Question about Akai LCT3701AD 37 in. LCD Television
I have Akai 37" LCT TV. When I turn it on, no picture is getting displayed.
  • Mithelen Dec 28, 2008
    Yes, I have the same problem. No display (just backlite) Audio works. I suspect the LCD driver board is bad.
  • noahmunyer Jan 26, 2009
    i have the same problem as "solution 3".
    How did you fix it? where is the Fu101 fuse?
    i have the manual and i took TV apart, where did you get new fuse?
    anything will help
Yes, I have the same problem. No display (just backlite) Audio works. Replaced a small fuse on 370wa02c board then picture works.
Posted on Dec 28, 2008
You can download the service manual from
http://www.free-service-manuals.com/
Registration is $5 for one month unlimited downloads.
I just downloaded the service manual for the LCT3701AD myself.
    Yes, the fuse was the problem. With the help of "circuitcity" on ShopJimmy.Com forum, we diagnosed and fixed the problem which was in deed the FU101 fuse. It was showing a resistance of 30 Ohms when I checked it with a meter, which was abronal. Fuses should show 0 resistenace.
I NEED A INSTRUCTION MAUAL FOR THIS Akai LCT3701AD 37 inch Flat Panel LCD HDTV with Built-In DVD Player, ATSC Tuner and HDMI THANKS BLUE
Posted on Dec 18, 2008
I got this from a person helping me
the no picture and good sound could be a combination of 2 defective boards in your TV, power supply or backlight inverter board.
1. If the TV turns ON, shine a light from a flash light near the screen and look for a dark video in a 45 degrees angle, if you see a dark video in the background then the power supply supply is not providing +24 volts to the backlight inverter board and will need to be repair.
2. No dark video might indicate that the backlight inverter board is defective.
This type of repair is not a DIY. If you open the back cover of your TV and remove the power supply board; you might be able to see the leaky or bulging capacitors.
The illustrations from the link are good for a LCD using 5 and 12 volts only but your LCD is using 24 volts to power up the backlight inverter board and computers power supplies do not supply that voltage.
So i took pics of the power supply Here
http://s704.photobucket.com/albums/ww50/smv244/
But then i read how u replaced the fuse... how did u.... exactly
can some please give me a guide...please email me at smv244@gmail.com
I just want my tv to work... also please email me the service manual..or does any one have a board...please help i just want my tv to work
Posted on Jan 03, 2009
2 Suggested Answers
ginko
  • 19396 Answers
SOURCE: I have Akai 37" LCT
If it has sound but no picture then one of the following parts is faulty, and must be tested and replaced:
The inverter is the high voltage board that provides variable power to the backlight lamp. This is the most common. When inverter is faulty you can get no picture, or a very dim picture that can only be seen by pointing a torch light with a 45 degree angle on the LCD surface from very near distance.
The inverter must be tested by reading voltages with a multimeter.
The LCD ribbon cable/LCD display and connectors.
This is quite uncommon, but happens. If the TV had been hit or moved the LCD cable may have slipped out, or the LCD connector may be damaged.
The LCD controller board.
This is the board that controls the video signal, it is difficult to test, as there is need to read determined values on IC pins. To test this board you need to purchase a service manual and follow the troubleshooting diagrams on service manual.
From description it looks like a faulty inverter, I think that is the first part to test.
If under warranty contact the manufacturer ringing the number on the user manual.
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
Posted on Apr 08, 2009
AKAI LCT 2060 was working well as a TV. Just hooked it up to my PC and the message on screen reads "No Signal" Checked monitor cable and it's good. checked old monitor and it works well. Why...
The display settings on your computer need to be turned down. Set it to 800x600 and move up from there, if the resolution is too high - the TV won't display it.
Feb 28, 2011 | Akai LCT2060 Television
Akai LCT 2060 TV will not turn on. Power unit shows blinking green light, but no picture.
Click HERE to download service manual copy as it was promised in chat session.
Thanks.
Jan 07, 2011 | Akai LCT2060 Television
I have a AKAI LCT 2060 TV, cannot see picture, only sound
This problems,i fix alot models of tvs all diffrent models of tvs but have the same board alway dies.The LCD inverter board is dead.This board help the LCD to have a backlight to go through the Turner board to produce a picture.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter board for the replacement.The board is long in shape.It the easiest board to replaced in LCD tvs.
May 07, 2010 | Akai LCT2060 Television
Problem with akai lct 2016
you can buy the new power supply on ebay for less then $20
Aug 28, 2009 | Akai LCT2060 Television
Akai LCT 328STA,Comes on Akai screen appears then goes off.
Akai LCT 3285TA (notice the "FIVE") uses the MLT169A Power supply. This is available from shopjimmy.com for about $100.
Jul 22, 2009 | Akai LCT3201AD 32 in. LCD Television
My Akai LCD TV/Dvd player will not turn on
http://www.fixya.com/support/t1661054-akai_lcd_tv_power_light_stays_red_turn
Jun 17, 2009 | Akai LCT2721AD 27 in. LCD Television
Akai lct 2070 tv switch does not turn on tv-no sound-no tv
Most failures on this TV are due to defective power supplies. If the TV does not turn ON, you should replace the power supply.
Check this website to buy the power supply adapter and hopefully that should fix the TV.
Jan 21, 2009 | Akai LCT2070 20 in. EDTV-Ready LCD...
Akai Model LCT 2662 problem
Open the back of the TV,and look at the can shaped items on the boards.If any of them have the tops,or bottoms bulged out,they need to be replaced.This should get it working again.I hope this helps.If you have any questions,please let me know.Thank You very much!
Tyler
Jun 03, 2008 | Akai LCT2662 Television
Akai LCT3701AD 37 in. LCD Television Logo
547 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
