Question about i-mate JAM Pocket PC
Bluetooth Enabled Audi Car
How do I properly pair mmy i-mate K-Jam with my Bluetooth enabled Audi car. I can get it all set up, ad then it drops out after two minutes.
  • 56 Answers
It's the session time .... you can change it from the connection setting ... if you find this help is useful please rate me!
Posted on Jul 31, 2007
SOURCE:
Conecting phone to car
Vehicle Needs to be 2008 or later with Bluetooth. If you have a 2005 to 2007 or an aftermarket deck with a USB port you can always use your USB charging cable and plug it in.
If your car has Apple play, you need to enable that on your iPhone in settings>General> car play. Be sure your car is in "pair mode" and that your iPhone Bluetooth is enabled.
For android, turn on Bluetooth and enable "pair mode" on your vehicle. Go back to your phone and select Bluetooth and look for Devices with the vehicle manufacturer signal i.e. GMC1465. On your phone, tap on the signal and follow the instructions.
Good luck
Sep 21, 2016 | Cell Phones
Tip
Enable Audi MMI 3G bluetooth hands-free phone
Activate Audi MMI 3G bluetooth connection and handsfree profile in your car. All Audis with Multi Media Interface 3rd generation are equipped with bluetooth, some just need activation which you can do for free, without adding any hardware.
  • You car need to have MMI 3G system. Check your Multi Media Interface version.
  • Hidden menu must be enabled.
Procedure:
  1. Turn key into II position and wait for the MMI 3G system to start. You can also use keyless buttons.
  2. Press and hold buttons SETUP and CAR.
  3. After couple of seconds hidden green menu will appear. You can now release the buttons.
  4. Navigate to diagnose > settings > Tel settings misc.
  5. Check current value in this line and switch to value with "BT/HFP" instead of "no BT/no HFP".
  6. Press RETURN and CAR buttons at the same time to exit hidden green menu.
  7. Restart MMI 3G with key combination
  8. Connect your diagnostic interface with module 5F - Control Head.
  9. Choose procedure 10 - Adaptation.
  10. Choose Channel 17 and read stored value (should be 0).
  11. Enter new value: 1
  12. Save new adaptation value.
  13. Exit.
on Jul 06, 2015 | Audi Cars & Trucks
Having a problem pairing my iPhone 6 to my Tx-sr333 receiver. Iphone just grinds and can't find Bluetooth.
Hi Don,
Pairing is necessary when using the Bluetooth-enabled
device for the first time. Before starting the procedure, learn
how to enable the Bluetooth setting function and to connect
with other devices on the Bluetooth-enabled device.
1. Press BLUETOOTH on the remote controller.
The unit enters the pairing mode and the BLUETOOTH
indicator starts flashing.
2. While the BLUETOOTH indicator is flashing,
complete connection on the Bluetooth-enabled
device in the nearby area within about 2 minutes.
If the name of this unit is displayed on the Bluetoothenabled
device's display, select this unit. Paring will end
after a short time.
???? If a password is requested, enter "0000".
???? When connecting the unit to any other Bluetoothenabled
device, start pairing by pressing and holding
BLUETOOTH until the BLUETOOTH indicator starts
flashing. This unit can store the data of up to ten
paired devices, Thanks, JT
Mar 09, 2015 | Onkyo Audio Players & Recorders
Bluetooth won't come on hdmx jam party and sync with ipod touch 5th gen
Follow the instructions from the set up guide that came with your Bluetooth wireless speaker on how to pair and connect .the speaker with a Bluetooth-enabled media device such as iPod, iPad or iPhone.
Apr 21, 2014 | Apple iPod Audio Players & Recorders
I have blackberry 8110 and it ask me for a passkey
Blackberry 8110
Bluetooth technology troubleshooting:
Common Problems
I cannot type a passkey on a Bluetooth enabled device
If you cannot type a passkey on a Bluetooth® enabled device, the passkey might already be defined.
On your BlackBerry® device, in the Enter passkey for <device name> field, try typing 0000.
My list of paired Bluetooth enabled devices does not appear
Try performing the following actions:
• Verify that Bluetooth® technology is turned on.
• Verify that you have added Bluetooth enabled devices to the paired Bluetooth enabled devices list.
I cannot pair with a Bluetooth enabled device
• Verify that your BlackBerry® device is compatible with the Bluetooth® enabled device. For more information, see the documentation that came with the Bluetooth enabled device.
• Allow the Bluetooth enabled device to discover your BlackBerry device. In the Bluetooth setup application, click Allow another device to find me.
• Turn off encryption for Bluetooth connections between your BlackBerry device and the Bluetooth enabled device. In the device options, click Bluetooth. Click a Bluetooth enabled device. Click Device Properties. Change the Encryption field to Disabled. Press the Menu key. Click Save.
I cannot share contacts with a paired Bluetooth enabled device
• Verify that your BlackBerry® device is paired with the Bluetooth enabled device.
• Verify that, in the Bluetooth options, the Address Book Transfer field is not set to Disabled.
• Verify that your BlackBerry device is connected to a Bluetooth enabled device that supports the Handsfree profile or the Object Push profile. For more information about supported profiles, see the documentation that came with the Bluetooth enabled device.
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thank you.
Feb 01, 2010 | RIM BlackBerry ® 8830 Cellular Phone
How can i set the em227pk bluetooth up for pairing? plz help.
In order to pair a BlackBerry smartphone with a Bluetooth enabled device (e.g. a Bluetooth enabled headset), the Bluetooth enabled device must be in pairing mode. Most Bluetooth enabled devices are not set to pairing mode by default. Refer to your Bluetooth enabled device manual for instructions on how to set the Bluetooth enabled device to pairing mode.
To pair the BlackBerry smartphone with a Bluetooth enabled device, complete the following steps:
1) On the BlackBerry smartphone, click Options > Bluetooth. If you cannot find the Bluetooth option,
2) Open the menu and select Add Device. The Select Device list appears and lists Bluetooth enabled devices that are in range and available to be paired.
Note: Only BlackBerry smartphones enabled with Bluetooth technology that are in range and in pairing mode will appear in the available Select Device list.
3) Select the Bluetooth enabled device with which you are pairing. The Enter passkey dialog appears.
4) Type the passkey to authenticate the Bluetooth enabled device. Most Bluetooth enabled devices contain a hard coded passkey. See your Bluetooth enabled device manual for the passkey.
Note: 0000 is the universal passkey for pairing any Bluetooth enabled device with a BlackBerry smartphone.
Note: Once a Bluetooth enabled device is paired, it appears in the Paired Devices list. The Bluetooth enabled device will no longer appear in the Select Device list.
Bluetooth devices are manufacturer specific. Please refer user manual for instructions on how to pair with other devices.
Oct 24, 2009 | RIM BlackBerry Storm 9530 Smartphone
I have a parrot ck3100 and trying to pair it with my nokia 5800 xpress music phone but comes up with cannot pair with the parrot. Help!!!
go to settings, pair devices and delete all the old pairings, then go to settings, pair with phone and start new pairing.
Sep 24, 2009 | Parrot Hands-Free Car Kit with LCD Display...
Cannot clear parrot memory
go to settings, paired devices and delete all paired devices, the go to settings pair with phone and start new pairing.
Aug 16, 2009 | Parrot Hands-Free Car Kit with LCD Display...
MMI not responding
hello
have you solved the problem? i have same problem on my A5 and the guys from audi told me to replace the battery. i really don't know what to do because the car is starting immediately.
thanks
Nov 27, 2008 | 2008 Audi A5 Coupe
Bluetooth/hands free
the problem in the session time ... by the defualt it's 2 min .. try to change it from the bluetooth setting or connection setting ... if you find this help is useful please rate me !
Mar 26, 2007 | i-mate JAM Pocket PC
i-mate JAM Pocket PC Logo
99 people viewed this question
Top i-mate Computers & Internet Experts
Thomas F. Schneider
Peter Dragonetti
Are you an i-mate Computer and Internet Expert? Answer questions, earn points and help others
