Question about Panasonic DMR-E55 DVD Recorder
DMR E55 won't read RAM Discs
I have replaced faulty Voltage Regulator, unit was turning off after about two minutes. Unit will now play CD's and DVD's but it will not read RAM Discs. Display reads "No Read" and then displays "1".
Clean the laser lens do no use a lens cleaner disc you need to dismantle the drive unit and clean lens with cotton bud and a isoproplyn solution also clean the disc turnble and clamp if possible get it done by somebody who knows what they are doing
Posted on Apr 20, 2007
    Genius:
  • 1,074 Answers
While you was replacing the voltage regulator you damage part of the microchip computer replace it.there after your worries will be over
Posted on Mar 26, 2007
Can't play recorded discs on other players or computer only DMR-E
TRY FINALIZING THE DISC IN THE SAME UNIT IT WAS RECORDED IN.
Mar 17, 2009 | Panasonic DMR-E55 DVD Recorder
Failure to accept DvD Ram discs in a Panasonic DMR-E55 Recorder
Possibilities are that the laser lens needs cleaning (use a proprietary cleaning disc) or that - as long as you are sure you have original manufacturers' discs and not fakes - the discs are scratched or dirty.
Feb 20, 2009 | Panasonic DMR-E55 DVD Recorder
Panasonic DMR E55 Won't record AT&T U-Verse programs!
Make sure you only use the correct type of discs: DVD-RAM or DVD-R for recording and DVD-RAM, DVD-R, DVD-Video, DVD-Audio, Video CD, CD-Audio (CD-DA) and CD-R/RW (MP3, CD-DA, Video CD formatted discs) for playback.
DVD-RAM disks are in plentiful supply on eBay, both new and used. Keep an eye open and you should pick them up, new, for less than £1 Sterling each!
I am unclear, though, what you mean about recording to and from the VCR. The DMR-E55 doesn't have a VCR facility, just DVD.
Jan 26, 2009 | Panasonic DMR-E55 DVD Recorder
Will my non finalzied discs play on a panasonic ez 28 or ex 768
You will have no problem playing your non finalized discs on any of the Panasonic DMR range including the DMR EZ28 series. The DMR E55 can also easily be repaired if you can use a soldering iron and a little care. Please checkout my other postings for full repair details.
Cheers...
Oct 08, 2008 | Panasonic DMR-E55 DVD Recorder
DMR E55-P will not read DVD-R
Hi Benyto
Thank you for the information. Sorry that you are having such problems.
Nearly all the problems on ths DMR E55 are due to a faulty power board. The greatest load on the power supply is when the unit first reads discs and also when finalizing. Sometimes the unit cannot read discs and sometimes it continuously self checks.
Try replacing IC001 on the power board. This is a 5 pin regulator #STRG6353. This component gets very hot and the heatsink is poor. When I replace these, I use a larger heatsink and some heatsink paste which helps to prolong the life of the component. If you look at the regulator, you will see by the colour of the circuit board that it gets very hot. It fails after two or three years in all DMR E55s.
Be careful when you take the old regulator out because the print can lift away from the circuit board.
I have posted full instructions on how to replace the STRG6353 >HERE<
Hope this helps
Mar 02, 2008 | Panasonic DMR-E55 DVD Recorder
Trouble with my Panasonic DVD recorder DMR-E55EB
Hi Dengle
The heat is caused by IC001 which is a regulator that is mounted on a completely inadequate heatsink on the power board. This component gets very hot during normal operation.
The regulator will usually last a couple of years, depending on how often the machine is used and then start playing up. The symptoms are intermittent operation, continuous self checking and rebooting, not being able to read discs and so on.
Eventually the component can short-circuit, burn out and take other components with it. The on-board fan is thermostatically controlled. It does not operate all the time, only when the unit gets hot enough. By using an external fan, you are keeping the unit cool enough for its own fan never to cut in. The additional cooling is probably squeezing a bit more life out of the regulator and is stopping its own fan from operating.
I have repaired lots of these and have never found a faulty fan, or fan switching fault. There's always a first time of course.
It is more likely that the regulator IC001 is faulty and if you are technically skilled, I would suggest you seriously consider replacing it. Use some heatsink compound and an extra heatsink, and it will probably do the trick. The regulator is an STRG6353. You can get these easily online from a number of outlets. Don't attempt a repair if you are unsure of what you are doing. Regards..
Nov 18, 2007 | Panasonic DMR-E55 DVD Recorder
Playing discs.
go to settings of check if it is PAL OR NTSC
Oct 19, 2007 | Panasonic DMR-E55 DVD Recorder
Panasonic DMR-E55 DVD Recorder Problem
I have been told that panasonic now have a faster speed disc on sale to suit the newer dvd recorders that dmr-e55 cannot record on as they are too fast. You have to buy the slower speed ram discs to suit the dmr-e55.
Aug 26, 2007 | Panasonic DMR-E55 DVD Recorder
DVD Recorder works fine for a while then shuts down
You need to replace the Voltage Regulator. Part No STGR 6353. There are several paces to obtain one on the internet. signalsuk.com can supply it for around £12.
Aug 29, 2006 | Panasonic DMR-E55 DVD Recorder
Panasonic DMR-E55 DVD Recorder Logo
163 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
