Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
Whirlpool under counter oven, inside glass door broke.
I ordered the part but don't know how to open the door to replace the inside glass.  do you have any schematic guide?
  • 8,197 Answers
To get to the glass on the inside of the door you need to do the steps listed.
1. Open door 4" and pull straight up at that angle
2. Lay door on flat surface with the handle down to surface.
3. Remove all screws that you see .
4. The inner housing should be removable now.
Then you should see the glass. Reverse the steps to put back together.
Good Luck with the fix.
Posted on Dec 17, 2008
  • Jyackle5
    Jyackle5 Dec 17, 2008
    If that does not work you can call Whirlppool to get instructions at 1-866-698-2538
Remove door and glass on whirlpool gbd307pdq1 double oven
hi there sometimes glass will just pull up on sliders on the side just open door etc and the glass panel should simply slide up.
Nov 27, 2011 | Whirlpool Ovens
The inside glass of my built in double electric oven has cracked and now has a small piece of glass missing. Can the glass be ordered and replaced or do I need a repairman?
You should be able to obtain a replacement door glass from the manufacturer. They are normally available for most makes of ovens.
Jan 26, 2010 | Whirlpool Ovens
THE INSIDE GLASS BROKE
part number is 4449259 of the inside glass you will pay around 60.00 for it good luck
Jan 12, 2010 | Whirlpool RBD305PRS Oven
The glass front broke off from the screws holding it to the door-how to fix??
You just have to order the front glass and when you order from us, with this part will come instructions on how to remove and replace it.
You may contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
We look forward to getting you cooking again. :>)
Nov 07, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
How to clean inside glass on oven door
If you can, usually it is possible, remove the door from the oven. open door to the first open position..(broiling) about 6" open then (make sure any screws are removed from hinges holding door in place) lift up and out at the angle the door sits.place on counter and start removeing screws. can be a whole bunch of em..
Oct 24, 2009 | Ovens
Whirlpool 6MFOS oven not heating
Do you still have this oven? I broke my glass door and need a replacement. thanks
Oct 19, 2009 | Whirlpool Ovens
Loose/broken seel on inner door glass of oven
Yes it is still avalible I looked it up and there is one in Texas here is the number to order. Genuine Parts & Accessories (800) 935-0062 please rate if this helped.
Aug 07, 2009 | Whirlpool GBS307PR Electric Single Oven
Need to clean liquid drip from inside of door whirlpool built-in
Hi, The screws in the bottom edge of the door will need to be removed. The dor handles screws usually help hold the upper part of the door together. There might be screws on each side. Makes sure the door is laying on a flat surface and be gentle with the glass pieces. They are very fragile.
I am sending you a picture of the door pieces and how they line up inside the frame.
Please let me know if I can assist you further.
Vic
Jul 12, 2009 | Whirlpool RBS245PDS Electric Single Oven
Broken inner glass on Model # NGSG3PZAQA
To replace the door glass do the following:
0 Check if there is a hinge stop bracket located at the hinge point of entry on the oven, in that case remove it.
1 remove the oven door by pulling it up and removing from the the hinges. If glass is broken , then secure glass with tape. Have a table with a cloth on top ready to lay the door.
2 Remove the outer screws , starting from lower side of the panel.
3Removethe inner screws. Keep all set of screws ordered, and take note of theorder you remove them. You will follow reverse order in reassembly.
4 the frame will be free now,
5 Remove the external glass panel and leave it in a safe place.
6 Replace the inner glass.
7 Clean outer glass and metal door, re-assemble it and mount it back
I also report testimonials for your model:
removed the door from the oven by releasing clips attached to the door hinge -- very nicely engineered. Removed about 6 philips head screws to allow the door assembly to be taken apart for access to the glass. Lifted out the broken glass, cleaned the inside of the door, installed the new glass, reassembled the door (a two minute project), and reattached the door to the oven. Cleaning the inside of the door"
I removed the oven door by lifting it off with the hinges. Disassembled the door parts one at time making sure I remember where I removed the screws until I am able to get to the broken glass. The most difficult part is making sure that the insulation strip & the gasket stayed in place after I replaced the broken glass & doing the reverse process of installing the parts together. Relatively easy process as long as you remember where the parts go. When in doubt, I had to refer to the pictorial of the disassembled door shown on your website. "
See diagram below , click on picture to enlarge:
Part here: Inner Door Glass
Mar 17, 2009 | Frigidaire FGB24S5A Gas Single Oven
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
152 people viewed this question
Top Frigidaire Ovens Experts
Oloyede Monsuru
Craig Butler
Craig Butler
Starnley Johnwells
Starnley Johnwells
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
