i-mate JAM Pocket PC Logo
Charles Mott Posted on Mar 26, 2007
Bluetooth/hands free My car is set up for Bluetooth. I have been able to pair my i-mate to the car. But when I set the phone to hands free it re-sets itself after two minutes.
Anonymous
Level 1:
  • Contributor 56 Answers
  • Posted on Jul 31, 2007
Anonymous
Contributor
Level 1:
Answers
56
Questions
Helped
46998
Points
92
The problem in the session time ... by the defualt it's 2 min .. try to change it from the bluetooth setting or connection setting ... if you find this help is useful please rate me !
1helpful
When on my phone it kicks me off the radio?
If you have a Bluetooth u-connect radio and Bluetooth phone it is likely the settings of the phone and car radio are to pair. I expert that during the pairing process and hands free operation the radio sets itself to mute.
Check settings!
Hope this helps?
Why my iphone can not find any bluetooth devices
iPhones cannot pair with bluetooth devices other than headsets and hands-free sets, you cannot transfer files or do anything else except use bluetooth headsets or hands free sets. This is why your phone cannot find other devices.
5helpful
2answers
How do I pair my phone to my blue tooth
Connecting a Bluetooth headset or car kit You can listen to music over a Bluetooth stereo headset, or have hands-free conversations using a compatible Bluetooth headset or car kit. It's the same procedure to set up stereo audio and hands-free.
  • For you to listen to music with your headset or car kit, the headset or car kit must support the A2DP Bluetooth profile.
  • Before you connect your headset, you need to make it discoverable so your phone can find it. You can find out how to do this by referring to your headset manual.
  1. From the Home screen, press MENU, and then tap Settings > Wireless & networks.
  2. Tap Bluetooth settings.
  3. If the Bluetooth check box is not selected, select it to turn Bluetooth on.
  4. Make sure that the headset is discoverable.
  5. Tap Scan for devices. Your phone will start to scan for Bluetooth devices within range.
  6. When you see the name of your headset displayed in the Bluetooth devices section, tap the name. Your phone then automatically tries to pair with the headset.
  7. If automatic pairing fails, enter the passcode supplied with your headset.
The pairing and connection status is displayed below the hands-free headset or car kit name in the Bluetooth devices section. When the Bluetooth headset or car kit is connected to your phone, the Bluetooth connected icon is displayed in the status bar. Depending on the type of headset or car kit you have connected, you can then start using the headset or car kit to listen to music and/or make and receive phone calls.
1helpful
How do i pair my jabra bt250 to my htc desire hd
The pairing and connection status is displayed below the hands-free headset or car kit name in the Bluetooth devices section. When the Bluetooth headset or car kit is connected to your phone, the Bluetooth connected icon howtoimage.aspx?id=12046 is displayed in the status bar. Depending on the type of headset or car kit you have connected, you can then start using the headset or car kit to listen to music and/or make and receive phone calls.
1helpful
I have a parrot ck3100 and trying to pair it with my nokia 5800 xpress music phone but comes up with cannot pair with the parrot. Help!!!
go to settings, pair devices and delete all the old pairings, then go to settings, pair with phone and start new pairing.
12helpful
2answers
My RAZR V3 won't pair with 2009 Chevrolet Silverado bluetooth
http://www.gm.com/vc/bluetooth/index.jsp?brand=chevrolet&landing=true
PAIRING A PHONE WITH YOUR 2009 Silverado
Before you begin:
To take advantage of the Bluetooth for Chevrolet functionality, you must first pair a Bluetooth-enabled phone to a Bluetooth-enabled vehicle.
Note: If you do not pair a Bluetooth-enabled phone, all calls will be made using OnStar® Hands-Free Calling.3
Some additional tips:
1. You can pair up to five phones with your 2009 Silverado.
2. Your system automatically recognizes the first phone you pair. To use a different paired phone, you must
select it using the "Change Phone" command.
3. Only one paired cell phone can be connected to your system at a time.
4. When the vehicle is in motion, you cannot pair a phone.
5. Pairing should only need to be completed once (unless changes to the pairing information have been made, or the
phone is deleted).
PAIR YOUR PHONE
Set up phone - Turn Bluetooth 'ON':
1. From the main screen, select "Menu"
2. Select "Settings & Tools"
3. Select "Connections"
4. Select "Bluetooth"
5. Select "Setup"
6. Select "Power"
7. Select "On"
Set up vehicle - Enter 'Pairing' mode:
1. Press and hold the Push to Talk button for two seconds
2. Your system will respond with a "Ready" message followed by
a tone
3. Clearly say "Bluetooth"
4. Your system will respond with a "Bluetooth ready" message
followed by a tone
5. Clearly say "Pair"
6. Your system will respond with instructions and a four-digit
Personal Identification Number (PIN); you will need to enter
this PIN on your phone
Begin the pairing process on your phone:
5. Select "Hands free"
6. Select "Look For Devices"
7. Select "General Motors"
8. Select "Yes" to bond with General Motors
9. Enter the PIN code provided by the vehicle
10. Select "OK"
Finish the pairing process in your vehicle:
1. The system will prompt you to give a name to your phone
2. Say a name that best describes your phone (example: Corey's
phone); this name will be used to indicate which phone is
connected
3. Your system will ask you to confirm your name
4. If you confirm that name, the system will respond with the
message: "'<Phone name>' has been successfully paired"
2helpful
Connection
Try deleting all paired device from the parrot and your phone, remove battery from you phone to reset it. Then follow below instructions from Parrot.
Pairing Devices: ** From your car kit:
** Select SETTINGS / ADVANCED SETTINGS / PAIR WITH PHONE / OTHER PHONES
* From the phone:
* Select MENU / SETTINGS / BLUETOOTH / MY DEVICES / SEARCH NEW DEVICE
* The phone will search for available devices
* Select CK3100 from the list of available devices and enter PIN code \"1234\"
* Phone and CK3100 are now paired. Wait for auto connection
2answers
Pairing a Motorola H850 to A Lg5300 cell
hi
turn on your hands free device. find "connectivity" in settings on your phone. then "bluetooth link". then "hands-free". turn on bluetooth. look for devices. pair from there.
that should do it.
dave.
Top i-mate Computers & Internet Experts
ExpressFiX
ExpressFiX
Mohammad Abumuailek
Mohammad Abumuailek
Grand Canyon Tech
Grand Canyon Tech
Are you an i-mate Computer and Internet Expert? Answer questions, earn points and help others
