Microsoft Xbox 360 Console
Problem for Microsoft Xbox 360 Console
Xbox 360 1 red light
By fitzy1294 on Dec 17, 2008
i was playing a game and then the game froze. I turned it off left it for a few seconds then turned it on again. when I turned it on it sayed there was a system error and then the same in all different langauges
Same Problem
May 04, 2009
-   my xbox 360live every time i turn it on it flashes one red light and says sysytem error and in other languages and also it says e 74-   Guest
Apr 20, 2009
-   i was playing my exbox 360 then it whent of so i ternt it back on and it come up as sistom era.-   enze
Mar 02, 2009
-   i was Playing fallout3 and ot froze... i turned it off, then back on; it came up with e64, tried turning it on and off several times, but it didn;t go away, i unpluged it over night and came back and it was fine for 3 weeks then it struck again but this time wouldn;t leave. PLEASE HELP-   Guest
Feb 22, 2009
-   blinking 1 red light
-   Guest
Feb 12, 2009
-   1 red light - E74 - same deal - microsoft.... -   Guest
Best Solution
posted on Dec 17, 2008
Very Helpful)
loonyface
Rank: Wiz
Rating: 80%, 70 votes
Section
4 is flashing red Means
- Hardware Failure
The Specific Type of hardware failure can be determined by the error code displayed on the screen.
If the screen is blank or you would like additional information follow the instructions for determining the secondary error code in the section below
E64: (not yet known)
E65: DVD Drive Error.... DVD Timeout, Wrong firmware, dvd is without f/w chip, etc.
E67: Hard Drive Error... It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it
E68: Hard Drive Error... It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it, This can also be caused by a Hard Drive Eprom Error.
E69: Hard Drive Error... It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it
E71: (not yet known)
E73: (not yet known)
E74: AV cable error... There is a problem with the AV cable, try using a different AV cable. (could also be a problem with the encoder chip)
E76: (not yet known)
E79: Hard Drive Error... It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it
--==SECONDARY ERROR CODES==-
The specific type of hardware failure can be determined by a "hidden" error code
  • Turn the xbox 360 on, and wait till the 3 red lights are flashing.
  • Press and hold the sync up button (the small white one), while holding that button press the eject button.
  • The LEDs will now blink the first number in the code (as described below).
  • Release the eject button and press it again.
  • The LEDs will now blink the second number of the code.
  • The LEDs will now blink the third number of the code.
  • The LEDs will now blink the forth number of the code.
  • The LEDs will go back to the 3 red flashing lights.
You should be able to determine the difference between the 3 flashing lights and the error code lights by the rate in which they flash.
Here is how you interpret the LEDs to get the code number:
  • All four lights flashing - 0
  • One light flashing - 1
  • Two Lights flashing - 2
  • Three lights flashing - 3
0001 power supply problem
0002 power supply problem
0003 (not yet known)
0010 over heating
0011 over heating
0012 over heating
0013 over heating
0020 (Not yet known, possibly overheating)
0021 (not yet known)
0022 GPU Error / GPU Overheating
0101 (not yet known)
0102 unknown error - literally means the console does not know what is wrong. Possibly a short or cold solder joint somewhere (2 reports of people repairing this, one was removing moisture build up inside the console, the other used a hot-air rework to reflow the BGA Ram chips)
0110 Memory Error / Memory Overheating
1003 Hard Drive Error... It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it
1010 Hard Drive Error, Can be caused buy a currupt or missing Eprom.
1013 (not yet known)
1020 (not yet known)
1022 AV cable error... There is a problem with the AV cable, try using a different AV cable. (could also be a problem with the encoder chip)
1030 (not yet known)
if your console comes up with ANY OF THESE CODES CALL MICROSOFT and they will repair anything for free
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Feb 20, 2009
Somewhat Helpful)
harry_best4u
Rank: Master
Rating: 69%, 7 votes
The cause of E-74 with one red light Error might be overheating of your console and for avoiding such error in future you need to put your machine at an open space. Ensure that it is placed near the window or you can also make some external arrangement for cooling of console such as cooling the machine through a pedestal fan.
But as your Xbox already have E74 with one red light Problem which can be solved by only repairing it, no other alternative.
Either you can send your Xbox to Microsoft (Please note that microsoft is no longer providing extended warranty for E74 with one red lightError) and wait for 3-4 weeks. If you don't want to wait for a month, you can also fix E74 with one red light problem with the help of this DIY Video, the guide will explain step by step approach to fix the problem. Choice is yours.
Was this helpful?
Yes
No
Popular Solutions for Microsoft Xbox 360 Console
Questions and Unsolved Problems for Microsoft Xbox 360 Console
Do you recommend Microsoft Xbox 360 Console?
Answer
Answer
I can hear sound but I cant see the game I tried making sure the cords were hooked up good and also... (More)
Answer
my xbox screen doesn't work i can here the sound but cant see anything and when i do get it to work... (More)
Answer
can hear the sound of the game but can't see the picture on Tv
Answer
this is the first time ive had an Xbox, idk how to get it to play the game i have, nor i konw how to... (More)
Answer
my console display went purple now have no picture
76 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Feb 12, 2009
I went to play my exbox and 1 red light started flashing. then it said system error, contact exbox customer support, in 11 different languages
Comment by brazy3450, posted on Feb 08, 2009
me tooooo
Comment by Guest, posted on Jan 07, 2009
1 red light on
1 red light on all the time
Comment by rohnkarl, posted on Jan 07, 2009
I went to play my exbox and 1 red light started flashing. then it said system error, contact exbox customer support, in 11 different languages.
Comment by Guest, posted on Jan 06, 2009
red rings
1 red light on and freezing!
Comment by tomap1955, posted on Jan 06, 2009
hello, we live in Ireland, where can you send a 360 for 1 red light repair?
Does anyone have a contact number please? Tom
screen went blank and then turned it on to find flashing red lights
1 red light flashing all the time tried turning it off and still get the same thing.
won't turn on
Comment by Guest, posted on Jan 05, 2009
2 red lights
1 red lights
sent mine in took a while to get it back!
full circle of red lights
1 red light on
Comment by Guest, posted on Jan 04, 2009
2 red lights as well
my xbox was fine .. i left it for 2 min off and when i came back and turned it on 1 red light was flashing ... section 3 does anyone know what that means???
got this one too!
1 red light is flashing on the power button.
2 red lights
Comment by Guest, posted on Jan 03, 2009
1 red light on
2 red lights
3 red lights are flashing when i turn it on.
got this too
Comment by Guest, posted on Jan 02, 2009
it is a scaler chip error blog at top tells you all about it!
blinking red lights
Comment by kotarofuma, posted on Jan 02, 2009
error code e 74 internal av problem the ********* at ms said it will cost 50 quid.ne replies to b.woods39@yahoo.co.uk
red lights are on
red ring of doom!
Comment by Guest, posted on Jan 01, 2009
i have this problem as well
help!
1 red light error as well
i was playing a new game i bought called rise of the argonauts then it froze
i have 3
Comment by Guest, posted on Dec 31, 2008
got them flashing as well
red light
1 red light on
red lights
got this problem too!
turned on and got a blank screen
1 red lights
Comment by Guest, posted on Dec 30, 2008
red lights on
2 red lights
1 red light
red lights
Comment by Guest, posted on Dec 29, 2008
2 red lights are blinking!
2 red lights
got the red lights as well
got back to green
no green light
Comment by Guest, posted on Dec 28, 2008
red lights
red light
Comment by Guest, posted on Dec 27, 2008
3 red lights
1 red light on
won't turn on
red lights blinking
green light turned red
Comment by Guest, posted on Dec 26, 2008
2 red lights
help!
just got this on xbox
got this too
Comment by Guest, posted on Dec 25, 2008
red light
help! my xbox is flashing!
red lights on
red light on
Comment by Guest, posted on Dec 24, 2008
2 red lights on
e74
3 red lights
Comment by RTDbogow1, posted on Dec 24, 2008
I have the same problem, but with GOW2. Went through the codes and couldn't really fix the problem, just identified it. I removed the game, unplugged everything and removed the hard drive. After a few minutes i reconnected the hard drive, the cables and turned on the xbox and it worked fine. I tried a different game (COD4) and it worked fine. I tried GOW2 again and the problem started again. I then tried the system cache clear and bad update fix.
  • To do the bad update fix, first remove the game from the xbox and turned it off. Hold the SYNC button and turn on the xbox. Keeping holding the sync button until the dash loads. then release it. This will clear any bad updates that were installed. (You may have to install updates for games again.)
  • To clear system cashe, go to your system blade (on new dash: my xbox...system) Go to memory. Press Y. Then press X, X, Left Bumper, Right Bumper, X, X. There will be a message that will pop up,select yes. This will clear any cache from your hd. (You may have to install updates for games again)
This may help, its probably good to do regardless, I still have the same problem with GOW2, but all my other games work fine. If a known download or some kind of fix that surfaces that actually fixes the problem other than just identify it, please let me know!
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Video Game... Experts
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
