Question about Intel D102GGC2 Motherboard
Intel d102ggc2 ram
It support ddr2 533 bus ram,can i use ddr2 800 bus 1 gb ram.
  • Anonymous Mar 02, 2009
    I dont know what can happen... I dont want to try... if you know anithing write me barclley (at) hot... Regards !!
  • barclley Mar 02, 2009
    I dont know what can happen...I dont want to try, I know a case in which fire of the board went out with a frecuency not supported ... (I clarify not specifically in this board, but I would not like to experiment at home) If you know something write me barclley @ hot... Regards !!
  • 48 Answers
Not sure of your question but in most cases if you use a higher speed ddr2 ram it will "dumb down" to the fastest that your motherboard will accept. So using a higher ddr2 is okay you just dont get all the performance out of it.
Posted on Dec 17, 2008
I have intel pendium d d102ggc2 motherboard. am using 512 mb ram ddr2 667mhz. Now i want to upgrade it and use 2 gb ram. please suggest.
Mother board d102ggc2
• Support for DDR2 533 MHz and DDR2 400 MHz DIMMs
• Support for up to 2 GB of system memory
Dec 27, 2012 | Intel D102GGC2 Motherboard
I am using D102GGC2 Desktop board with Intel Pentium D Processor 2.8GHz and using 512MB DDR2 PC-533 RAM. Nw I want to upgrade to 2GB and decided to purchase 2 * 1GB DDR2 PC-667 RAM. Will it be compati
Hello here is the homepage:
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Third-Party+Chipset+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+D102GGC2
You can only add 1gb per slot Because the mb does not supports a bigger module.
This ram type does come as 1 gb module.
The 667 mhz and 800 mhz is the Mhz speed for the ram module.
Your mainboard supports this but it will only run the current front side bus speed as the mainboard supports.
This means that the new ram will only run 533/400 mhz as the mb supports.
Hope this was helpfull
Nov 23, 2012 | Intel D102GGC2 Motherboard
I have a 512 DDR2 (533 FSB) RAM in one of my slot in Intel D102GGC2 Mother board,can i put a 2 GB DDR2 ram in another slot.If yes then What FSB will match and what is the maximum capacity of ram per slot?
This motherboard will support maximum 2 GB of total system memory. so configuration is should be 1GB + 1GB or one 2GB in one slot. If you attempt to install 2GB + 512MB, this is unsupported. but you can try if might the system can read it or not. there is no serious problem for installing memory exceed than maximum system memory...
Memory supported is DDR2 533 Mhz and DDR2 400 MHz...(sometimes on the market DDR2 533 will described as module name PC2-4200 and DDR2 400 as PC2 3200)
Aug 10, 2011 | Intel D102GGC2 Motherboard
I bought new 2gb ddr2 with 800 mhz and its not working on my motherboard d102ggc2 can u plz help me with the solution
i guess you did not check the compatibility of the RAMs to your MB limitations....
the only solution is to return the RAMs and get the RAMs that is supported by your MB.....
the MB (D102GGC2) can hold only a max of 533 mhz and max of 1GB each in each slot of RAM....
so if you are trying to install one 2GB card of 800 mhz IT WIILL NOT WORK....
get TWO RAM cards of 1GB each (total 2GB) of RAM.... each of 400 mhz....
hope this helps...
Reg
Suresh
to check what your MB supports, look for the details below...
http://www.intel.com/support/motherboards/desktop/d102ggc2/sb/CS-029352.htm
Intel® Desktop Board D102GGC2 Technical product specification circuit388.gif Product Specification
This product specification applies only to standard D102GGC2 boards with BIOS identifier GC11020M.86A. Changes to this specification will be published in the D102GGC2 Desktop Board Specification Update before being incorporated into a revision of this document.
pdf.gif D102GGC2 Technical Product Specification [PDF]
File Name: D102GGC2_TechProdSpec.pdf
Date: April 2006
This document is an update to the specifications contained in the D102GGC2 Technical Product Specification. It is intended for hardware system manufacturers and software developers of applications, operating systems, or tools. It contains specification changes, errata, specification clarifications, and documentation changes.
pdf.gif D102GGC2 Desktop Board Specification Update [PDF]
File Name: D102GGC2_SpecUpdate03.pdf
Date: November 2006
Apr 27, 2011 | Intel D102GGC2 Motherboard
800 MHZ RAM NOT SUPPORTED
Pls check this link of supported memory for D102GGC2
http://www.intel.com/support/motherboards/desktop/d102ggc2/sb/CS-026579.htm
Even I am not able to find a 533 MHz 1GB ram. Let me know in case 667MHz RAM works
Jan 25, 2010 | Intel D102GGC2 Motherboard
I have 2gb of ram.but system detected 1 gb of ram
Make sure the board supports 2 gigs of ram, and make sure the board supports the type of ram you installed.
This info can be found either on the manufacturers website and/or the user manual that came with the board.
Mar 01, 2009 | Intel D102GGC2 Motherboard
Machine randomly restarts after upgrading RAM
Ok thats the problem.
1 module with 2gb is not possible on this board:
http://www.memoryxxl.net/mainboard::4345_36366/Intel-D102GGC2.html
Intel D102GGC2 Motherboard Mainboard Speicher Technische Beschreibung Intel D102GGC2:
Bus Architecture: - Hersteller Standard Ausrüstung: Non-ECC only, Unbuffered only, Chipset: ATI Radeon XPRESS 200 - vom Geräte Hersteller empfohlener maximaler Arbeitsspeicher: 2048MB - Speicher Upgrade: 2 (2 banks of 1) -Speicher Beschreibung: Jeder Slot kann mit DDR2 PC2-4200, DDR2 PC2-5300, DDR2 PC2-6400 und maximal 1GB Speicher aufgerüstet werden. Eine bessere Performance erziehlt man bei paarweiser Modul Installation. (USB Support: 2.x Compliant, Graphics Support: PCI Express x16) - Speicher Bus Architecture:
You have to use 2 modules with max. 1 gb per module
Dec 30, 2008 | Intel D102GGC2 Motherboard
Two 1 gb ram sticks not working together!
may be frequency is different of RAM,just check it
Mar 05, 2008 | Intel D102GGC2 Motherboard
Intel D102GGC2 Motherboard Logo
464 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
