Question about Kenmore 52673 Side by Side Refrigerator
Food in the freezer of 52603 is too cold/frozen.
Food in the freezer side is too cold/frozen. Temperature on the refrigerator side seems fine. We've put it on the highest setting and checked to see that the vents on both the freezer side and the refrigerator side are not blocked. We've tried to reduce the amount of food in the freezer but we did not think it was unusually loaded. Also, cleaned the coils as best as possible.
  • 944 Answers
This would usually indicate that some refrigerant gas has leaked out - the effect at certain percentages is to allow the gas to expand too much when it first enters an evaporator (the plate in the freezer that gets cold), thus making it much colder than the thermostat is set too. due to environmental laws you cannot top this up yourself, it must be done by a qualified fridge guy. get him to check for leaks as well, usually they can be fixed if there is one, but a tiny amount of refrigerant can leak out over time with no actual major leak. Try first defrosting completely - occasionally ice crystals can form inside the refrigerant system which may be causing the problem, once defrosted, this water should be dealt with by the filter/drier. Probably still needs refrigerant gas, but is worth trying. once the gas is topped up then ask the guy to check that the freezer thermostat is working correctly - it could possibly be faulty, no way to tell easily without just replacing it or topping up the refrigerant gas first. Hope this helps, please post again if not :)
Posted on Mar 26, 2007
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
Why is the refrigerator side is freezing food
First some fridge 101, the refrigerator/freezer models cool by directly refrigerating the freezer section and the refrigerator section is cooled when "some" of the cold air from the freezer is directed over to the refrigerator side (typically by a fan) to keep food fresh and not frozen a temperature controlling damper opens and closes to regulate the temperature of the fridge by introducing more or below freezing air into the cabinet. In older models where the freezer was on top the air simply "gravity" drained into the refrigerator cabinet, if the food was too cold you turned the fridge knob up and less air sank from the freezer to the fridge, simple but effective.
When you adjust the temperature level it controls the freezer temperature and this turns the compressor on and off to keep the food frozen. There is typically a knob or lever and some even have electric dampers that open and close to direct more or less air from the freezer and direct it to the refrigerator cabinet based on your temperature requirements.
Now that you know how it works there are a couple things to check. If the condenser coil is plugged with dust the internal system pressure will rise and in some cases make the fridge an over achiever and can chill too much so check/clean the condenser coil. Check the freezer temperature control and turn in up, also make sure the fridge temperature control setting is not set too cold.
Finally as the temperature changes around the refrigerator it will have an effect on the inside of the fridge too so expect to turn it up and down as the environment changes, down in the summer and up in the winter.
Hope the novel helps to resolve your issues.
Nov 01, 2017 | Refrigerators
Lg lbc22518ww bottom freezer not keeping food frozen
door seals may be bad. check for cold air leaking especially on the corners and the hinge side.
Feb 28, 2014 | LG LBC22518 Bottom Freezer Refrigerator
Fridge temperature is too cold, food id freezing. freezer seems fine. even adjusting the fridge temperature up to 1 does not change the temperature. seems to be stuck at 30F.
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Dec 10, 2010 | GE Profile 23.1 Cu. Ft. Side-by-Side...
Freezer not freezing, fridge seems too cold
If the refrigerator is in the house and the temperature in side is between 60 and 80 it should be able to hold good temperatures. If it is in a garage or outside it will not work as well.
If it is inside the first thing to try is resetting the controls. Turn the Fresh food control to a low setting and the freezer setting to maximum. Wait 24 hours and recheck. If this does not work you will need to replace the cold control. To find the part number you will need the complete model number located on the tag.
Apr 18, 2010 | Frigidaire All Refrigerator & Freezer Kit...
Freezer is cold but not keeping icecream frozen.
If, the fresh food section is 34- 38 degrees, then the freezer should be cold enough to keep ice cream solid. All of the cooling capability comes from the freezer section. I, personally, would not waste time or money on a ten year old box. Ten years ago it cost $1000, so, the outlay is $100 per year. Dump the old refrigerator and get a new one.
Aug 27, 2009 | Refrigerators
Food in freezer not frozen; food in refrigerator not cold
1.check the coils on the back or under side.
2.check if compressor is running
3.check if copressor is hot
4.let me know the answers
Jan 14, 2009 | Freezers
Ge SIde by side SSS25KFMDWW stopped freezing
number one,is the freezer fan working?2,is there frost forming on the back wall of freezer?let me know more-mike
Nov 13, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Admiral - GC2224GEKB
Does freezer cool like the cold food section? Did this suddenly happen, and frozen food began to thaw?  Most freezers control the cooling in the cold food section. The freezer must work fine before the cold food section will work fine. Let us know more, Thanks JT
Oct 24, 2007 | Admiral 26 cu. ft. Side-By-Side...
Freezer works fine but the fridge won't get cold
It sounds like cold air from the freezer isn't making it to the fridge compartment. This can be cause by a several things. The damper that lets air into the fresh food side is stuck in "closed" position, the temp sensor (t-stat) isn't working properly, the evaporator fan (in the freezer comp above the coils) isn't working to blow air up to the fresh food section. In some situations, the defrost cycle for the freezer section isn't working and the coils have frozen into a block of ice and air can't flow over them properly so you get not cold air to the fresh food section but the freezer still stays cold due to the block of ice.
Feb 21, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore 52673 Side by Side Refrigerator Logo
101 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
