Question about HP Photosmart C5180 All-In-One InkJet Printer
My printer has suddenly started printing terrible quality photos
I have started printing Christmas photos and the first three were fine. Now it is suddenly acting up and the pictures come out terrible. The printer works fine printing documents in both black and white and color. My cartridges are not low either. What is going on?
I discovered I had switched photo paper in the process. The new paper obviously isn't compatible with this printer. I went and purchased more of my regular paper and the pictures began printing well again.
Posted on Dec 18, 2008
When I print photos, they have uniform vertical streaks.
Issue: Banded or streaked prints
Solution: Change the Print Quality Settings (Windows)
Change the Print Quality Settings (Windows) The Quality setting controls how finely ink droplets are placed on the printed page. Depending on the type of paper being used a higher Print Quality setting does not always insure a better print. Print speed will decrease as the Print Quality setting is increased. Follow the instructions below to change the print quality settings in the Canon printer driver for the Windows operating system through a printing application.
  1. Click 'Properties' in the Print dialog box.
    Note: Depending on the Application software, 'Properties' may be displayed as 'Preferences'.
  2. Set the desired print quality in the 'Print Quality' section.
  3. Select 'High', 'Standard', or 'Draft / Fast'.
To set more detailed print quality settings, follow this procedure:
  1. Select 'Custom' and click 'Set'.
  2. In the Set Print Quality dialog drag the slide bar from 'Fast' to 'Fine' to select the print quality.
    Note: There are five options in 'Quality'. However, selectable options are limited depending on the media type.
  3. Select 'Auto', 'Dither', or 'Diffusion' from the 'Halftoning' section.
Apr 22, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
It's possible that your cartridges are leaking into the printhead and cross polluting the other colours or there is a problem with the parking pad where the printhead "rests" when not in use.
I'd recommend removing your cartridges and checking for any ink leaks on these and/or puddles of ink in the printhead.
Then check the parking pad for any puddling of ink...
Given that you have a CX6600, which is now quite an old model, you may have a clogged waste ink tube and this is causing cleaning cycles to expiate ink into the parking pad but not actually draw it away, thus soiling the underside of the printhead.
Resolving this is not easy but involves a suitable inkjet cleaning solution (ammoniated windex is recommended in the USA) and leaving this in the parking pad to work at any clogging. It's likely to take a few days and repeated application of cleaning fluid but if a clogged waste pump is the issue this should eventually clear it.
One other possible cause is a dead pump.. If that's the case, it's time for a new printer as it's just not worth fixing.
Hope that gives some ideas.
Feb 14, 2009 | Epson Stylus CX6600 All-In-One InkJet...
Printing problem with the kodak 5100
Theres alot of possible reason why you're having those print out. In your case since your complaining about the ink being to wet.. check the paper that ur using is it a photo paper? is it inkjet compatible? did you use the same paper you used before? Possible that your Print Head is defective. Have you tried using the ITG(interavtice troubleshooting Guide) www.kodak.com/go/itg
If that does not work call kodak. 1-800-421-6699. :-P
Dec 28, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Photos are not good
Make sure that your quality is set to best and you are using a high quality photo paper for maximum resolution and quality.
Jun 11, 2008 | HP PSC 1210 All-In-One InkJet Printer
Print quality
Paper type must be set to "Plain" to select Normal or Fast for Print Quality. Every other paper type selected will automatically set print quality to Fine (Photo).
May 30, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Poor color when printing in high qualitiy - fine when in standard quality
go to preferences then clock on manual
slide pink slider 100%left
give a litle bit black to right
print light
Manual is the printers dark room
Feb 27, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Lousy print quality
That might be a problem of the photo paper. Use another brand and have a look at the manual to set the right paper settings.
Feb 20, 2008 | Brother MFC 210C All-In-One InkJet Printer
Poor quality printouts from my canon mp150
before printing check the quality printing in printing preferrences to change it to best or normal.
Dec 04, 2007 | Canon PIXMA MP150 All-In-One InkJet...
FD73 Photo Quality
I'm guessing, cause i own a F505 and not a FD73......but, I dont even see a use for the F505 "standard" quality setting. It will stay on "FINE" quality always. I've got a HP 882c and it prints just fine. I use HP premium photo paper and the printer setting BEST. Are you using photo paper? Regular paper will bleed the colors around. Take some pictures on FINE and print them out on photo paper w/ printer BEST and compare.
Sep 11, 2005 | Sony Mavica MVC-FD73 Digital Camera
HP Photosmart C5180 All-In-One InkJet Printer Logo
145 people viewed this question
Seeker5211
Seeker5211
