Question about Toshiba MV13L2 13 in. TV/VCR Combo
Need code for toshiba mv13j3 to put code in remote
Trying to find correct code for toshiba mv13j3 to program in a remote. This is a tv/vcr combo
  • 4234 Answers
SOURCE: Toshiba TV Combo MW24FP1, DVD player doesn't work on some discs
This is a common problem for all combo units. The high voltage of the TV section attracts large amounts of particulate dust from the air and often it collects inside the DVD unit. The best way to deal with this is to clean the lens of the DVD unit u sing a cotton swab and alcohol. The store bought "cleaners" MAY work, but that is rare. These cleaners are nothing but small brushes embedded into a disc. They attempt to brush off hte dust. This rarely works. Open up the unit (if you feel comfortabel in doing so) to access the DVD section. Remove the top cover and carefully clean the lens. That should resolve the problem.
Dan
Posted on May 21, 2008
  • 54 Answers
SOURCE: need codes for toshiba tv
You will find the codes you need here : http://www.mykameleon.com/support.html#rs
If the exact code is not listed for your model then you must do the code search. This sometimes takes a while because you have to search through every possible code! Goodluck!!
Posted on Aug 17, 2008
  • 4 Answers
SOURCE: Need help to re-program Toshiba remote that came with MW20FM1
Check out Toshiba Customer Support. They e-mailed me the instructions to reset the V-Chip.
customer_support@tacp.com
Posted on Sep 14, 2008
  • 56 Answers
SOURCE: toshiba 13' tv dvd combo, Fios remote control need code
Greetings!
Here are the codes: take a deep breath:
0181, 1283, 0183, 1292, 0087, 0677, 0859, 0872, 1183, 1383, 1683, 1731
You may find that these don't work. Often, with combination pieces like yours, you will find you are lucky if you can get a universal remote to turn it on and change the volume and little more. The fact that Toshiba did not build this peice can compound the problem. My suggestion, if you can't get the universal to program up, is to use the original remote for the set. If you do not have the original remote it is available from www.encompassparts.com for around $15.00 plus shipping. The original part number for the Toshiba remote is 72796929.
Rob
Posted on Jan 14, 2009
PABLOCSA
  • 1124 Answers
SOURCE: Universal Remote Codes
Try, 0045, 0043, 0845 or 0154, 0156, 0060
Posted on Feb 03, 2009
Need instructions and codes for toshiba t.v.
Hello
Codes for Toshiba TV with One for all URC 4220 are:
0060, 0154, 0156, 1265
[1] Turn on a desired device (e.g.,VCR or DVD player) and, if
applicable, insertmedia (e.g., cassette or disc).
NOTE: Please read steps 2 through 4 completely before proceeding.
Highlight or write down the codes and device you wish to program
before starting step 2.
[2] On the remote control,press a device key once (i.e., VCR/PVR,
DVD,CBL/SAT,or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo,
or TV/VCR/DVD Player Combo press VCR/PVR once.After programming
a VCR Combo device, you will be able to control channel selection,
volume,andVCR functions.
NOTE: To program control of a DVD Player,DVD Player/VCR
Combo, or TV/DVD Player Combo, press DVD once.After programming
a DVD Combo device, you will be able to control channel selection,
volume, and DVD functions.
NOTE: To program control of a Cable Box, Cable Box/PVR (or DVR)
Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR)
Combo, press CBL/SAT once.
[3] Press and hold SET until the LED (red light) blinks twice,
then release SET.
[4]Use the Manufacturer's Codes to
locate the type of device and brand name and then enter
the first four-digit code for your device. If performed correctly,
the LED will blink twice.
NOTE: If the LED did not blink twice, repeat steps 2 through 4 and enter
the same code again
[5] Aimthe remote control at the device and press POWER
once.The device should turn off. If it does not, repeat
steps 2 through 5, trying each code for your brand until
you find one that works. If it still doesn't work, try
Searching For Your Code on next page.
NOTE: If the device does not have a POWER key, press PLAY
OK.
Jul 03, 2011 | One For All URC4220 Remote Control
I have One For All URC-4063 remote control. How do I program it to my orion TV
Hello
The codes for Orion TV with One for all URC-3021 are
0236, 0463
The One For All 3 Device Universal Remote Control is preprogrammed at
the factory to operate an RCA TV, a Toshiba DVD player, and a Motorola
cable box.To control devices other than the default brands,perform the following
steps; otherwise skip this section:
1. Turn on a desired device (e.g.,VCR or DVD player) and, if
applicable, insert media (e.g., cassette or disc).
2. On the remote control,press a device key once (i.e., DVD/VCR,
CBL/SAT,or TV).
or TV/VCR/DVD Player Combo press DVD/VCR once.After programming
volume, and VCR functions.
Combo, or TV/DVD Player Combo, press DVD/VCR once.After programming
selection, volume, and DVD functions.
3. Press and hold SET until the LED (red light) blinks twice,
then release SET.
4. Use the Manufacturer's Codes (starting on page 18) to
the same code again.
Aim the remote control at the device and press POWER
NOTE: If the device does not have a POWER key, press PLAY.
Mar 20, 2011 | One For All URC-3021 Remote Control
I need code for URC-3220 Universal remote control for toshiba tv/vcr in one.
I can help you reprogram your URC-3220 Universal Remote for your Toshiba TV/VCR Combo.
The Toshiba TV/VCR Combo codes are 1145 & 0845.
Please review my Fixya Tip posts for:
TV/VCR/DVD Combo Codes
Searching for the proper codes, or
Downloading the URC-3220 users manual / owners guide.
I hope that helps.
Apr 07, 2010 | Universal Remote Control Remote Control
How can i put the code?
POR FAVOR NECESITO EL CODIGO PARA TV SANSUNG, SIN ESE DATO MI CONTROL NO SIRVE
Mar 19, 2010 | One For All URC-3021 Remote Control
Need Toshiba remote access code for this product so I can use a universal remote to operate the VCR and DVD
remote codes are set by the manufacurer of the remote not the tv. if there are any others not listed in instructions for remote, the manufacturer of remote would have them. most combo unit are not able to be programmed into universal remotes due to the fact that there are alot of specialized function buttons on original remote. you can obtain a replacement remote thru toshiba
May 16, 2009 | Toshiba MW24F51 24 in. TV/VCR/DVD Combo
Dish Network remote code for RCA 20F510TD TV/DVD
hello and please help.
want to know the codes and way to program this rca dish remote model RCR500SAM1 for my Toshiba tv.
ive done it a few years ago but forgot.
so i need the codes for toshiba tv and way to program this rca dish network remote.
grateful,
kay
Jul 26, 2008 | RCA 20F510TD 20 in. TV/DVD Combo
Big Easy programming
TV Toshiba 0154 0156 0060 1256PROGRAMMING
TV/VCR COMBO CONTROL
Perform the following instructions to
control a TV/VCR Combo:
1. Turn on the TV/VCR Combo and
insert a video cassette.
NOTE: Please read steps 2-4 completely
before proceeding.Highlight or write down
before moving on to step 2.
2. On the remote control,press VCR/DVD.
blinks twice, then release SET.
3. Use the Setup Codes For TV/VCR
Combos (on the back side) to locate
the brand name and then enter the
If performed correctly, the LED will
blink twice.
NOTE: If the LED did not blink twice, then
repeat steps 2 through 3 and try entering
4. Aim the remote control at the device
and press POWER once. It should turn
off. If the device does not respond,
repeat steps 2-3, trying each code for
your brand until you find one that
works. If it still does not work, try
Searching For Your Code.
POWER key, press the (PLAY) key.
hope that helps
Jun 26, 2008 | One For All URC-3300 Remote Control
Will a HRMC 8 Program to a dvd/vcr combo by Toshiba?
I HAVE A TOSHIBA TV AND I WANT TO PROGRAM MY REMOTE TO WORK BOTH. THE REMOTE IS A HRMC-B
Dec 15, 2007 | Hughes HRMC11 Remote Control
My allinone tv remote
PROGRAMMING DEVICE CONTROL
CBL/SAT,or TV).
then release SET.
4. Use the Manufacturer’s Codes (starting on page 18) to
5. Aim the remote control at the device and press POWER
you find one that works. If it still doesn’t work, try
6. Repeat steps 1 through 5 for each device you want to control.
For future reference,write down each working device
Here is a link to your manual:
http://www.ofausa.com/remote_manual/CTGA...
Dec 02, 2007 | One For All URC-3021 Remote Control
Toshiba MV13L2 13 in. TV/VCR Combo Logo
262 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
