Question about Tomtom One XL GPS Receiver
How do you get the GPS to work right when you take it out of box?
What is the very first step to get it on if pushing button doesn't do it? Must you be in cold, frozen car and unit plugged in?
    Problem Solver:
  • 3 Answers
Charge it for an hour or so. Having said that, how old is it? There is normally at least some residual charge left in the unit when you first buy it.
It should turn on when charged but you need to be outside for it to receive satellite signals so it can work out where it is. This then normally stays in memory and subsequent switch ons are a lot faster.
Posted on Dec 19, 2008
My mx android tv box won't switch on to home page or return there so I can't get to android side I don't know if I hit always instead of just once Mark
On your box is a reset button.push in with a tooth pick. Release unplug power connect. Then push reset button again wait 10 seconds while holding reset button re plug right hand power cord. Release button and wait. Information box will appear click top section to reset. This should resolve problem. If not you will repeat when screen appears scroll down to reset to factory settings. Follow steps to connect again. I hope this works. Also do a search on youtube.
Feb 01, 2015 | Televison & Video
Volvoxc70 doesn't start when i push in the button and then apply the break, after a few times it makes a clicking noise and then the noise stops. still doesn't start. am i actually trying to s
insert the key into the slot then step on the brake and keep it depressed, then push the start button. when it starts to crank release the button.
Feb 24, 2013 | 2004 Volvo XC70
TOMTOM DOESN'T COME ON
In the back where the mounting bracket goes, is a small reset button, push this in for a few seconds with a pin.
May 07, 2012 | Tomtom ONE GPS Receiver
My computer's tower turns on but it doesn't display on the monitor, the monitor shows the normal Self test box so the monitor doesn't seem to be the problem. Also when I press the power off...
Make sure that the cable is connected from your computer to the monitor, and if it is wiggle it and push it in all the way. If it has screws, screw them in. If that does not work, check that your monitor is on the correct input (if it has multiple) then see if anything comes on the monitor. If nothing happens you should buy a new cable from the store. If all of those steps do not work your computer or your monitor might have a more serious problem.
Jul 29, 2011 | Computers & Internet
My garmin nuvi 255w keeps freezing up at loading maps screen...i have tried the hard reset but that doesn't work, when i push on the bottom right corner and start the gps, it doesn't even make it...
There is a hard reset button under the sticker at the bottom of the unit. It is located directly under the check mark on the sticker. Once you get it going fully charge the unit then go to the Garmin website and register and update your 255w. I will attach the link to the Garmin Site. Thanks for using FixYa
https://my.garmin.com/mygarmin/registrationGettingStarted.htm?productType=auto&categoryType=AUTO
May 29, 2011 | Garmin nuvi 255W GPS Receiver
Nuvi stopped talking. where is the mute button located on the unit?
If you are no longer getting the voice guidance from your gps, then you need to check if the volume is on the highest or lowest. There is no mute button on the gps, it is when the volume is at the lowest it seems muted. Ensure the volume is turned up by adjusting the scroll whell that is by the right hand side of the unit.
If that does not help, then you check the language settings in the unit. Verify that the voice is enabled, by following these steps:
  1. from the 'where to? view map' screen, touch 'tools',
  2. Touch 'language',
  3. Next to 'voice language' you will see 'jill' listed in the blue box on the right (if so the unit should be ready to use)
  4. If you do not see a 'voice' listed in the blue box, touch on the blue box,
  5. Select 'voice',
  6. Touch 'ok' at the bottom,
That should do the work for you.
Dec 23, 2010 | Garmin nuvi 205W GPS Receiver
My nuvi 465t, froze and then the screen went blank, unable to figure out how to recover
You need to reset the GPS.Press the reset button , you'll find it on the bottom right of the Nüvi but it doesn't look like a button. It's basically the sticker with all the information on it. It's just enough to push the sticker carefully with something small, not too sharp so it doesn' get destroyed. The Nüvi reboots, the loader loads and proceeds with the software load. Once this is over, shut down the Nüvi and reconnect to the PC. Then, everything works fine.
However this is caused by a full memory, erase as much saved data as you can to free up space, examples are "recently found" items, saved trip or addresses which you don't need anymore.
Let us know if you were looking for something more else please accept the suggestion.
Thank You for contacting Fixya.com
Feb 25, 2010 | GPS
I just bought a garmin edge 705 gps. Chg it and turned it on. Different languages came up. I wanted English and I thought I pushed the toggle for enter but another language has emerged and I don't know...
Press Wrench.
Press the button with the picture of gears on it.
Press Down arrow.
Choose second menu item from the top.
Press the middle of the 3 boxes on the right.
Press up arrow to find American or British English.
Let us know if this solution works for you. Thanks.
Oct 31, 2009 | Garmin Edge 705 Handheld GPS Receiver
How to reset my gps device
Steps to fully reseting Your Garmin nuvi
1:remove sticker located at bottom
2. There should be a reset button located to the far right.
3. Hold down the reset button ( at the same time push the power button to the left) hold these for 10 seconds.
May 09, 2009 | Garmin nuvi 260W GPS Receiver
Tomtom One XL GPS Receiver Logo
23 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Marvin
Marvin
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
