Question about Acer Aspire 5315 Notebook
My dvd-rw plays movies but not dvd-rom's
I have a acer aspire 5315 and it won't play my tutorial dvd-roms but it plays dvd movies perpect
Can't watch blue ray movies on my acer aspire model 5334
Taken from the acer support website.
" Optical media drive 8X DVD-Super Multi double-layer drive:
  • Read: 24X CD-ROM, 24X CD-R, 24X CD-RW, 8X DVD-ROM, 8X DVD-R, 8X DVD+R, 6X DVD-ROM DL (double-layer), 6X DVD-R DL (double-layer), 6X DVD+R DL (double-layer), 6X DVD-RW, 6X DVD+RW, 5X DVD-RAM
  • Write: 24X CD-R, 16X CD-RW, 8X DVD-R, 8X DVD+R, 4X DVD-R DL (double-layer), 4X DVD+R DL (double-layer), 6X DVD-RW, 8X DVD+RW, 5X DVD-RAM
This model of computer does not have a blu-ray drive unless you got a third party upgrade. In this case, you will need to track down special drivers, which can best be done by whomever sold you the drive.
Jun 10, 2011 | Acer Aspire One PC Notebook
HOW DO I REMOVE DVD ROM FROM ACER ASPIRE 5315
im assuming the "eject" button is not respomding, no worries REAL easy fix, if you have a paper clip, if not find something the same diameter, if so, unfold paper clip and there should be a small hole on the door next to the "eject" button, insert end of paper clip, retrieve dvd.. :)
Apr 14, 2011 | Acer Aspire 5315 Notebook
Can lite-on-ltn4865 48x play dvd movies
If your Drive is a CD-Rome drive, surely it cant, for the drive cant read dvd disc. Replace the drive of yours with DVD-Rom or DVD-RW in order to play dvd disc, DVD-RW simply has the added capablity to burn on DVD discs
Jan 12, 2011 | Lite On (LTN486S) Internal 48x CD-ROM...
Acer aspire 3690, my cd-rom will play movies, audio and some old games can be read but mostly refuses to read most of my game disks now, any ideas??
Try an external DVD drive that you can connect to your USB port. The drive you have in the laptop either has a dirty laser lens, which you can carefully clean with a "Q" and alcohol, or the laser itself may be going out. The drive can be replaced. You mentioned you have a cd-rom. If you can play movies (DVD) it is more likely a DVD drive instead of a cd-rom. CD-ROMs can only read data or music.
Nov 19, 2010 | Acer Aspire 3690-2196 Notebook
How to play a DVD-RW on Aspire with a DVD/CD-RW
just put the dvd in and open it with windows media center or any other dvd/media software
Jan 17, 2010 | Acer Aspire 5315 Notebook
Cd/dvd-rom drive E: not detected
plz check in the bios the cd rom is enable, then check the datacables try with a new data cable
Jun 19, 2009 | Acer Aspire 5315-2153 Notebook
My laptop acer aspire 5315 cannot see the dvd/cd rom,so i canoot play any cd or dvd.
do one thing go to the device manager
right click my computer > properties > hardware > device manager
than go to the option that is ide/ uninstall the secondary channel and than restart the system
the issue should be resolved
Jan 10, 2009 | Acer Aspire 5315 Notebook
ACER 4520 CD-RW/DVD-ROM its pops up insert disc
you can try two solutions
1) go to device manager and uninstall the primary and secondary ide controller under the IDE ATA/ATAPI controllers and than restart the system and than chk it if that works out
2 ) if the first option doesnt work try to update the firmware of the drive
Sep 09, 2008 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
Acer aspire 3500 DVD ROM making noise
type of noise ? It might just need a cleaning. Try using a compress air can to clean. Look inside to see nothing is stuck in there.
May 06, 2008 | Acer (91.48T37.003) CD-RW/DVD-ROM (Combo)...
Acer Aspire 5315 Notebook Logo
77 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
