Question about Zanussi ZWF1430W Front Load Washer
Zanussi electrolux washing machine zwf1431w
Washing machine keeps stopping mid wash and coming up error 20 zanussi ZWF 1637w keeps stopping and reporting E20 as a fault, how do i fix this?
  • 3 more comments
  • itchysb Dec 31, 2008
    the machine is not draining and it still has a load in it how do i get the load out
  • Anonymous Jan 29, 2009
    I've had the same E20 error initially during the Synthetics wash but now stopping during all washes approximately every 1-3 minutes on our ZWF1431S.
  • Anonymous Mar 18, 2014
    an e20 error on my simpson washing machine
  • Anonymous Mar 23, 2014
    error 2 keep coming up on a bush washing machine what caurses it
  • Anonymous Mar 25, 2014
    stop washing machine
  • 17 Answers
Error E20 means the machine has failed to pump out. 1st check the filter at the bottom right hand side there may still be water inside if so pull the grey tab to the left of the filter there should be a thin hose extend it put it into a shallow dish and pull the cap off to let the water drain this may be a slow process. When the filters out look into the hole with a torch to see if any obstructions in the pump impeller this looks like a cross. If the filters and pump are clear it may be the pump has failed.
Posted on Dec 17, 2008
SOURCE:
My washing sent in control panel alarm is ( EHO) what problem model ( zanusssi zwf 16581w)
C\nt find a fault code EH0. EH1 EH2 AND EH3 all relate to power supply problems voltage to high or low . the electronics dont like a dirty supply spikes and fluctuations upset them. they dont always work from a small generator supply.
Jul 25, 2010 | Zanussi ZWF1650W Front Load Washer
Error code E20 comes on during a wash cycle. i
If the filter is clean and the hoses are free of obstructions,you will need to replace the pump
Oct 18, 2009 | Washing Machines
Zanussi Electrolux ZWF 1430 W (E20 error)
I'm fairly sure that this is a warning that the filter is blocked. There is a filter in the bottom right hand corner of the machine.
Now, as stated by the other user here, your problem is that you have a machine full of water and if you remove the filter, you are going to get a very wet floor. The trick here is:
Turn the power off at the mains and remove the plug from the wall. Wait ten minutes. This SHOULD power off the safety feature that allows you to open the front load door.
Presuming it does, pull the machine out if it is under a work surface and taking great care because of the weight, tip tha machine backwards until the water level is below the door (Having a chair or a box to rest the back of the machine on is a good plan here, so you don't tip it beyond about 45% and have it fall on ots back.
If the door will open, then you can now rescue any clothes and bale out the water with a cup. Once you gave got to all the water you can (Memember there is still more waqter out of sight and in the pipe going to the filter!) You can now tip the machine back a little further until the water is clear of the filter in the botton right of the machine.
NOW, you can take the filter out, remove the fliff, couns, old sock and other debris clogging it and screw it back in place. TIp the machine back on to its feet and put it back.
Now, make a note in your diary to check the filter ever 6-8 weeks or so. Once you have done a few check and cleans, you will figure out how oftem you need to clean the filter, which depends on what you wash and how much you wash it.
Aug 04, 2008 | Electrolux EW1000i Front Load Washer
RE: ERROR E40 ON ELECTROLUX ZANUSSI JETSYSTEM 1200
hi there e40 fault could either be your door interlock or main pcb
Dec 11, 2007 | Zanussi FJS1225W Front Load Washer
Error code e30
This error relates to the motor drive. Plug off the wall, open up behind, look for broken belt. If the belt is good its the motor brushes. Secure connections to the motor, look for loose wires.....
& pl rate if helped...............
Dec 04, 2007 | Zanussi FJS1225W Front Load Washer
Zanussi turbo dry 1200
Try cleaning out the pump, and main hose to sump. If problem persists replace pump.
Slim Jim
Nov 12, 2007 | Zanussi FJS1225W Front Load Washer
Check water "forreign object trap". It's under the lid at the bottom of the machine. First drain water by pulling out the hose and pull out the plug. Then unscrew the trap. Have had this E20 error twice. First it was two coins there, next it was a big paperclip. Have worked fine ever since.11_20_2011_8_57_27_am.jpg
Sep 26, 2006 | Zanussi ZWF1430W Front Load Washer
Zanussi ZWF1430W Front Load Washer Logo
1,325 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
jimorris77
Marvin
Marvin
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
