Question about SanDisk Sansa Clip MP3 Player
Sansa Clip not holding charge
If I fully charge my clip and then try to use it 2-3 days later, it is nearly dead even though I never turned it on since fully charging it. I even am careful to "lock" it in the off position to ensure that it was not accidentally turned on allowing the battery to charge.
  • randy_gay Jan 05, 2009
    Even if the unit is not "locked" during charging it still will not hold the charge.
  • 8,596 Answers
Locking the player will not allow the player to charge properly, no matter how long you have it plugged in.
Posted on Jan 01, 2009
My Sansa Clip MP3 Player is almost new, however the battery only last about 3-4 hours from fully charged. But now it appears to be completly dead which my computer will not even recognize it to start the...
Hey, greatings from lithuania
i have the same problem. Couple days ago i changed the battery from another sansa clip ant it worked fine, pc recognized sansa again :/ i think that the battery is dead , detailier the microchip wich is on the battery..
Oct 26, 2010 | SanDisk Sansa Clip MP3 Player
I was able to charge it fully last night but now it will not turn on this morning.It is a sansa clip i have tried holding the power up for a few minutes but still nothing.
I'm surprised it wouldn't turn on when plugged into external power. That would mean a different problem than a disconnected battery lead ... possibly a disconnected USB port lead, though then I would have expected that you'd be able to turn it on when not plugged in.
Feb 19, 2010 | SanDisk Sansa Clip MP3 Player
My sandisk sansa clip 1gb wont turn on
Make sure the player is fully charged. 1. Connect the player to the PC. 2. Make sure the computer detects the player.
NOTE: If needed, switch the player to MSC mode, 1. Turn device OFF. 2. Slide the Hold switch down to Lock (orange color showing). 3. Press and hold the center button while connecting the device to the PC.then connect it to the PC. Next Be sure the battery is charged 1. Leave the player connected for approximately 2 hours to charge. 2. Disconnect the player from the PC. 3. Verify if you can turn on the player. 4. Reset the player if necessary.
To reset the player: 1. Press and hold the Power/Menu button for approximately 20 seconds. 2. Release the Power/Menu button. 3. Press the Power/Menu button again to turn on the player.
If that does not do it, re-seat the battery: Here is how to get to the battery, 1. Press the battery compartment in while sliding to the right. 2. Remove old battery. 3. Insert new battery or reset the old battery. 4. Close the battery compartment. Then try and see if it will come on with out the battery hooked to your computer. 1. Remove the battery. 2. Connect the player to the PC to verify if it turns on. 3. Re-seat the battery to ensure proper connection. 4. Verify if the player turns on.
Jan 29, 2010 | SanDisk Sansa Clip MP3 Player
Sansa clip sandisk 2gb won't charge. Thought it was low and after plugging it in to computer overnight it wasn't fully charged but worked the next morning but suddenly died. Now it won't charge. Sansa...
I had the same problem this morning, albeit with my 8G Clip. Nothing worked -- the thing seemed dead as roadkill -- until I found a link about "forcing MSC mode." Basically, it told me to hold down the center button while plugging my Clip into my computer using my USB cable. Suddenly, boom! It's awake and alive and happy again. I'm unsure how that works, but that did it for me.
Nov 03, 2009 | SanDisk Sansa Clip MP3 Player
Sansa Clip Won't take a charge...
Are you sure the cable you are using provides both data and power to the device? Some cables are data only and will not charge the device despite appearing so.
Has it held a charge before? If this is a new device and has not yet ran down then charged fully again yet, then I would return it.
Jan 26, 2009 | SanDisk Sansa Clip MP3 Player
Sansa 1g clip wont turn on.
did you try holding the power button on for ten seconds (the reset) after trying to charge it again? does it even power up when you plug it into the usb. if it powers on when connected to the usb and then shuts off immediately when you take it off the usb (rather than "refreshing database") then your battery is either 1)disconnected inside 2)dead or there may be issues with power management. Same thing happened to me (disconnected) but I soldered the loose connection and it only worked for two days, even checking the connections again. Now I don't know what's going on. It's more likely the battery has reached the end of its life.
Nov 16, 2008 | SanDisk Sansa Clip MP3 Player
SanDisk Sansa Clip MP3 Player Logo
370 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
