Question about Dryers
Creda Reversair Sensa Dry Tumble Dryer produces no heat.
Model number is 37649,
Machine rotates and operates as normal but no heat in either the low or high heat setting. Do you think it is likely to be a thermostat cut-out or the heater element. Do you know if their are more than one thermostat cut-outs or more than one heating element?
  • 3,463 Answers
There is only 1 heater element, and normally one thermostat.
they are located at the rear of the m/c, behind a removable panel.
If you are not sure whether it is the element or stat, join the two
wires togeher that go to the stat, if the heater then works, replace stat. if no heat, replace heater.
plz leave feed back for this solution.
Thanks.
Posted on Dec 17, 2008
How to fit belt on Creda Reversair 37643 Tumble dryer
New belt is very tight, so you have to use more strength. Put it on motor and all other on "drum". Spin it easily and slowly but with strength until its done.
Be carefully, use gloves.
Apr 13, 2013 | Indesit Hotpoint Creda Tumble Dryer Belt...
I have a creda reversair anti tangle dryer and dont understand the heat setting button on the front, is it pressed down at the top for low or at the bottom as there is a green line shows if its pressed...
The issue isn't a "problem" with the dryer, the issue is that it's hard to tell which switch position enables the 'low heat' function. The question is:
Is the switch pressed in at the top or the bottom for 'Low Heat'?
Feb 18, 2011 | Dryers
Creda tumble dryer not heating up, drum is rotating with no probs, filter is clear, any ideas please?
either heating element is faulty or the stats are faulty...............
easy fix.........
Jan 16, 2011 | Creda W120VW Front Load Washer
My creda reversair dryer no.37642 doesn't rotate, although there is heat in the drum. What could be wrong with it?
Most likely the drum belt is broken or the tensioner is broken this is not to expensive to fix and the belt can be bought at any applince store.
Mar 10, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
How to fit creda thermostats
It depends on which make and model of tumble dryer you have as to how easy it is to replace the relevant parts. Some tumble dryers have heating elements that are easily accessible by removing the back panel, and can be tested for continuity or checked for obvious burning out or open circuit. Others though have their heating elements inside, which aren't accessible without stripping the dryer down we will try and cover as many as possible in or video tutorials section. Tumble dryer heating elements are always protected by thermal fuses and thermostats which are usually simple devices with 2 wires connected and have a bimetal strip inside them. They can be tested for continuity with a test meter.
The problem is that if a stat (thermostat) or t.o.c. (thermal overload cut-out) has gone open circuit, it may be for a reason. Overheating could have caused it by not being able to vent the air due to a blockage some ware. Blocked filters or even the machine not being allowed its ten minute cooling down period, Overloading can cause it as well. Sometimes they can go for no apparent reason. A blocked or severely kinked vent hosecan also cause overheating.
You-Tube video "ymXmpyVkxIE" placeholder (do not delete)
Jan 02, 2010 | Dryers
Creda tumble dryer T632CW is not heating up. Any
SOUNDS LIKE YOU NEED NEW HEATING ELEMENTS.
Oct 18, 2009 | Dryers
My creda tunble dryer model 37324 is working but
If you plan to try to repair the problem yourself, then the first thing you want to do is unplug the dryer from the electric.
Remove the back of the machine and try to locate the air tube going from the blower to the drum. Normally inside the air tube you will find the heating coil and the thermostats/thermistor.
Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor by removing the two wires and taping them together with electrical tape.
If the coil heats up then replace the thermostat/thermistor.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST. This could cause a fire, as you have removed the saftey of overheat from the machine.
Good Luck,
Hope this helps
Oct 17, 2009 | Dryers
No hot air from my tumble dryer
Hi.
You do not state whether it is a condenser or vented dryer.
the most obvious reasn for no heat is element and/or stats..
The only way to confirm which it is-- is to meter them out with a multi meter..
If you have one then set it on the ohms range and test the components for continuity, you should get full scale deflection if they are o/k.
You must disconnect the wires to the components, or you will get a false reading, and needless to say, have the m/c unplugged.
If all test o/k then the problem could be with the timer and or control unit, or the heater relay if it has one.Unknown to me as I do not know your model number.
If it is a condenser dryer, make sure all filters are clear, air intake and outlet vents clear, water container empty .
Plz rate my solution
Thanks
Dec 29, 2008 | Dryers
No heat to tumble dryer
Check the thermal disc with an OHM meter. One will be next to the heat element (high limit) and another on the air exhaust area which is the low limit.
Dec 16, 2008 | Dryers
Creda tumble dryer
It is probably the electric heater coil. How old is the machine? If a couple of years or more, the coil is probably burnt out. It is accessible through the back. Good luck!
Feb 08, 2008 | GE DBL333EA Electric Dryer
Dryers Logo
913 people viewed this question
Top Dryers Experts
