Question about Nikon COOLPIX L4 Digital Camera
Lens Error I fell while holding my camera. The lens was open at the time and when I got up I turned the camera off. I then turned it back on to check it and the lens opened and immediately closed with the "lens error" on the screen. I can turn it off and on and the lens will always open but closes as soon as it has opened with the lens error on the screen. The shutter opens but closes also, like the lens. Can this be fixed? It was a gift so I don't have the bill of sale but I still have the original box and paperwork.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Feb 22, 2010
How do I fix lens error problem on the described camera?
hi,
lens error occur normally when it fell or the lens shaken, if so open the camera, take the lens unit out, disassemble the lens unit, then fix it again properly. example below:
(this is not the told model)
Dec 10, 2015 | Nikon Coolpix S3000 Digital Camera
Why is my lens still stuck, and why does it not seem to charge?
Send it back to Nikon for repair, or buy a new one.
Jun 09, 2014 | Nikon COOLPIX S3300
My camera fell on the floor and a lens error appeared when i tried to open it
Good day,
This tip will explain a few methods on how to try and fix your lens if it is stuck or you get a lens error on your screen.
Please note that all these methods are used at the users own risk and that I can not be held responsible for any damages or losses that occur while trying these methods.
1. If your camera is still under warranty, send your camera to the manufacturer to be replaced or fixed professionally.
2. If your camera is out of warranty try these methods.
  • Make sure your batteries are fully charged.
  • Remove the batteries for 10min. Replace the batteries and see if the problem persists.
  • Try compressed air. This method can be useful if there are any sand or any other object stuck in the lens motors. Use compressed air with a fine tip. Direct the air between the camera body and lens and move in a circular motion around the lens to complete a full rotation.
  • You can also try to tap the padded USB cover firmly on a flat surface like a table. This is sometimes a surprisingly effective method.
  • The last method is to try and force the lens. Turn of your camera and place it on its back on a flat surface. Look at the spacing between the lens and the body and see if the gap is consistent all the way around the lens. If the gap is not even it is likely that the camera fell while the lens was extended. Now VERY GENTLY push down on the lens were the gap is the biggest until you her a "click". This will indicate that the lens is back in place. Try powering back on.
  • If the lens does not extend or it extend and retracts turn of the camera. Hold the camera in your one hand and with the other hand turn the one part of the lens in a circular motion. Rotate both sections of the lens until you hear a "click". This will indicate that the lens popped back in place. Power the camera back on.
  • The last method you can use is to turn the lens while powering on the camera until you hear a "click". Power the camera of and back on to see if it works.
If any of the methods listed above failed to work for your lens problem it would be wise to take it on to a professional to get your camera repaired.
Thanks for taking the time to read my tip and feel free to let me know if it was of any help.
Regards
15073327
Mar 13, 2011 | Casio EXILIM EXZ35 Digital Camera
Lens Error!
In My case, the lens was coming out part way a start up and pulling back in without camera coming on. Some times the screen would stay a dark blue and could not be shut off. Ensure batteries are new or remove and replace existing. Lens will come out part way and retract when the battery door is opoened and closed. Press "on" button and as the lens comes out touch and hold the lens, with a finger placing pressure on the side of the lens. The lens will stay out. With camera upside down blow into the sliding mechanisms of the lens. Grip the furthest most extened lens with two fingers and pull the lens all the way out with steading pressure. The pressure should be equivalent to lifting one to two pounds of bread with two fingers. Perform this with the camera upside down so that any dirt particles can fall out. A slight rocking (side to side motion) of the lens may help. Once fully extended, open and close the battery door. The lens should retract. Turn on the camera. A couple of ideas relatd to this problem 1) If the concentric circles of the lens are not even, this could indicate a large grain of sand. After lens is extended or partialy extended push the lens on the side where the largest gap is while the camera is upside down. This may provide a larger gap for the grain to fall out. 2) Dirty camera case. I turned my camera case upside down over a piece of white paper and was amazed at the particles of sand that fell out. I turned the case inside out and completely brushed and vacuumed the case.
Jul 13, 2009 | Nikon COOLPIX P60 Digital Camera
Camera lens stuck
Look at some of my posts today.
This may be that the lens is off track and may be able to be pushed back by a little force as you start the camera....see my other posts on this problem.
Jun 11, 2008 | Nikon COOLPIX L3 Digital Camera
Lens error
your lens are stuck! did you drop the camera? you need to get a repair on the lens
Jan 10, 2008 | Nikon COOLPIX L3 Digital Camera
Nikon Coolpix L12 It has a constnat lens error screen
mine has that too....urgh i need to take pics cuz im going on vacation too....joy
Dec 31, 2007 | Nikon COOLPIX S9 Digital Camera
Dropped camera-lens stays open
The only way to fix a lens error is to send into casio and have it fixed. Call them at 800-706-2534 option 2 and tell them you have a lens error. They will tell u how to go about sending it in for repair.
Nov 25, 2007 | Casio Exilim EX-S600 Digital Camera
Lens is stuck and will not power on
Hi ive got a solution to this
apparently i have some bad news , its the lense which is misaligned or broken in terms of gears, the thing to do turn on the camera and make sure that lens is out and then LIGHTLY tapp on the lens the direction of which you feel that the lens is not equal legnth to the outer ring > place that looks uneven
Nov 19, 2007 | Sony Cyber-shot DSC-W70 Digital Camera
Nikon COOLPIX L4 Digital Camera Logo
297 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
