Mitsubishi VS-45607 45" Rear Projection Television Logo
Posted on Dec 17, 2008
VS-45603 we have power but nothing else will show up on screen.
We scooted the tv 2 feet and now nothing will show on the screen. the power light will come on and nothing is on the screen. we tried pushing everything, input, menu, etc... and nothing shows on screen. cable is hooked up correct, it was checked by 2 cable professions. there is cable signal to tv.
  • jpugh001 Dec 26, 2008
    I have the same problem checked fuses and they are fine.
Anonymous
Level 1:
  • Contributor 41 Answers
  • Posted on Dec 17, 2008
Anonymous
Contributor
Level 1:
Answers
41
Questions
0
Helped
8608
Points
65
I would suspect bad solder connections on the convergence IC's caused one to short out a blow one or more pico fuses, thus causing the set to go into shutdown so as to stop further damage to the set. The TV will need to be seen by a profesional to confirm or deny this.
Hello I have a mitsubishi vs-45603 with what appears to be a convergence problem.
You may have bought bad chips or your soldering...
This is a common problem on many brands of Projection Tv sets. Its usually a convergence issue. You can get more details and a solution here on fixya using this link http://www.fixya.com/support/r11932741-convergence_repair_dull_video_repair
5helpful
5answers
Mitsubishi VS-45603
You will need to go into the menu, setup, a/v connection, then make sure the locked to input is selected to no..
Good luck..
After big storm the tv only shows small picture in upper right corner. Will not allow to go to full screen. VS-45603
You are in pip mode, and if itwill not let show on regular mode, then your tuner is out,and youcan bypass it and go directly into the video input with RCA cables from your recieever,and put your set in video mode,better picture, and save you 500 dollars on a new tuner.
1helpful
Mitsubishi VS-45603 had power outage and when it came back on it says TV is locked. How do I unlock it?
Go into the 'Menu' -> then 'Setup' -> then 'A/V Connections'.
You should see an option called 'Locked to Input' switch it to 'No' and your problem should be solved!
Screen fades occasionally. Perfetc and them fades dark for about 5 min. Is that the bulb? Howmuch is a new bulb?
Make sure that in the settings that your TV isn't setup to auto dim. I remember I had a similar problem. I think when ever a light would turn on or someone would walk near the TV it would get dim. It was really annoying. Check your settings. Good luck
No picture or sound on Mitsubishi VS-45603
you may want to inspect it for a fluid leak. Look on the signal pcb first. look for any signs of liquid on the connectors. If the leak is found and has been there for awhile before it finally shorted out a connector then chances are that it corroded the pcb
Mitsubishi vs45607 dead
Check for leaky D980 PART # 264P045040. You also can try to do a self test to get the error codes, search here or on ctechnicians.com
Only Picture in Picture Works...????
Its possible some of the surface mount capactors has failed on the pip board is so the unit will need to be replace or repaired.
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
