaserClass 2050 Plain Paper Fax
Will not make a copy
If it won't copy, it is unlikely to handle faxes either since those functions use the same scanner. If your received faxes are coming out blank, then it is a problem with the ink system; if you can get faxes printed but not copy a document, the scanner may be at fault.
Have someone send you a fax to check this function (printing) and then try sending one back to check the scanner.
If either one fails, then hyou know where the problem lays.
Jul 10, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Cannot Send or Receive Faxes
here you might find an answer:
http://welcome.solutions.brother.com/bsc/public/us/us/en/faq/faq_top.htm?reg=us&c=us&lang=en&prod=mfc240c_all
Mar 29, 2008 | Brother Multi-Function Center MFC-240C...
Panasonic fax kx fp342 regarding
my fax do not send paper but it's reciver and copy it .
what solution ?
Dec 29, 2007 | Office Equipment & Supplies
Canon FAXPHONE L80 Laser Logo
101 people viewed this question
old marine
old marine
