Question about Mitsubishi WD-52725 52". Rear Projection HDTV
Vertical Lines on my 3 year old WD-52725
Vertical lines appear on 90% of the screen. Starting from the left to the right they are evenly spaced apart.
  • mmiller733 Dec 18, 2008
    Thank you for your help - do you know what the general cost of the repair will be ?
    Problem Solver:
  • 11 Answers
This is a horizontal problem in the tv circuit. you must bring this in nearest service center
Posted on Jul 13, 2009
    Sergeant:
  • 233 Answers
I believe the format, or FMT board is going bad. this is not a do it yourselfer type repair, unless you have extensive electronics background - I have one myself with the same problem. I am waiting to get a new FMT board for mine.
Posted on Dec 18, 2008
  • Josh Crager
    Josh Crager Dec 18, 2008
    Unfortunately, This is one of Mitsubishi's "cursed sets" it seems. I personally love Mitsu, but the 52525 and the whole ***25 line has been riddled by problems of bad capacitors, overheating, bad modules and bad color wheels. I am not trying to bad mouth Mitsubishi in any way, as I said before, they make a great product... they just failed on this particular line of DLP sets. As far as repairing this unit, I would not even recommend it due to the possibility that even IF you changed the FMT board, two months or so from now the color wheel could fail, or maybe the dm module caps will fail..I guess what I am trying to say is that you have basically gotten the "useful life" from your set.
Should the T-CON board be replaced on a Samsung LN40C650 LCD TV to fix the vertical lines problem?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Nov 08, 2015 | Samsung LN40C560 LCD TV
WD-52725 Picture Quality Problem
sounds like a possible issue with the Optical light engine itself.
Nov 28, 2012 | Mitsubishi WD-52725 52". Rear Projection...
I have a vizio p42hd TV. It has thin red vertical lines evenly spaced about 3/4" apart throughout the viewing area.
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
HOPE THIS WILL HELP TO FIX IT.....
May 18, 2011 | Televison & Video
White vertical lines across the screen. Why and what can be done? Thw white lines appear and stay all the way across the screen. They are about 1.5" inbetween each vertical line,
You have a failure in the vertical circuit. Service can run between $75 to $150 depending on your area.(In home repair will cost more) If set is older then 3 years and under 27" recommend replacing it.
May 06, 2010 | Mitsubishi WD-62327 62" Rear Projection...
Rolling lines on screen
Sounds like the power supply has a bad capacitor. This problem can inject excessive 60 hz from the AC line into the vertical stabilizing picture system. The hum also my come from the same reason, bad or leaking filter capacitors. Cheaper just to buy a new TV or borrow another TV and connected to your system to see if the problem still occurs.
Mar 16, 2009 | RCA F36668 36" TV
Mitsubishi DLP wd-52725 wavy lines from top left to bottom right
the DM board is going bad and needs to be rebuilt. check out www.tv-techs.com
Jan 02, 2009 | Mitsubishi WD-52725 52". Rear Projection...
H Lines on the left side of the screen
just in case you came across this - it is the light engine! $950 - thanks mits for complete junk
Oct 13, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Vertical lines in screen
Are the Lines Symetrical in distance and space? Makes a diferernce..
Jan 21, 2008 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Vertical lines across the screen
Change ballast and lamp at same time. Ballast #75006507 lamp #23311153
Sep 11, 2007 | Toshiba 46HM95 46" HDTV
Mitsubishi WD-52725 52". Rear Projection HDTV Logo
403 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
