Question about Panasonic AG-DVC62 Mini DV Digital Camcorder
Give me hints
Dear sir, My camera (AG-DVC62EN) at time does't switching ON. If ones ON means all other function will be ok. Please give me the suggestion for service. Thanking you Udupi
    President:
  • 3,130 Answers
This model and most of the Panasonuc camcorders have surface mounted capacitors and these are what we have been finding wrong most of the time. The capacitors will become weak and start to leak goo and sometimes will blow something like a small fuse inside called a circuit protector. To find these bad capacitors, you will need to disassemble the camcorder and use whats called a ESR capacitor checker. I had a camcorder once that I replaced 27 bad surface mounted capacitors in. Good Luck.
Posted on Mar 26, 2007
I have sony vaio S. but the wirelees is not working no wireless host shown. how can i fix it?
Selecting the wireless function Follow the steps below to select the wireless function to be activated when you set the WIRELESS switch on your computer to on. Double-click (wireless switch icon) on the Notification area at the bottom right of the desktop.The Wireless Device Switch dialog box appears. Hints The appearance of the wireless switch icon changes depending on the selected wireless function. Point to the wireless switch icon to display the selected wireless function. Alternatively, you can right-click the wireless switch icon and select "show Wireless Device Switch settings" to display the Wireless Device Switch dialog box. Select the desired wireless function from "Wireless LAN" or "Bluetooth Device". Notes 5 GHz Wireless LAN is available on certain models only. You must select at least one wireless function to perform wireless communications. The 2.4 GHz and 5 GHz Wireless LAN functions employ different frequency bandwidths, thus are not compatible with each other. Checking the check box for both "Enable 2.4 GHz Wireless LAN" and "Enable Bluetooth Device" may cause poor communication performance or a connection loss due to electromagnetic interference. Click OK. The message "Setting up the wireless devices. Process may take several minutes. Please wait." appears first, then the Wireless Device Switch dialog box is closed, and finally the dialog box that describes what to do with the icon on the Notification area appears. Note While the message "Setting up the Wireless Devices. Process may take several minutes. Please wait." is displayed, do not: place your computer into power saving mode. turn off Windows or log off from the current user. turn on and off the WIRELESS switch. Confirm the settings and click OK. The dialog box about the icon on the Notification area closes. Hint If you check the "Don't show this dialog in the future" check box, the dialog box will not appear next time you close the Wireless Device Switch dialog. To analyze the network condition You can analyze the network condition if you select either or both of the wireless functions under "Wireless LAN" in step 2 above. Click the "Diagnose" button to start Windows Network Diagnostics. When the network analysis is complete, the result is displayed. If any problems are found, follow the on-screen instructions. Hint Windows Network Diagnostics is the function to identify problems the network has and present solutions to them.
Mar 01, 2011 | Sony Computers & Internet
1) I turn on the power and place a prerecorded
If it is not a bad soldering joint somewhere, it could be the mode switch. They can sometimes be cleaned with Servisol Video 40, but you might have to replace it.
Dec 21, 2009 | Panasonic AG-1980 S-VHS VCR
RE: freezing pictures
you can go into the video setting menu and switch off a function called still but you may face a jump in the image when switching between cameras; so its either a freez or a jump your choise.
sorry Its not detailed but if I remember correctly the details are in the user manual page 55 or 56.
hope ur problem is solved.
Aug 15, 2008 | Panasonic AG-MX70
Give me hints
head cleaning is enough. and or guide alignment may need. contact a professional service technician.
Nov 25, 2007 | Panasonic NV-MD9000EN Mini DV Digital...
Hints
it is general fault in this camcorder get a clean path tape and you may get better work regards
Apr 25, 2007 | Panasonic NV-MD9000EN Mini DV Digital...
Pretend record issue
I've had this happen with a Panasonic when I went back out into the cold after going into a warm, humid cafe for lunch. The drum had picked up some condensation, but the condensation detector didn't shut down the camera.
Mar 30, 2007 | Panasonic AG-DVC7 MiniDV Proline Camcorder
Please help
non scarica le foto della memoria interna
Feb 03, 2007 | Kodak EasyShare CX7330 Digital Camera
Please guide me
it is a mechanical fault with the front damper of the zoom path check all mecxanical plastic related parts regards
Nov 03, 2006 | Panasonic AG-DVC62 Mini DV Digital...
How to connect Remote to computer
Hello Nairy, Install infrared module onto IrDA connector, and enable function from the BIOS setup. Make sure you have the correct orientation when you plug into the motherboard. Location: Towards rear of motherboard, next to first PCI slot, on AGP side. The number one pin is closest to rear of board. Pin Configuration: 1. +5V 2. NC 3. IRRX 4. GND 5. IRTX 6. NC Please let us know how this works for you, and if we can help you in any other way. Best regards, nightdiver
Sep 20, 2006 | Acer AOpen AX 59 Pro II (91.87810.402)...
Panasonic AG-DVC62 Mini DV Digital Camcorder Logo
123 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
