Question about Sharp Notevision PG-B10S Multimedia Projector
Sharp, home projector brought new lamp still see greenish tint & replace lamp prompt. I followed instructions for resetting to no avail so I called lamp provider. They say not a problem with the lamp Green tint sounds like something else. Need repair tech... Any ideas?
  • 2,237 Answers
The light filter on the blue lcd is toasted, thus causing the tint. as for the lamp prompt, you need to reset the lamp timer.
Posted on Aug 04, 2009
I replaced the lamp on my XGC55X Sharp Projector and it worked great for 2 nights (roughly 6 hours). Now it goes to warm up, with the lamp light blinking, and will power down with the status button showing...
Have reset the lamp hours after installing the new lamp? If, not the projector has treated the new lamp as old lamp & refusing to light further. So, reset the lamp hours to zero. To reset the lamp timer do as follows. Plug the power cord into the AC socket of the projector. Switch ON the power of the socket. (not projector) While pressing simultaneously INPUT, ENTER & UNDO on the projector, press ON on the projector. "LAMP 100%" is displayed, indicating that the lamp timer is reset.
If this does not correct your problem then the problem lies in other area. Let me know so that further I can provide you solution. Above things are preliminary
Aug 06, 2011 | Sharp XG-C55X Multimedia Projector
I replaced the lamp on my sharp dt100 projector and now it will not turn on
Have reset the lamp hours after installing the new lamp? If, not the projector has treated the new lamp as old lamp & refusing to light further. So, reset the lamp hours to zero. To reset the lamp timer do as follows. Plug the power cord into the AC socket of the projector. Switch ON the power of the socket. (not projector) While pressing simultaneously MENU/HELP, ENTER & DOWN (button near MENU/HELP) on the projector, press STANDBY/ON on the projector. "LAMP 000H" is displayed, indicating that the lamp timer is reset. If this does not correct your problem then the problem lies in other area. Let me know so that further I can provide you solution. Above things are preliminary.
Aug 06, 2011 | Sharp Office Equipment & Supplies
Projection lamp expired. how much is it to replace it?
you need the projector model number to find the proper projector lamp as not all projector lamps are made equal.
here are some sites you can find more information. just search based on your projector model.
http://www.projectorcentral.com/Sony-lamp-suppliers.htm
http://www.myprojectorlamps.com/
Projector lamps range from price. Low $100s to $300s based on the projector brand and model you have.
Mar 06, 2011 | Sony Televison & Video
Projector sharp XR-H325SA indicating lamp I replace tha new lamp but still indicating ineed to reset lamp timer but how?
hi,
for resetting the lamp hour do the following
1. Plug the power cord into the AC socket of the projector.
2. While simultaneously holding down MENU/HELP, ENTER and DOWN ARROW button on the projector, press STANDBY/ON on the projector.
3. "LAMP 0000H" is displayed, indicating that the lamp timer is reset.
ok
Jan 24, 2011 | Sharp XR-10X Multimedia Projector
SHARP XV-Z91E Projector Replaced lamp but
hold down menu, enter, and down arrow, then press power. this is the only way to reset the lamp timer. if it won't turn on and there are no leds lit, you may have to reset the bimetal breaker. to do so, remove the 6 bottom screws and the top 2 screws on the back panel, and remove the top case. on the front side of the lamp housing, you will see a red button. press it. if it clicks, it is reset. if it doesn't, it wasn't tripped, and you have a power supply issue.
Jan 12, 2010 | Sharp XR-10X Multimedia Projector
THE LAMP DOES NOT COME ON AND THE LAMP LIGHT BLINKS
New projector lamp time! you may have found that a symbol of a lamp comes on in the bottom corner of the picture after you turn it on for a short time. perhaps the lamp light has been flashing too. But yourself a lamp and be sure to follow the instructions that come with the lamp on resetting the timer- you must do this in order to get it to fire up again. Tip for the Sharps- Must replace it with the AC cord disconnected. (reconnecting the AC cord is part of the reset procedure)
Happy lamp shopping!
Jan 11, 2010 | Sharp (BQC-PGC20X//1) Projector Lamp for...
Left half image has greenish tint, other half fine XV Z9000U
I am having the same issue, did you ever get yours fixed and if so how please?
Shannon
Nov 25, 2008 | SharpVision XV-Z9000U Multimedia Projector
Lamp timer on Sharp XV-Z2000 will not reset
I unplug my cord, waited for 5 minutes, then reconnect cord holding the power button at same time, released, then proceded with input, left arrow, enter, right arrow and depress power button again holding for 15 seconds, then released. projector warmed up showing the  "0000H" on the bottom left of screen...that's how mine worked today.
Feb 15, 2008 | Sharp XV-Z2000 Multimedia Projector
Sharp projector XV Z90U
I also had this issue - followed the On, Input, Undo, Left, Enter, Right, On button sequence several times. Then I decided to push them in that sequence very quickly and it worked. The lamp LED on the front changed to green and the projector started up. So the button sequence they provide in the manual works, you just have to push them in rapid succession. Hope that helps.
Oct 31, 2007 | Sharp Projector lamp Projector Lamp
Green screen in the middle
Check the Fly-Eye lens and the RGB panels.
May 31, 2007 | Sharp Notevision PG-A10S Multimedia...
Sharp Notevision PG-B10S Multimedia Projector Logo
565 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
