Question about Elan VIA!dj-S MP3 Player
RE: Elan Via-DJ power supply
Hey--
I have a similar problem, what I would like to know (since my power supply isn't operational) what are the voltages on the power supply out pins? I believe that from left to right the colors are:
blue : black : black : red : red : yellow
I'd appreciate any help you can offer.
Thanks,
Darin
Hello, If you look on the connector on the main board (not the power supply) it is indicated, it is quite small writing, you may need a magnifying glass.
Posted on Dec 17, 2008
Why does the light in the front panel dims and lightens constantly
Possible there is a fault in the feed voltage to the display as the power supply can be pulsating. Please check the voltage on the display panel using a analogue multimeter and if it will shows a drifting signal the power supply unit must be checked . test voltage on the board to confirm if any capacitor has gone weak. If there is no voltage shift then the display driver IC is faulty.
Oct 01, 2011 | Elan VIA!dj-S MP3 Player
My chauvet Elan stopped working. I cant find a power switch and am not even sure how to check whats wrong
"Elan stopped working doesn't give us much to go on... does it light? Do you hear anything in it? Are you activating it from DMX or as standalone?
May 10, 2011 | Chauvet Elan 4 Channel Dmx 512 Led Dj...
Presario C714NR gr983UA#ABA ALPS touchpad does not work I have updated the BIOS and uninstalled and reinstalled the drivers but it still does not work
I had a similar issue with my ASUS. Try finding a program on your computer other than the Control Panel that controls the trackpad. For instance mine is Elan Smart-Pad. Usually working with some of the configurations in the program reinitialize the trackpad. If that doesn't work make sure that it isn't turned of due to keyboard interference (hitting a button that turns the trackpad off). Hopefully that isn't the case though.
May 10, 2011 | Compaq Presario 700 470024-192 Notebook
I need an elan via dj ii manual asap
do you still need this manual???
Nov 30, 2010 | Elan VIA!dj-S MP3 Player
The unit will not boot-up. Static message on screen reads: ViaDJ Starting ... I suspect, based upon research that the hard drive has failed. I can hear the hard drive spinning, but nothing...
Ok, my Elan Via!dj unit was doing the exact same thing. This is how you fix it. Take an aluminum baseball bat and in an over-the-head, ax swinging, motion, strike the unit from the top 4 to 6 times. Dispose of unit in dumpster. Fixed. - John Wilcox of San Diego California
Sep 28, 2010 | Elan VIA!dj-S MP3 Player
I can't eject a CD using the eject button. I've powered off the unit & restarted, with no luck.
Power off the unit. Under the right corner of the drive tray is a small hole (see pic). Find a paper clip that fits the hole. Straighten the paper clip and slowly push it in the hole. The drive tray gears will begin turning forcing the tray open. Gently pull tray all the way out. Power unit back up and see if it starts to respond again.
I don't know if it will completely fix the issue for sure but it is worth a try. I have had good results using this method if the drive is not truly broken.
Aug 11, 2010 | Elan VIA!dj-S MP3 Player
Elan home system s12 manual
Only place to get it from is the ELAN dealer site. I have access to that area. Still need it??
May 06, 2010 | Elan VIA!dj-S MP3 Player
Where can I but a replacement for my Elan ad/dc adapter it is 16v, 24w
I suggest looking on www.ebay.com.-(where you live for example uk for united kingdom) and look through for it
Dec 12, 2009 | Elan VIA!dj-S MP3 Player
Re my elan Via DJ
I have just repaired this same fault, check voltage with test meter on the main board from the power supply it is labeled with 0v -12 +12 and 5v (two of these) if the voltages are either low or rather high (usually within 5%) replace all the electrolytic capacitors on the power supply PCB ,( it's the small one in the corner next to mains inlet.) This should fix it for about £10.00. Hope this helps
Nov 13, 2008 | Elan VIA!dj-S MP3 Player
Speaker and Mic problems
Hello Elan, You will need to have the device dissasembled and checked for a loose connector to the mainboard. Those 2 components are linked to the mainboard via a ribbon like cable that may not be making a perfect electrical contact. It'a a cheap repair, you don't have to worry, other than that if the device is still in warranty it will be made for free.
Jun 05, 2007 | i-mate JAM Pocket PC
Elan VIA!dj-S MP3 Player Logo
391 people viewed this question
Top Elan Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Elan Audio Player and Recorder Expert? Answer questions, earn points and help others
