Question about Wharfedale Moviestar 70+ System
Wharfdale moviestar 70 speekers and sub
I have 2 rear, 2 front, one centre front and a powered sub (moviestar 70).
I am not getting much out of the sub especially for music, dosent sound too bad for movies but still somthing is not quite right. I have a single cable ronning from the top corner plug (INPUT) going from my yamaha rxv450 amp SUB OUTPUT.
The sub is working but not very strong like I think it should be????
Anyone know how / where to get a user manual for these speakers, thanks.
Can anyone help me on this issue.
Thanks so much.
I have the same moviestars 70+ plus a yamaha rx-v750 put the crossover on the sub to maximum (left knob) volume (right knob) about 2/3 clockwise. change the crossover on the yamaha to anywhere from 80-120 ( the 120 will put more bass to the sub) if your yamaha has sub level/volume control set it higher, also if it has LFE/sub out set it to sub only.
Posted on Mar 11, 2009
I just got a multimedia surround system with subwoofer.Spa7650/05, 180w.The subwoofer has three audio connections,front,centre and rear,My tv only has an audio coaxial.I can't connect it.What adapter...
Firs of all lets get agree on something..The subwoofer has three audio connections for "output " to :front,centre and rear speakers...these are not for "input"..Your powered SUB provides necessary signal for other spekers..
You can connect TV audio coaxial to SUB input with a RCA cable.....if your SUB does not have "RCA input " probably it should have "3,5mm Haedphone female Jack"..
if this is the case you need to buy a cable ; one end 3,5mm MALE headphone jack and the other end 2xRCA stereo (or 1x RCA for mono or you may need "Y cable " ) to be connected to your TV...
And you need to connect front,centre and rear speakers to your SUB as well...
Take care and if it succeeds please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
Jun 22, 2011 | Philips Audio Players & Recorders
On the power sub-woofer, when turn the bass control toward 'maximum', the bass decreases and vice-verse
It sounds like you have it all figured out. Is it a problem? After all, it's just labeling.
Jun 21, 2011 | Wharfedale Moviestar 70+ System
When I do a noise test I get no sound out of the woofer. I am getting no bass from the woofer
These are "decent" quality 5.1 speakers, usually without any trouble.
Now, to your question, you will not have 5.1 "surround sound" effect with standard sound card, standard sound card will provide only three speakers sound, rear speakers will not connect but bass should be hear. Please switvh power off to the speakers and disconnect all cables from spaekers and connect them for best quality as follows:
1. Audio from PC, orange, green and black connecting to front right speaker.
2. DB15 (D-SUB) connecting to subwoofer, subwoofer is serving as mixer, power board, amplifier and connection box, control pod is just cable connection to it
3. Connect all cables to they respective speakers
Establish location of the speakers, from experience, in ideal world:
1. Sub should be on about your knee level or below, about twice your hight from you.
2. Front centre speaker should be about some distance as sub or bit closer on front and slightly above your head.
3. Front left and right speakers should be at about 45degree from your axis, at distance of about 1.5 your hight and on the level of your head or slightly below.
4. Rear left and right speakers should be located similiary to front speakers, on they level or slightly above them, again, about 45degree from your axis.
Location of the speakers is more actually important than it is assumed, total sound immersion is not possible without proper speakers installation. Head in these instruction meant a location of your head while you are listening to your music or recording not while you are standing.
In reality... hang them higher than your head in four corners of your room, front centre higher than sides, woofer lower than sides and below front centre, if they interfere with each other - increase the distance. I hate reality...
After speakers are connected:
1. Plug power cord in,
2. Turn all sounds totally down, including subwoofer
3. Increase sound on PC to maximum, let play any known to you music, tufftuff or bach, whatever, do not bother with metallica as you cannot discredit on it correct levels.
4. Increase subwoofer volume, holding one hand on the front of the grill till you get some vibration from it
5. Increase sound on centre speaker, then on sides front speakers till you achieve equality of the sound
6. Decrease sound volume on your PC to about 60% - 70%
7. Increse subwoofer volume till you feel sound on your hand in front of the speaker.
8. Increase sound volume on front/rear speakers as required.
Hope that short intro solved all your speaker problems, enjoy! if you require any additional help, do not hesitate to answer to this post with request.
Aug 12, 2010 | Logitech G51 5.1 Multimedia Surround Sound...
I cannot seem to get the driver working on my new computer which has windows 7 currently. Are the two compatible?
Are we looking at this same computers? Since when do you require drivers for speakers?!? Speakers are dumb devices (yes, this is correct name for passive computer devices) and do not require any drivers in any computer or operating system with sound capability! Computer speakers are compatible with any copmuter in the world and any operating system which generate sound!
These speakers are qualified as 5.1, that meant that these speakers will have front bass, front centre speaker, front left and right speaker and rear left and right speaker, in total six speakers.
Please follow this advice and you will have joy of surround sound.
1. Mount your subwoofer in front centre, below your knee level at the distance of about 2 of your hights
2. Mount your centre speaker in the centre on your head/hight level or slightly above at same distance as subwoofer or slightly closer.
3. Mount left front speaker about 45degree from your centre line to the left and right same distance to your right, on the level of your head while you are listening to the music, distance from you slightly closer (about 1/2 your hight) than your centre speaker.
4. Mount your rear left and right speakers at same or slightly greater distance as front left and right speaker. these should be at same or slightly higher level as front speakers.
5. Triple 3.5mm jack is going to your computer output and your speakers (incidently, your subwoofer servers as junction box, amplifier and mixer).
6. Connect speakers to they respective jacks.
7. Turn power on speakers all way down
8. Connect power to the speakers and switch it on
9. Play some music on your computer, output on full, music recommended will be some classic, like bach or similar
10. Put your hand in front of subwoofer and turn bass till you feel vibration
11. Turn sound till you hear it well
12. Turn sound on the computer down till about 70% - 80%
13. Turn on sound on your speakers till desired level and enjoy the experience!
If you have still some problems, these can be then related to the drivers installed on your computer, please check therefore what motherboard do you have, if there is proper sound drivers installed. If not, go to the site of our motherboard/sound card manufacturer and install relevant drivers.
Please do not hesitate to ask me if you have any addtional problem related to this particular issue.
Aug 06, 2010 | Creative Labs Inspire T5400 Computer...
I bought these x 240 speakers used. do i need a driver to run them? where do i connect the plugs, black and green?
These are "decent" quality 5.1 speakers, new were on about $100.00 to $150.00, have two years warranty from time of purchase.
Now, to your question, you will not have 5.1 "surround sound" effect with standard sound card, standard sound card will provide only three speakers sound, rear speakers will not connect.
Connect speakers as follows:
3. White plug is connecting to front left speaker
4. Red is connecting to front centre speaker
5. Black is connecting right rear speaker
6. Yellow is connecting left rar speaker.
Establish location of the speakers, from experience in ideal world:
2. Front centre speaker should be about twice your hight distance from you, on front and slightly above your head.
Location of the speakers is more actually important than it is assumed, total sound immersion is not possible without proper speakers installation. Head in these instruction meant a location of your head while you are listening to your music or recording not whil eyou are standing.
5. Increase sound on centre button of the right fron speaker till you achieve equality of the sound
Aug 06, 2010 | Logitech X-530 Computer Speakers
No surround sound from my Denon 3805
well as long as all signals are routed through the Denon your on the right track, now what else you have to do is connect all devices to the reciever do not loop one device through another. Also you have to try the different surround fields to hear the one you like the best for music I use 5Ch stereo for movies the surround field varies based on the type of movie
Feb 01, 2009 | Denon AVR-3805 Receiver
Bose lifestyle 5
I cannot exactly solve this issue but I can make a comment based on investigation. Lots of people have this issue but there are very few comments to help solve the issue unfortunately.
I have the same issue and have been able eliminate various things because I have a second complete Bose Lifestyle 5 system.
It is clear the issue does not lie in the Sub and is related to the Music centre unit. I can use a second identical music centre to power my sub just fine and my broken Music centre cannot drive my second sub.
Now the issue is knowing where to track down R428 in the music centre which is the suggested fix to this issue. I have opened my unit and there are resistors various Resistors in the 400 range but no R428.
If anyone can help with the location of R428 in the Music Centre I would be very grateful.
Thanks,
Jeff
Nov 06, 2008 | Bose LifeStyle 5 Series-III CD Shelf...
Subwoofer not powering enough (Sounds like under powered 8inch)
get a nice monster subwoofer cable and a Subwoofer PowerCenterâ„¢ SW 200 with Clean Powerâ„¢ Stage 1 get it from like amazon and you'll definately see a difference and also put the sub in like a corner
Jun 08, 2008 | JBL S120PII Subwoofer
Logitech x540 speakers- rear speakers distorted on matrix mode
I installed my soundcard which is the sound blaster SE audigy but when i try to test the sound i see that it does not sound separately.What i have to do to make them sound saperately when i'm testing it ?
Apr 16, 2008 | Logitech X-540 Computer Speakers
Wharfedale Moviestar 60+...
witch company your sub woofer. aleredy company has given user manuval see connections in manuval okkk
Mar 12, 2008 | Wharfedale Moviestar 60+ System
Wharfedale Moviestar 70+ System Logo
663 people viewed this question
Top Wharfedale Audio Players & Recorders Experts
jason
Are you a Wharfedale Audio Player and Recorder Expert? Answer questions, earn points and help others
