Question about Garden
I have an older Airens snowblower, model 924038.I want to take out the augers and impeller in 1 piece.I have the side bushings out,the auger is free.What is holding the shaft from coming out fro the drive pully.I took out the 2 set screws, but still wont budge.
  • nickpower
    nickpower May 11, 2010
    do you have the pulley and pulley hub off?
  • 43 Answers
PUNCH IN YOU MODEL TO GET PARTS DIAGRAM, MIGHT HELP YOU.
http://partsradar53.arinet.com/scripts/EmpartISAPI.dll?MF&app=ARNC531&lang=EN&TF=Empartweb&loginID=ariensc&loginpwd=consumer&partner=ARNC
Posted on Dec 19, 2008
Snowblower auger will not turn. When auger drive engaged, the belt smokes but auger does not turn.
the auger drive gearbox has failed and needs rebuild with new gears and lube
Feb 09, 2018 | Garden
Troy-bilt snowblower smokes when I try to engage auger. It’s the belt burning, but do I simply just replace the belt or is it something else that’s causing the belt to burn?
How old is it? Model? Can you move the auger single stage or augers 2 stage by hand when in neutral. Could be a ice jamb. or bad bearing. Do this with the unit NOT running. If it's a 2 stage take a 2X4 and insert in the chute
and try to wiggle or move the impeller. Bent impeller/auger? Maybe. check them visually.
Hope this helps.
Dec 26, 2017 | Troy-Bilt Garden
Replace snowblower belt
Locate the two top auger housing fastening bolts and remove. The auger housing will tilt forward and then lift the housing off of the bottom 2 bolts/bushings. You will need to support the traction frame as it will try to fall onto the handles.
Feb 27, 2017 | Mtd Garden
The impeller is turning but the blades are not. Belt seems ok
Depending on your make of snowblower, At the impeller there is usually 1 or 2 shear pins or bolts circled in red. If the impeller and the impeller shaft are turning but the augers are not, the gear may be stripped inside the gear box circled in yellow or the keyway may have sheared between the auger gear and the auger shaft.
Jan 24, 2016 | Garden
MTD 8/26 snowblower
Either there is a belt or a chain off, or the linkage became disconnected or there is a pin sheared. Take one of the three. If you have power spinning like you said then those are your choices! Best of luck to you. Hope you beat the weather!
Feb 11, 2015 | Mtd Garden
Auger on craftsman snowblower is very slow.how do i adjust idle
Not sure how long you have owned this machine but the auger does not turn fast. It 's job is to chop up the snow and push it back to the impeller. The impeller is the round plate in back of the augers that actually throws the snow out the chute. That turns fast. Check to be sure the shear pins are not broken. Shut the machine off. Wait for the augers to stop spinning and then try to turn the augers by hand. If they spin on the shaft then the shear pins are broken-replace them by using original equipment shear pins.
Dec 22, 2012 | Garden
Swisher 27" snowblower front impellers turn free
Hi Craig,
Most snowblowers incorporate "shear pins" between the motor and auger. A shear pin looks similar to a nut and bolt or pin that couples the drive to the auger - but it designed to break or shear off to prevent damage to the auger or motor in the event of a jam or overload. They look like these:
Only the shear pin recommended for your particular brand and model snowblower should be used. Under no circumstances should a regular bolt or other steel pin be used instead of a shear pin. Check your manual or consult with Swisher to determine the correct shear pin for your snow blower.
I hope this helps & good luck!
Dec 21, 2012 | Garden
Ariens snowblower impeller not throwing snow
Sounds like you have a broken or partially broken shear pin in the auger.Check along the auger[machine off]and see if there is what looks like a bolt anywhere along the auger shaft.If there is [and there will be] remove and inspect it and you will see why the auger is not working.Next time,never clean out a chute or auger while the engine is running,people loose limbs this way.
Feb 13, 2010 | Ariens 34 In. Zoom Series Riding Mower
Craftsman 247 88190 0 snow blower auger frozen
my auger and impeller froze too. fixed by clearing all snow, ice,stone build up behind impeller it works fine now.. hope that helps
Jan 19, 2009 | Ariens 34 In. Zoom Series Riding Mower
Garden Logo
61 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
