Question about Watches
I was given a digital watch by a Saudi Prince. It is stuck in Middle East time. It has two buttons. One larger and one recessed. Any idea how to set to EST?
  • 2,338 Answers
Push the smaller button and holld till the display flashes, then adjust settings using bigger button.
Recessed pushbuttons usually is for MODE and the bigger for SET.
Posted on Dec 17, 2008
Please can u show me how to change the time on this watch.
Set the time on your Baby G by switching to time mode. The button on the bottom left-hand side of the watch is the mode button. Pressing it once to will set the watch to time mode. The time digits will begin to flash.
  • 2Start by adjusting the seconds. Press the button on the top-right side of the watch once. The second digits will start to flash. Press the bottom right-hand button until the correct second time is displayed. Hold down the button to cycle through the digits. Once the correct time is displayed, press the bottom left-hand button and the digits will stop flashing. Press the bottom left-hand button again to set the hours.
  • Sponsored Links
  • 3Follow the same procedure to change the hours setting. Set the time and date by cycling through the digits in the following sequence: seconds, hours, minutes, year, month and date.
  • 4Press the bottom right-hand button to set the seconds to 00. When the second display is between 1 and 29, the digits will change to 00. If the display is between 30 and 59 seconds, the seconds will revert to 00 and one minute will be added to the minutes display.
  • 5Change from an a.m. to a p.m. setting by pressing the button in the middle of the bottom of the watch when any of the time display digits are flashing.
  • Nov 03, 2012 | Watches
    I have a wave ceptor casio 4774 watch - looks great etc. Only problem is that I work in middle east and it does not correct itself so I am having problems constantly resetting the time. The casio watch...
    Nothing you can do. Where you work (middle east) there is no time signal radio station for your (radio controlled) wave ceptor watch.
    You can read more here:
    http://en.wikipedia.org/wiki/Casio_Wave_Ceptor
    Feb 19, 2011 | Casio G-Shock GW500A-1V Wrist Watch
    How do I set the analog time on an Ohsen FD0723 watch?
    press the lower button until all the digital numbers are flashing, then you press the middle button to set. Cheers Mark
    Nov 17, 2010 | Watches
    How to set the hands to match the correct digital display on my Casio wave ceptor 2734 wva-104h watch
    Setting Digital Time
    1. The digital timepiece on a watch is set using the function buttons on the outer part of the watch face. To set the digital time, press and hold the upper left button until the seconds starts blinking. Press the lower right button to reset the seconds to "00."
      Push the lower left button to move to the Daylight Savings Time portion of the watch. Use the lower right button to toggle between "On" and "OFF."
      Press the lower left button twice. The hours unit will start blinking. To advance the hour, press the lower right button repeatedly until the correct hour is displayed. If you need to move the hours unit backwards, press the middle right button until the correct hour is displayed. When the hour is set, press the lower left button to switch to minutes, and use the same commands to change the minutes unit.
      After the time is set, press the upper left button to exit the digital time setting function.
    2. Setting Analog Time
    3. You may find after setting the digital timepiece that the analog display does not match. When this occurs, you need to set the analog time. To set the analog time, press the lower left button 6 times. Next, press and hold the upper left button until the digital time starts to blink. This indicates that you are in analog time setting mode.
      Analog time adjustment is completed using the lower right button. Every time you press the button, the analog time will advance 20 seconds. If you need to make a big change to the analog time, press and hold the lower right button to make the hands move faster. Once the analog time is set, press the upper left button to exit the analog time setting mode.
    Aug 21, 2010 | Casio Watches
    Hour hand does not match digital time
    Hi, activate the touch screen, touch the middle of the screen 3 times slowly until you see the OPT in the LCD. press the middle big button on the side of the watch once until you see the 24H screen, then hold down the same side middle button for 5 seconds, the display will then say SYNCRO.
    You first move the hour hand with the top and bottom side buttons to 12 touch the middle of your screen to set then move the minute hand to 12 as straight as you can, then press the middle of the screen to set to exact digital time. Thanks Mark ;-)
    Sep 22, 2009 | Tissot T-Touch T33159851 Wrist Watch
    I have a Starter Brand Watch that did not come with a manual. I can't seem to get the chime to stop chiming on the hour.
    Just bought a STARTER Sport Watch Model# STW14 @Walmart
    TO CHANGE TIME:
    1. Press and release MODE button quickly 3X in a row(top middle no.(Seconds will flash)& change Seconds by pressing START button 2. Press & release RESET button 1X quickly(Minutes will flash) & you change Minutes by pressing START button 3.Press & release RESET button 1X quickly(Hour will flash) & you change Hour by pressing START button. 4.Press & release RESET button 1X quickly(Date will flash) & you change Date by pressing START button.5.Press & release RESET button 1X quickly(Month will flash) & you change Month by pressing START button 6. Press & release RESET button 1X quickly(Day of week will flash) & you change Day by pressing START button 7. Press & release MODE button 1X quickly to return to Normal use
    TO SET ALARM: 1. Press and release MODE button quickly 2X in a row(Hour will flash)& you change Hour by pressing START button 2.Press and release RESET button quickly 1X (Minutes will flash)& you change Minute by pressing START button 3. Press & release MODE button 1X quickly to return to Normal use
    TO VIEW MONTH & DAY: 1. Press & Hold START button 2.Just Release START button to return to normal use.
    TO USE STOP WATCH: 1. Press and Release MODE button quickly 1X 2. To START stop watch: Press START 1X quickly 3. To STOP Stop watch: Press Reset button 1X quickly 4. To RESET Stop watch: Press & Hold START button and press RESET button quickly @ the same time, 2X in a row 5.Press & Release MODE button 1X quickly to return to Normal use
    Sep 12, 2009 | Bulova Watch
    Change military time to standard time on a Casio e-data watch
    Depress the recessed 'Adjust' button (top left side) which will get the time setting flashing. Then depress the button on the lower right side once to get to the 24 hour time option. You will then have manually enter the time in that format. Once set, then depress the rescessed 'Adjust' button again.
    May 21, 2009 | Casio E-DataBank DBC3101 Wrist Watch
    Compass wont work correctly
    if your hands aren't straight when you use the compass try this to sync the hands.
    1. Press and hold the middle button to enter T-Touch mode.
    2. Press the centre area on the face twice to display 24hr/12hr
    3. Press and hold the middle button to enter T-Touch mode untill screen says sync.The hands will face 1200.
    4. Press either the upper (East) or lower (West) button to adjust the compass hands. They should both face 1200.
    5. Press the middle button to get back to 'regular' compass mode. Note that your offset setting will still show in the digital area.
    Oct 10, 2007 | Tissot T-Touch T33759851
    TIME IS NOT THE SAME AS THE DIGITAL TIME
    • Push the middle (T) button.
    • Touch the screen in the center selecting the units mode (24 C m).
    • Push the middle (T) button again for 5 seconds.
    • "SYNCHro" will appear on the display.
    • Use (+) button for min arm and (-) for hour arm.
    • Bring the two hands pre-cisely to 12 o'clock.
    • Press the middle (T) button to validate the setting.
    Oct 10, 2007 | Tissot T33.1.588.71 Wrist Watch
    Watches Logo
    326 people viewed this question
    Top Watches Experts
    Arturs Kalnins
    Arturs Kalnins
    Marvin
    Marvin
    Are you a Watch Expert? Answer questions, earn points and help others
