Question about Hardware & Accessories
Need leveling screws (bolts) for my patio table legs
Where can I purchase the leveling screws for my patio table? need all four. I could not find the product in your drop down menu so I just picked
one to be able to send my question
Thanks for your help
Jim Gross
12019 East End Ave
Chino, Ca. 91710
909/591-4959
  • 8,197 Answers
Hi I would try a local patio supply place. Something like BBQ galore
Posted on Dec 17, 2008
Tip
Turn Travel Trunk into a Coffee Table
Making your old travel trunk into a coffee table can be a very good feature to add to your decore and can be a great conversation starting piece. The best part is that turining it into a coffee table is not a very difficult thing to do.
Most travel trunks are a little too short to be a proper coffee table so you are going to want to find some table legs that you like and cut them down to the height that you want the table to be at. If they are wood you can even stain them to match the trunk or other furniture in your house.
Things you are going to need:
- A travel trunk
- 4 table leg straight top plates
- 4 table legs
- screws and a drill
If you are going to stain the legs then you should stain the legs before you start and allow them to dry.
Using the drill screw the table leg plates to the corners on the underside of the trunk. Once the legs dry screw them into the leg plates and flit the trunk over. And walla! you have a brand new vintage coffee table.
on Oct 21, 2013 | Luggage & Travel
Leak at left side and front of lid model #8240ywo
Be sure and check if the flooring is in good straight flat surfaced,if it is,then re tighten all the screws/bolts around its body and it`s back,then put level bar on top of it,if it is not leveled properly,re adjust/turn the four legs of unit until you achieve the dead zero level on your level bar.
Oct 25, 2014 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Table broken leg
You need some kind of screws/bolts to hold the broken pieces in place before you can apply glue. At the end of your video, you showed the bottom view of the legs. If you can drill some holes at good positions, you should be able to put bolt and nut to hold the legs in place. Then, you can use super glue to keep the surfaces smooth.
Apr 11, 2014 | Furniture
Level a refrigerator
Rinda,
Most refrigerators will have a leveling leg or wheel at each ot the front corners. What I usually do is lift the refrigerator up and set a block under the refrigerator and turn the legs or the screw for the wheels until they are at the point I want them and then remove the block. In your case, if you have leveling legs you will want to screw them into the refrigerator to lower the front. If you have wheels you will need a screwdriver or a nut driver and un-screw the bolt to lower the front. You may need to take the trim under the door off to access the bolts if you have wheels in the front. Hope this helps!
Jun 04, 2013 | Refrigerators
My patio table is wobbly how can I fix it?
If your table has feet that look like the screw in, then youshould be able to adjust the feet on the legs of the table by tightening themall. To so you should ensure that the table is flat and see if any of the feetare off the ground, if so you should adjust them so that they are touching thefloor on all sides.
May 29, 2012 | Garden
What is a folding table?
A folding table is a two or four legged table that can be flattened via hinges on each of the legs. Folding tables are very convenience because they tend to be very light weight and can save space.
May 29, 2012 | Furniture
How do you square table saw fense?
Briefly, unplug the saw. Raise the blade as high as it will go, the fence should have some screws or bolts on the end closest to you, loosen those, put the fence up against the blade, and retighten the screws/bolts.
Apr 30, 2010 | Jet 708315LSB 10" Benchtop Tablesaw with...
I purchased GardenSun Patio Heater Model: HSS-A-SH and no screws or bolts came with it. How do I get or replace them? Thanks
Go back to where you got it and tell them. They should provide the needed pieces, free. If you have to buy them, they still should know what to give you. Good luck...Lee
Nov 24, 2009 | Stainless Garden Sun Steel Propane Patio...
I need assembly directions for evenflo exersaucer triple fun.
1. Remove toys and seat from the exersaucer.
2. Fold exersaucer, but do not let the tray lock to the base. With exersaucer flat on the floor, twist each leg assembly (B) fully clockwise until it stops. Fully depress one of the pedestal locking tabs (C) then push on the leg assembly (B); leg will partially fold. Repeat this for all four legs. After pressing the fourth pedestal locking tab (C), the Exersaucer will fold with the tray (D) rotating toward the base (E). Make sure all four tray locks. (F) are locked onto the base before trying to carry exersaucer.
3. Place your fingers beneath the legs (A) push upward to disconnect the leg assemblies from the pedestals (B). Repeat for all 4 leg assemblies.
4. After all four legs have been disconnected from the pedestals, remove tray assembly (C) from the base (D).
5. Turn tray (C) upside down and remove both end caps (E) from beneath.
6. Squeeze both locking tabs (F) on each side of the tray to disconnect and seperate the tray halves (C). 7. Connect tray halves (C) to form activity table.
8. Rotate leg assemblies (A) fully clockwise until they lock into postition. Make sure all four legs lock (G) are locked properly into the uper leg pedestal (H). Also make sure all four leg locks (I) are sticking out past the edge of the tray.
9. Turn table over and install two end caps (E). Make sure both end caps lock into place. NOTE: one end cap installs from above and the other installs from below.
10. Install toys on activity table. If desired, adjust table to the appropriate height for your child. IMPORTANT: NEVER use stage 3 without end caps!
Mar 20, 2009 | Evenflo Exersaucer Triple Fun Active...
Hardware & Accessories Logo
331 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
